Question about VIA P4XB-M Motherboard
PS 2 port problem
Dear sir /madam
i have system 800mhz VIA processor , 40GB , 256DDR2 newly purchased , its PS2 ports are not working due to some hardwarw designing PS ports are present in board , i donot know jumper setting between USB & PS .help me in this matter
thanks
  • Anonymous Mar 29, 2009
    i have no vga driver
    President:
  • 2,351 Answers
What is the model number of your motherboard? VIA does not make Processor's/CPU's.
VIA makes chipset's for motherboards.
In order to answer your question I'll need the manual for the motherboard. No manual listed here: http://www.via.com.tw/en/products/mainboards/others/p4xb_m.jsp
Here is a picture of the VIA P4XB-M motherboard. This model can not use DDR2 memory. (Only, 184pin PC2100 DDR266 DIMM)
Found here: http://www.upgradecomputermemory.com/ram.cfm//memory/V/VIA-Technologies/P4XB-M-Motherboard/256MB-VIA-Technologies-Desktop-184pin-PC2100-DDR266-DIMM.html
VIA P4XB-M
http://www.via.com.tw/download/mainboards/4/11/P4XB-M.pdf
99.0% of motherboards still use PS2 ports. One colored purple for the PS2 keyboard female port, back side of the MB & the other colored light green, female port, back side of the MB PS2 mouse port. By default, most motherboards have the jumper for PS2 keyboard enabled. Location for this two-pin jumper varies from board to board.
A USB port looks like this:
http://www.rickysays.com/images/usb-port.jpg
The PS2 port's are found in the upper left hand corner of this same picture. This next link will show how to connect USB motherboard jumpers including their wire locations. (Standard for most motherboard USB connections).
Mike
Posted on Dec 16, 2008
Specifications only
CPU º Socket 478 for latest Intel Pentium 4 / Celeron processor
º FSB 533/400 MHz
º Support Hyper-Threading Technology CPU
CHIPSET º VIA® P4M266A & VT8235
º North Bridge: VIA® P4M266A
º South Bridge: VIA® VT8235
GRAPHICS º Integrated S3 ProSavage8 2D/3D Graphics
º Share Memory : 8/16/32MB
MEMORY º 2 x 184-pin DDR DIMM socket support up to 2 GB
º Support DDR266/200 DDR SDRAM
Due to the operating system limitation, the actual memory size may be less than 4GB for the reservation for system usage under Windows® 32-bit OS.
For Windows® 64-bit OS with 64-bit CPU, there is no such limitation
EXPANSION SLOT º 1 x AGP 4X slot
º 3 x PCI slots
º 1 x CNR slot
STORAGE º Support by VIA® VT8235
• 4 x Ultra DMA133/100/66 devices
AUDIO º Realtek ALC655 6-Channel audio CODEC
º Compliant with AC'97 2.3 specification
LAN º VIA® VT6103 10/100 Mbps Fast Ethernet PHY
REAR PANEL I/O º 1 x PS/2 keyboard & PS/2 mouse connectors
º 4 x USB ports
º 1 x RJ45 LAN connector
º 1 x VGA port
º 1 x Parallel port (LPT)
º 1 x Serial port (COM1)
º 1 x Audio port (Line-in, Line-out, Mic-in)
INTERNAL I/O CONNECTORS & HEADERS º 1 x 20-pin ATX Power Supply Connector & 4-pin 12V Connector
º 1 x FDD connector supports one 360K~2.88MB FDD
º 2 x IDE connectors
º 1 x IrDA for SIR header
º 1 x SPDIF out header
º 1 x USB 2.0 header support additional 2 USB ports
º 1 x Front panel switch/LED header
º 1 x Front panel audio header
º CD in/ AUX in headers
º CPUFAN/CASFAN connectors
SYSTEM BIOS º Award BIOS with 2Mb Flash ROM
º Supports Plug and Play 1.0A, APM 1.2, Multi Boot, DMI
º Supports ACPI revision 1.0 specification
FORM FACTOR & LAYERS º Micro-ATX Size (244mm*244mm), 4 Layers
for more detail look at this site
http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?DetailID=436&CategoryID=1&MenuID=18&LanID=19
i hope this helpful
thank you for using fixya
Feb 06, 2011 | EliteGroup P4VMM2 V8.1 Motherboard
I have a dell inspiron desktop that has no ps2 port, only USB. From my older computer I would like to use my microsoft ergonomic keyboard that has a ps2 plug. I bought a PS2 to USB adapter but when I...
The adapter you purchased is for use with a PS/2 mouse only. The only keyboard adapters will have keyboard and mouse in a "Y" adapter. The single adapters will not work for keyboards because they do not have the conversion electronics to go from PS/2 to USB, mice can work on either one. Do a google search for "usb to PS2 dual port adapter" you can get them for around $2 plus shipping.
I hope this helps, if so please rate our solution.
BuddyMc
Dec 23, 2010 | Computers & Internet
My friend has an hp he bought - one or two years ago, everything works fine except the mouse and keyboard ports are all messed up from the cords being ripped out and put back in, is there any way to just...
Try the keyboard and mouse on anothe system. if it works fine the on board PS2 port is most likely bad. Buy a USB keyboard and mouse in plalace of the PS2 keybaord and mouse or change the motherbord. If the keyboard and mouse is bad replace with a good one.
Sep 28, 2010 | HP (D7580-60003) Motherboard
I just purchased an iogear GCS1742 2 port kvm Switch. The keyboard is the only piece of hardware that will not work. I have two cpu systems and one monitor. The keyboard has a PS2 connector with a usb...
Bill,
Due to the keyboard emulation that the GCS1742 uses it may not work with a PS/2 to USB adapter. If possible try using the KVM with a basic USB wired keyboard. This will tell you if the KVM is in working condition or if there is a problem with the actual KVM. If the KVM does not function correctly with a basic USB wired keyboard then I would think there is a problem with the KVM.
May 20, 2010 | IOGear GCS1742 2-port KVM Switch
Can you play ps2 games on ps3 40gb
Not with the discs...ONLY if you download the game via the PSN Shopping network.
You can only play PS2 games on units that have 4 usb ports.
Nov 21, 2009 | Sony Playstation 3 (PS3) Console
PS KB .MOUSE PROBLRM
that means you didnot clone the system yourself and it will be difficult for you to fix it. so get USB mouse and keyboard. thats the only solution for now unless you can talk it to a qualified repairer in your area.
Dec 15, 2008 | Computers & Internet
Dear sir/Madam i have a PC 800mhzVIA , 256DDR2, 40GB, PC model is TC700 and its PS2 keyboard ,Mouse are nor working due to some hardware designing .Help me in this matter thanks
the best solution is to get USB mouse since PS2 muuse is not working. and if you cloned the system yourself i suggest you take a look at the motherboar and youy will see a jumper labelled on the board PS2 keyboard and Mouse, place the jumper in the next pin. and try and see if it will work.
VGA doesn't work on my EMachines W2040
Take new vga graphic card which can be use in agp slot and upgrade ur system with it. ok bye bye
Sep 25, 2007 | E-Machines eMachines Desktop PC
VIA P4XB-M Motherboard Logo
215 people viewed this question
Top VIA Computers & Internet Experts
David
David
Tony
Abhinandan  Patil
Abhinandan Patil
Are you a VIA Computer and Internet Expert? Answer questions, earn points and help others
