Question about Kitchen Ranges
Convert natural gas stove to LP
I have a Magic Chef stove, model #3448XTA, I need to convert it from natural gas to LP, how do I do this?
  • Anonymous Mar 19, 2014
    Why does the stove come from factory without propane hook up as it states in the manual
  • Kitchen Ranges Master
  • 8,220 Answers
Nothing is imposible but this stove was not made to be converted. It is a not a classic crank down and flip model. Your best bet would be to get your LP gas supplier to do it.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Dec 15, 2008
Gaffers and sattler stove
SOURCE:Whirlpool 465 Gas Stove conversion from propane to gas?
In most cases the orifices can be removed and reversed to convert from lp to natural gas. Sometimes you will need a conversion kit and you will need to look this up by model number. 465 is the oven capacity not the model number. You can locate the model number by pulling the drawer out and looking behind it. Please let me know the model and I can let you know what kit you need. Also I should let you know that your gas company is the most qualified to convert your range, and this conversion should not be attempted by anyone who is not qualified. If this conversion is not completed properly you could be risking your life and the lives of everyone in your home, so make sure you know what you are doing!! Or get a qualified person. Good luck and please be careful making any changes to your gas appliances. Please dont forget to rate me also.
Mike Anderson
Anderson Appliance
(865)945-3808
Natural gas to LP conversion of Gaffers Sattler stove
Feb 12, 2018 | Kitchen Ranges
Recently acquired an older Hot Point Cooking stove with self cleaning oven. Need to know if I can convert to propane and how to do so. There were no manuals with the stove..
Stove conversion natural gas to Lp - YouTube
? 6:08
https://www.youtube.com/watch?v=iXX2mS6FrxI
Sep 2, 2014 - Uploaded by Clay Rogers
If anyone can do it so can you. ... Stove conversion natural gas to Lp ... How to Convert Your Natrual Gas ...
Nov 15, 2015 | Kitchen Ranges
How do I convert a Jenn Air PRG 4810 from natural gas to lp?
Many gas stoves anymore have adjustable orifices. and they just need to be adjusted to propane .
Mar 09, 2015 | Jenn-Air PRG4810 (NP) Gas Kitchen Range
Convert from natural gas to lp
You can purchase an LP kit and install it on your burner
Nov 25, 2013 | Magic Chef CYG3004AWW Gas Dryer
Convert from gas to lp
This is going to result in you needing a different metering orifice on the gas valve. There are LPG kits to install this, but I highly recommend a professional to eat the liability on this one because LPG is heavier than Natural gas and if it's installed improperly, a leak will cause the gas to settle on the ground creating an explosion hazard.
We have a magic chef gas stove with sealed burners. were trying to change it over from natural gas to L.P. do we haveto have different orfaces?
Do you have your owner's manual? It will tell you how to convert it to propane and what size orifices to use with each burner. Not all the burners are the same size, so you will need this info in order to install the right size orifices. The data plate on the oven, which is usually behind the bottom pull out drawer, will tell you what the BTU rating is for each stovetop and oven/broiler burner. If you don't have the owner's manual, reply back with the exact model # you have (it's listed on the data plate too) and I'll look it up for you. You will need a small nut driver tool to change the orifices. As soon as you provide more info, I'll try to help you further. Douglas
May 28, 2010 | Magic Chef 31000 Gas Kitchen Range
Gas stove need to switch to propane
Hotpoint supplies the orifices and instructions with each range for converting. It is just that it is hidden, they attach it to the gas regulator. The regulator is near the bottom back typically. Here is a cut out from your use and care manual.
CONVERTING TO LP GAS (or converting
back to natural gas from LP)
This range leaves the factory set for use with natural
gas. If you want to convert to LP gas, the conversion
must be performed by a qualified LP gas installer.
The conversion instructions and LP orifices can be found
attached to the range next to the pressure regulator.
Keep these instructions and the orifices in case you want
to convert back to natural gas.
May 13, 2010 | Hotpoint RGB745 Gas Kitchen Range
Gas range burner flame too high and too yellow.
Did it work OK in that location before the changes?
Sounds like you used Natural gas parts instead of LP.
Lp orifices have smaller holes than Nat.
Mar 12, 2009 | Magic Chef CGR3742 Gas Kitchen Range
Convert from lp to natural gas
you need to change the gas regulator (if installed on back of oven),pilot and burner orfice your ready to go.happy new year.
Dec 05, 2007 | Magic Chef CGR3742 Gas Kitchen Range
Kitchen Ranges Logo
485 people viewed this question
Top Kitchen Ranges Experts
Craig Butler
Craig Butler
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
