Question about Garmin (010-00583-00) for nuvi 750/760/770
Clearing a trip in progress
When I set a trip from point a to b and somewhere between, I change my mind and decide to go somewhere else; how do I clear out the trip that I set, so that I can set the new one?
    Problem Solver:
  • 10 Answers
Use 'Where to' to find or enter the place where you now want to go. You should be offered "replace existing destination?" Tell it yes and it will clear out your previous trip and calculate the new one.
Posted on Dec 26, 2008
I just purchased a Vigoro zinc spike sprinkler . I want to set it to 360 degrees watering . The only instruction to do this is : Full circle : Left trip pin I've played with it a bit but have not hooked...
Lift completely up or down on the mechanism that allows for it to STOP against the setting pins. 360 is a full circle and if you can't spin the head all the way around, readjust the mechanism until it clears both the right and left stopping pins. Once you accomplish this and turn it on, you will have 2 options for operation...progressive traveling and return traveling. The trip lever can be moved to set that accordingly.
Apr 19, 2011 | Garden
How do I cancel the progressive scan?
Try looking on the internet for the company and model and get the manual, if you dont have it. My insignia DVD=VHS recorder had a brief note somewhere in the manual that mentioned performing some change to reset the progressive scan. It was easy, like stepping through the menu to an obscure setting or pressing a rest button on the player. Good luck
PS, if you have a problem give enough info, like Brand/model, etc
G
Mar 03, 2011 | Insignia Televison & Video
Keeps recalculating route and rerouting
This may or may not help you.  If you are in area where the unit cannot get a signal it will tell you recalculating or if you are in area where it's maps are not up to date it may tell you the same thing. One other possible solution, shorten the trip, on a long trip the unit will/might find several possible routes and based on your settings it is unable to select just one route so it is choosing between two at the same time and it will keep recalculating until circumstances allow it to decide on just the ONE route.  Change some of your settings in the setup screen and see if that helps or if it is a long trip, break the trip up into smaller segmants. Hope this helps
Jun 01, 2010 | Tomtom ONE 130 GPS Receiver
Need a point setting for ao smith air compressor ac motor model number opa-0297 s# c56b72b2316508j2 work on air machine with motor installed motor will hum and trip breaker can we set points to stop trip...
try running up this motor when its not installed on the compressor,, if it still blows the trips the motor is faulty,, if it runs ok, but hums when reconted to the compressor the compressor if far to tight for the motor to turn the compressor,,,you can not reset the points in a breaker trip they trip at a set curent if the motor is pulling more amps than the trip is set for it will trip the trip to turn off the curent, the motor will pull far more amps than it should if its over loaded thats why its humming its trying to spin up it but cant so it just keeps pulling more and more amps till the trip cuts out
Mar 25, 2010 | AO Smith 2 Hp Spl 3450rpm M56 Frame...
Front tank fuel gauge not working
If the gauge works on the rear tank but not the front, the problem is most likely the sending unit in the front tank. You will have to drop the tank to change it. I guess what I would do is, set your trip meter to zero when you fill the front tank. Then, run that tank to the point where the truck is starting to run out of gas and then switch to rear tank. Keep track of how far you can go on the front tank. Then when you refill the front tank reset the trip meter and switch tanks about 20 miles before you think it's going to run out. It's not a good idea to run those pumps dry. Just make sure you have gas in the rear tank. If you do decide to change the sending unit, run that front tank as empty as you can, also, I would change the pump too. In 92, I think the pump or the sending unit can be replaced seperately. The worst thing about changing those in tank fuel pumps is getting the gas out of the tank. No trip meter? Just write down the mileage from the odometer. Good luck.
Feb 06, 2010 | 1992 Ford F250
My purple proggesive kenmore upright motor works but beater not beating help thank you
I just had the same problem - reset button didn't trip - cleaned the roller - ultimately found there is an override switch at the point where the hose attaches to the base of the vacuum - it disables the roller when you use the attachments. The hose had become loose (but not disconnected) enough to trip the switch. An easy fix after alot of tinkering... p.s. All those "experts" that said to change a belt obviously don't understand that this model is beltless...
Nov 09, 2009 | Kenmore 31913 Progressive Direct Drive...
I have a HD TV with cable and a go video DVD/VHS player hooked up. I went to change the time and accidentally changed the setting on the DVD player from auto scan (I think) from off to on and now when I...
It sounds like you may have enabled the progressive scan output on your DVD-VHS combo. This is a correct setting if your TV support it. However most DVD players that support progressive scan will not support an interlaced signal and a progressive signal at the same time.
It would appear that you are using a composite type cable (3 RCA ends. 1 for video and 2 for audio) for this hook up. This means you have two choices.
#1 Look in the manual for the unit for the FACTORY Reset option. Its usually a combination of plugging the unit in while holding the power button or something similar to that. Without a model # I can't help any further with this option.
#2 Use a component video cable (3 RCA red/green/blue) to plug your DVD/VHS player into a compatible input on your HD TV. Your TV will pick up the progressive scan output from the unit and give you back your on screen display. At this point you can go back into the menu and disable progressive scan. And now just reverse the process to plug the DVD player back in using the composite cable.
It should be noted that if you have a progressive scan TV which HD TV's support you will get a better picture if you use the Component video cables instead of switching back to the composite cable. If you decide to use the component cables you will still need to run audio cables though.
Best of luck.
Trevor
Aug 11, 2009 | GoVideo Go Video DVD/VCR Combo
1999 Plymouth grand voyager ABS
You can have the ABS disabled although it is not advisable. Keep in mind on icy , wet, slippery roads without ABS you could lock the wheels causing a slide. Be careful on your trip if you decide to do this.
Jan 12, 2009 | 1999 Plymouth Grand Voyager
How to set the Trip odometer
You push in the stick and wait for it to go to "Trip" then you will just hold it in until it resets. I do this to find my gas mileage.
Nov 13, 2008 | 2006 Chevrolet Monte Carlo
Pioneer dvd recorder dvr 310
I've seen this problem somewhere before, ran across it on a service call or something and I just can't remember where.. Just getting old I guess.. You should have a "Return" button on the remote. Press it and the "2"... That should allow you to access the unit again. What you've done basically is set the unit up as unit 2 and you could have as many as 3 identical units all operating from the same remote. So, Pioneer, in their infinite wisdom decided to make three specific designation points and allow you to switch the remote to access each one without disturbing the rest... If this doesn't solve the problem you might try calling Pioneer support, 800-421-1404 and they should clearly be able to help. Good Luck Bill
Jun 07, 2007 | Pioneer DVR-3100 DVD DVD Recorder
Garmin (010-00583-00) for nuvi 750/760/770 Logo
62 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
