PS KB .MOUSE PROBLRM
Dear sir /madam
i have system 800mhz VIA processor , 40GB , 256DDR2 newly purchased , its PS2 ports are not working due to some hardwarw designing PS ports are present in board , i donot know jumper setting between USB & PS .help me in this matter
thanks
  • nas john
    nas john May 11, 2010
    please help me with the model of your pc
  • 449 Answers
That means you didnot clone the system yourself and it will be difficult for you to fix it. so get USB mouse and keyboard. thats the only solution for now unless you can talk it to a qualified repairer in your area.
Posted on Dec 15, 2008
How do I connect the mouse?
212
i am assuming you have a usb mouse and a PS2 connection on the computer. If this is the case then you need a female usb to ps2 mouse adapter
So that the mouse cable plugs into the USB female connection and the male ps/2 plug end goes int othe female ps2 port on the computer.
If this is the case you have the wrong converter the chester will convert a ps/2 on the mouse or keyboard to a usb on the back of the computer.. Can you tell us what sort of mouse you are trying to connect does the end of the cable have a usb plug on it a bit like the blue usb plug in your picture.
Google it and see the difference.
Mar 12, 2015 | Chester Creek PS/2-USB Converter PS/2 to...
I have a dell inspiron desktop that has no ps2 port, only USB. From my older computer I would like to use my microsoft ergonomic keyboard that has a ps2 plug. I bought a PS2 to USB adapter but when I...
The adapter you purchased is for use with a PS/2 mouse only. The only keyboard adapters will have keyboard and mouse in a "Y" adapter. The single adapters will not work for keyboards because they do not have the conversion electronics to go from PS/2 to USB, mice can work on either one. Do a google search for "usb to PS2 dual port adapter" you can get them for around $2 plus shipping.
I hope this helps, if so please rate our solution.
BuddyMc
Dec 23, 2010 | Computers & Internet
My friend has an hp he bought - one or two years ago, everything works fine except the mouse and keyboard ports are all messed up from the cords being ripped out and put back in, is there any way to just...
Try the keyboard and mouse on anothe system. if it works fine the on board PS2 port is most likely bad. Buy a USB keyboard and mouse in plalace of the PS2 keybaord and mouse or change the motherbord. If the keyboard and mouse is bad replace with a good one.
Sep 28, 2010 | HP (D7580-60003) Motherboard
I was sold a mouse...with a round end....where is the portal on the computer?
That end is a PS/2 connector most modern day laptops do NOT have this connector, you need a USB Mouse, I suggest you take it back and try and swap it, for one compatible with your PC.
Feb 22, 2010 | HP Presario C555nr Notebook
PS/2 connection for mouse and kb faulty. How can I repair this. My USB mouse and kb replacement have their limitations. I need the PS/2 connection.
go to Frys, and get a PS2/USB adapter module, and plug your keyboard and mouse into a USB port. Or get a new one...all the new ones are USB now anyway...no one uses PS2 anymore unless they have a really old computer...and if you do, it's not going to last forever, so be prepared. This sounds like a motherboard issue.
Jan 15, 2010 | Asrock ConRoe1333-D667 Motherboard
How to disable ps2 on GA-8IR533 Motherboard
PS2 is usually disabled In the BIOS under ADVANCED or PORTS, but if that option is not available, I suggest you purchase PS2-to-USB adapters, then use your usb mouse and usb keyboard in the ps2 ports. Personally, I love ps2. id rather use USB for my cameras and scanners and drives rather than wasting those ports on a kb and mouse.
Oct 01, 2009 | Gigabyte GA-8IR533 Motherboard
PS 2 port problem
What is the model number of your motherboard? VIA does not make Processor's/CPU's.
VIA makes chipset's for motherboards.
In order to answer your question I'll need the manual for the motherboard. No manual listed here: http://www.via.com.tw/en/products/mainboards/others/p4xb_m.jsp
Here is a picture of the VIA P4XB-M motherboard. This model can not use DDR2 memory. (Only, 184pin PC2100 DDR266 DIMM)
Found here: http://www.upgradecomputermemory.com/ram.cfm//memory/V/VIA-Technologies/P4XB-M-Motherboard/256MB-VIA-Technologies-Desktop-184pin-PC2100-DDR266-DIMM.html
VIA P4XB-M
http://www.via.com.tw/download/mainboards/4/11/P4XB-M.pdf
99.0% of motherboards still use PS2 ports. One colored purple for the PS2 keyboard female port, back side of the MB & the other colored light green, female port, back side of the MB PS2 mouse port. By default, most motherboards have the jumper for PS2 keyboard enabled. Location for this two-pin jumper varies from board to board.
A USB port looks like this:
http://www.rickysays.com/images/usb-port.jpg
The PS2 port's are found in the upper left hand corner of this same picture. This next link will show how to connect USB motherboard jumpers including their wire locations. (Standard for most motherboard USB connections).
Mike
Dec 15, 2008 | VIA P4XB-M Motherboard
Dear sir/Madam i have a PC 800mhzVIA , 256DDR2, 40GB, PC model is TC700 and its PS2 keyboard ,Mouse are nor working due to some hardware designing .Help me in this matter thanks
the best solution is to get USB mouse since PS2 muuse is not working. and if you cloned the system yourself i suggest you take a look at the motherboar and youy will see a jumper labelled on the board PS2 keyboard and Mouse, place the jumper in the next pin. and try and see if it will work.
Dec 15, 2008 | Computers & Internet
MS Wireless Desktop set - KB and Mouse
Well this problem has nothing to do with your Operating System. This has everything to do with your System Bios.
Basically, the first thing you need to determine is "Is it USB or PS2?"
If it's USB:
1) Is it installed in a USB Hub? It might not have enough power, try a different USB port.
2) Go into the system bios. Look for an option that says "Enable USB Support" make sure it's enabled.
If it's PS2:
1) The connection might be lose, turn the computer off, unplug it, plug it back in.
2) Try a different PS2 Keyboard, same problem? Your PS2 ports are failing, buy a USB Keyboard.
Dec 23, 2007 | Microsoft Wireless Optical Desktop Comfort...
Computers & Internet Logo
330 people viewed this question
David Payne
David Payne
