Question about Kenmore 95589 Electric Kitchen Range
Replacing both receptacle and cooking element but it is still not
Need your help, please!
I was trying to fix my Kenmore cooking range without luck yesterday, please give me some advice.
Here is our little background.
First, we saw a little sparkle when we turn on one of my large cook top (8 inch), then this cooking element is not heat at all, and then I want to confirm to see if I need to change range receptacle or cooking element, I pull out the cooking element and plug into another receptacle, but I saw sparkle again when I turn another one on, I mess up one more cook top, so now both of my large cook tops are not working. =(
So, I replaced brand new both receptacle and cooking element but it is still not heating at all, so I use my voltage tester to test it, and it doesn't show have enough voltage to heat up this element, but I know at least have some voltage because I used testing screwdriver to test it and I got a light but it didn't tell me how much voltage is it.
Now both of my little cook tops are working fine, but both of my large one do not have heat at all.
Base on my little story, is it something cost a lot of money to fix? Or there any fuse on the back that I can easily change it myself?
Thank you very much....
  • 906 Answers
Good day,
hope this link below will solve your problem.
cooking
Posted on Aug 05, 2010
    President:
  • 1,304 Answers
You just may have shorted your king sealy or robert shaw switches for those burners
check the selection switches behind the control panel
Posted on Oct 05, 2009
4 Suggested Answers
jsrock516
  • 5911 Answers
SOURCE: Dual cooking zone burner not working
Okay...what you have is a dual element with the 6 inch coil burned out. Yes, this is repairable, but unfortunately, since this is a dual element, it is sold as one assembly. The part number for a replacement is WB30T10044, and you can find it at repairclinic.com for about $90 (repairclinic item number 824238). I know it isn't cheap, but it beats having to pay for a service call, or buying a new appliance.
If you wish to repair this yourself, you can do so by following these steps:
1. UNPLUG the range before servicing. There are dangerous voltages still present even with burners turned off.
2. There are a few screws located under the front edge of the cook top. You will need to open the oven door to see them. Remove these screws and the top should lift up. If the range is not equipped with any kind of hinge supports, the top will have to be propped up.
3.On some ranges, there is a disconnect plug for the surface element wiring harness. If you have this feature, unplug the wire harness from the connector and follow these steps:
a. Unplug the cook top and leave the elements in place.
b. Place the whole cook top assembly face-down on a soft surface (like some old towels, or a blanket).
c. Remove the affected surface element. Take note of the numbered positions where the mounting screws are located and locations of the wires. You may want to write down the numbered positions and the wire color codes. HINT: A good digital camera can save you time if you have one. You will need to install the new element in the same manner.
d. Install new element (upside down). Handle the surface elements with care. They are very fragile. Care also must be taken not to handle the element coils or ceramic material. Try to handle from the underside of the element only. Oil from your hands can cause damage to the element and/or premature failure.
e. Re-install the cook top back on the range and you are DONE.
NOTE: If your range does NOT have a disconnect plug on the wiring harness you will need to perform the repairs with the cooktop propped up, and install the surface element assembly from underneath. A helpful hint: Use some duct tape to hold the element secure until you have it screwed back into place. Don't forget to remove the duct tape when completed. Once completed, lower the cook top and secure with screws.
I hope you find this information helpful. Let me know if you have require additional assistance.
Posted on Sep 09, 2008
  • 360 Answers
SOURCE: kenmore glass top range left front large burner out
check the burner socket, it is likely that contact is being lost where the burner connects to the hardwired portion of the system (the socket). It is not unusual for the socket to "burn up" when there is a poor connection to the burner resulting in the burner being replaced and the new burner not working or working intermittently.
Please take the time to rate this solution
Posted on Jan 29, 2009
headstrong56
  • 493 Answers
SOURCE: The oven heating element won't turn off
I would thing if you called an appliance service store or retailer and gave them the make and model number of the stove they can sell you one and maybe install it if you need them to but I would thing it would be called the oven switch
Posted on Jul 24, 2012
Why is my broil element not working?
On an electric range, sometimes the broiler element just gets corroded where it plugs into the element receptacle. It should pull out (with some degree of physical encouragement) and you can take some emery cloth (hardware store) and lightly sand the blades that plug into the receptacle. Slide it back into place. Might need to encourage it a little with a block of wood and lightly tapping on it with a hammer. (Block of wood BETWEEN the element and the hammer.)
Jul 13, 2014 | Kenmore Kitchen Ranges
Tip
Replacing a Glass Cook Top
This advice is for Electric Ranges equipped with glass smooth tops. If it becomes necessary to replace the cook top due to wear or damage, here's some helpful tips on how to complete the repairs yourself. NOTE: Cook tops are NOT cheap. Prices vary between models, but most are in the $200 to $300 range. With added labor charges, this repair can cost over $600 from an appliance repair company.
WARRANTIES: Most warranties DO NOT cover cosmetics. That is, if your cooktop paint starts to wear off, most manufacturers will not replace it. Warranties also DO NOT cover accidents such as dropping something on the top and breaking it. Warranties DO cover blistering, warping and heat related breakage (if you are using the recommended cookware). This is why it is important to follow all the manufacturer's use and care instructions that come with your range. I know this does not include ALL manufacturers, but this is true with most.
This is a recommended two-person repair job. Please read through the instructions carefully before starting the repairs, and follow any safety recommendations.
2. If the old cook top is broken, you will need to get rid of a much of the glass shards as you can and thoroughly vacuum the area around the oven box. Use extreme care when handling broken glass. Wear safety glasses and gloves.
3. There are a few screws located under the front edge of the cook top. You will need to open the oven door to see them. Remove these screws and the top should lift up. If the range is not equipped with any kind of hinge supports, the top will have to be propped up.
4.On some ranges, there is a disconnect plug for the surface element wiring harness. If you have this feature, Follow these steps:
  1. Unplug the cook top and leave the elements in place.
  2. Place the whole cook top assembly face-down on a soft surface (like some old towels, or a blanket).
  3. Remove the surface element assembly leaving all the elements wired together.
  4. Place the new cook top face down in the same manner and lay the surface element with wiring harness directly on to it and screw in place.
  5. Install the new cook top back on the range and you are DONE.
5. If the wiring harness does NOT unplug, follow these steps:
  1. There are a series of screws holding the element assemblies in place. Leave these assemblies wired together for ease of replacing. It is recommended that a second person holds the assemblies in place to support the wires until all the screws have been removed.
  2. Lay the intact element assembly, with wires still connected, on top of the oven box. Handle the surface elements with care. They are very fragile. Care also must be taken not to handle the element coils or ceramic material. Try to handle from the underside of the element only. Oil from your hands can cause damage to the element and/or premature failure.
  3. If you have to remove the elements, individually, make sure you write down how the wires were connected to ensure you reconnect them in the right order. Make sure you also take note of the numbering scheme on the element and make sure you place the mounting brackets in the same holes that they came out of. Use care when screwing into the new cook top. CAUTION: The screw holes are usually painted and a little force may be required to thread the screws. Do not apply too much pressure on the glass, or you can damage it.
  4. Prop the new cook top in place and install the surface element assembly from underneath. A helpful hint: Use some duct tape to hold the assembly until you have screwed it back into place. Don't forget to remove the duct tape when completed.
  5. Lower the new cook top into place and secure with screws.
    Good luck and I hope this helps.
on Mar 02, 2010 | Kitchen Ranges
Tip
on Feb 11, 2008 | GE Spectra JBP78 Electric Kitchen Range
Hi, MY name is Ben I have problem with my Kenmore (GE) gas range. the oven does not start up...I've replaced the igniter, but no luck. I measured the voltage across the the two wires at the inigter and...
A burner works only intermittently If one of your burner heating elements works only intermittently, it's probably because of worn or bad contacts in the receptacle that the element plugs into. On most electric ranges, you can remove the element by lifting it up several inches and firmly pulling it away from its attachment (receptacle). Read your owner's manual to learn the correct technique for your range. If, after removing the element, you see that the ends of the element that were plugged in are pitted, corroded, burned, scarred, or rusted, replace both the element and the receptacle.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Dec 09, 2009 | Microwave Ovens
Oven wont bake
The problem might be with a burned out receptacle that the element plugs into. If this is the case, replace both the element and the receptacle.
If the receptacle and element are OK, replace the main control board.
Jun 19, 2009 | Kenmore 92022 / 92024 / 92025 / 92029...
Large Heating Element no longer heats
Is it the eye itself or the receptacle? solution: yank out the questionable eye and put another from the stove in that one. swap em around and determine if the eye is bad or the receptacle. The receptacle are around 10 bucks.
9f0ea2e.jpgpart number 330031
Mar 02, 2009 | Kenmore 91112 / 91114 / 91117 Electric...
Sep 09, 2008 | Kenmore 95589 Electric Kitchen Range
Kenmore ultra bake cook top indicator light
is there multiple lights(one for each burner?) of so thers an issue with the sensor on the element and the element would need to be replaced, check your manual generally a loner possibly 5 year warr on elemnts
Apr 09, 2008 | Kenmore 92022 / 92024 / 92025 / 92029...
I have a Kenmore electric range oven Model # 79095201103 that has a glass top. The top cracked and I ordered a new glass top for it. What steps do I need to do to replace the top. Is it complicated???
Here ya go...
Apr 06, 2008 | Kitchen Ranges
Kenmore 95589 Electric Kitchen Range Logo
346 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
