Question about Dryers
DRYER ONLY WORKS IF YOU HOLD DOWN THE TIMER BUTTON. DOOR SWITCH IS WORKING PROPERLY. TORE THE ENTIRE THING APART AND REPLACED THE MOTOR, WHICH IS WHAT I WAS TOLD WAS WRONG. HOOKED IT BACK UP AND THE SAME THING IS STILL HAPPENING. CAN USE IT BY DUCT TAPING OR RUBBER BANDING THE SWITCH DOWN. Dryer shuts off after pressing timer/start knob. The dryer will spin and heat, but simply will not remain engaged after pressing the timer/start button. I've checked out the hi-limit T-stat, C-switch at motor, and motor itself. All appear to be ok. there are no electronics associated with this model. So my guess is the timer control. Am I right or is there a more economical solution? Thanks! DAN :<) (Roswell GA) BTW, this is a great tech site!
  • blindaim Dec 15, 2008
    Yeah... I thought as much. The timer/switch is kind of expensive. Any ideas on where I can locate a cheaper used one for my dryer (Maytag DE4000)? Really don't want to exceed $40 for the part.
My dryer cuts on sometimes just fine then other times you hold the switch downit turns over for a few seconds and it then wont run
Posted on Jan 26, 2009
  • jadezuni Jan 26, 2009
    my dryer cuts on sometimes and runs fine. However the switch sometimes will not turn over unless you hold it down, even then it cuts off after a few seconds?
  • Dryers Master
  • 19,396 Answers
You need to replace or repair the timer control, this is not a faulty motor control unit.
You find parts by entering model number here.
Posted on Dec 15, 2008
Dryer start button doesn't work
door switch or possibly the motor. if you hold the door switch in and push the start button have someone turn the drum by hand if it starts running it is the motor
Jul 04, 2010 | Frigidaire FEX831CS Top Load Stacked...
Kenmore gas dryer doesn't stay on
I think it is probally the thermocouple not holding letting gas valve work properly, timers do not go out very often, its not getting hot enough to release the gas, valve wont let it, chheck thermocouple, let me know im not there, but its in the heat not getting hot enough
Feb 25, 2010 | Kenmore Dryers
Kenmore Dryer (Model #11073952101) starts, but WON'T stay ON
your motor maybe going out. theres a switch on the motor that starts it . on most models the start switch is built into the motor. however some models the switch can be replaced by itself.
Aug 30, 2009 | Kenmore 73952 Gas Dryer
I have to hold the push to start button for the dryer to run
Ok you are really not that ignorant, all dryers shut off when you open the door and no holding down the button won't make it work.
Mar 20, 2009 | Kenmore 63942 Dryer
Dryer problem
with power disconnected
follow the wires from the start button, to a relay,
check the wires (both ends) of all leads to the relay and reconnect any that have fallen off. (crimp tighter if they have fallen)
Check door switch function and connection.
check timer connections
the relay start-button timer and door switch comprise a latching circuit, when the start button is pressed the relay is supposed to latch closed and supply current to heater and motor. if the latching circuit disconnects the relay does not latch closed, and only runs as long as the start button is pressed.
if nothing has disconnected one side of the relay has usually failed, and the connection is not being made to latch the circuit
replace relay
cd48320.jpg relay is shown at right, 2 switches connected by a dashed line.
Oct 12, 2008 | Kenmore 62602 Electric Dryer
Sharp R-1450 microwave
This is usually caused by either a bad door switch, a loose door switch mount, or occasionally a problem on the control panel.
On these, it's usually a broken tab on the upper switch holder.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
That sounds like what's happening when you hold the Start pad - maybe you're moving the frame and chassis enough to help it work.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
You can probably find exploded views and order parts by entering your model number here at the Sears parts site.
The best place to order Sharp parts is Tritronics.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
William E. Miller
Aug 19, 2008 | Microwave Ovens
Dryer won't run unless we hold the button
The start button starts the motor heater and energizes a relay that latches closed to keep the motor and heater running untill the timer switch or door switch cut the power to the relay and the relay opens.
The latching relay has failed or disconnected
if all the cables are attached to the relay
replace relay
not an expensive item, good for another 10years
Aug 08, 2008 | Kenmore 63942 Dryer
Check the main control board inside the control panel and/or the motor start relay (which should be a black module mounted somewhere near the control board. Usually when one of the two goes bad it will cause these very same symptoms. Hope this helps you.
Jun 16, 2007 | Whirlpool LGR8648 Gas Dryer
Dryers Logo
205 people viewed this question
Top Dryers Experts
