Question about DeLonghi DCU72 Coffee Maker
DCU72 Urn-Glass tube broke-not available any more--what to do now
Glass coffee level indicator (TG007) is no longer available for purchase anywhere on line that I have checked or from the company. Is there any other fix available to me?
  • 2 more comments
  • dolgill Dec 30, 2008
    I also have a practically new DCU72 with a broken glass tube. I think that it is totally irresponsible on the part of the company not to make this available. I certainly will not purchase this brand again, and our church keeps 4-6 urns working at any time.
  • Anonymous Jan 17, 2009
    I have the DCU62 coffee urn. Same problem. I see the replacement part listed but it is no longer avaliable.
  • elwood1972 Apr 30, 2009
    The tube on one of the urns at church broke on Sunday. Gonna try the 1/2 inch rubber stopper bit, but I hope it does not effect the taste.
  • Mike Uro Jul 10, 2013
    United Silica Products in New Jersey made a replacement tube for my urn. I received it 2 days after I called and placed the order. Fits Perfectly!
I had the same (sight glass tube replacement) problem, but DeLongi gave me the number of a parts supplier that has them available.  Call 1-800-436-5415.
Posted on May 18, 2009
  • 1 more comment
  • Gregg Jun 18, 2012
    This number is an advertisement for talklive.com.
  • crames1 Apr 16, 2013
    Don't call this number.
  • Helen Gesell Jun 03, 2013
    Do NOT call this number... not correct.
Best solution that I have found is to go to your local hardware store and get a 1/2 inch top rubber stopper to plug the hole. Unscrew the housing on the spout where the tube would fit. Feed the small end of the stopper through it until it is snug. Then screw the housing back onto the spout assembly. You should get a good watertight seal with the stopper.
You won't be able to see your water level, but you will at least still be able to use your machine without it leaking all over.
Posted on Jan 23, 2009
Not only did I break the level indicator on a borrowed coffee pot, DeLonghi DCU72, but I had borrowed it from my daughter. Ouch! 'Nuff said about that! After going crazy trying to find a replacement and having no luck at all, I contacted United Silica -- they're on the web -- and they manufactured one to my specifications!! It's a perfect fit, and I couldn't be happier! The coffee pot works just like new and DOES NOT leak!! It cost $10 for one tube (I bought two so as to be "prepared"), plus $15 shipping -- but much cheaper than a new coffee pot!! If you go this route, contact John in Customer Service, and tell him you need the same indicator level tube that Susan and Doug ordered. John made a drawing of what we described to him, then fine-tuned it after we reviewed and commented, then had the part manufactured and shipped to us within a couple of days. They were great folks to work with. Remember! United Silica!!! www,unitedsilica.conm, or quartzsales@unitedsilica.com, or 973-209-8854.
Posted on Jun 04, 2012
    I did this. too. Our church's tube broke. When calling John, he said over they have had over fifty orders for these tubes. Thank you, Susan, for this awesome solution.
    Thankfully we had two other coffee pots of the same model. Each tube can vary slightly for the lengths, but they all have the same diameter. No markings on the tube, but I am just thankful that we have a working coffee pot again :)
  • 3 Answers
I have a DCU72 which had a chipped tube (TG007) which seems discontinued.
I purchased a TG039 from www.thegourmetdepotco.com, and this seems a usable replacement.
The only caveats are that the tube is slightly shorter (7 inches) than the previous one,
so I cannot fill the pot to the 60 cup capacity (keep at about 50-55 cups or less).
The other option I did not try is to just not have a coffee level tube, and block the hold in the spigot
with a plastic disk the same diameter as the original tube.
Posted on Jan 24, 2009
  • dbotti Jan 25, 2009
    I purchased a TG039 from www.thegourmetdepotco.com, and this is a usable replacement for the TG007.
    The only caveats are that the tube is slightly shorter (7 inches vs 8 inches) than the previous one.
    The web site does not seem to find TG039 in a search,
    you need to navigate Delonghi > Coffee Urn > View All (parts) >Glass Tube Assembly
  • BJM1947 Nov 22, 2010
    The glass tube for these coffee makers is .393 or 10mm. I contacted a glass blowers supply and purchased a piece of tube and then the guy that supplied the tube flattened one end so the nut could be tightened to seal the lower end of the tube. Only thing missing is the markings that say how many cups are left.
Solution #4 may work. I just called them (1-800-436-5415) and they are shipping a replacement glass tube assembly today. The fellow told me that it is slightly different than the original but comes with instructions on how to make it work. If you don't see a follow-up comment assume that it worked.
BTW, re: solution #3, they told me that the part was discontinued about 6 months ago (Jan 2010 I guess)
Posted on Jun 15, 2010
I found this glass tube kit that says it fits DCU72
http://www.nelsonappliance.com/Delonghi+Coffee+Urn+Sight+Glass+Kits+%23TG007.html
Posted on Jan 07, 2010
I need the glass tube that goes to my delonghi 60 cup coffee maker
Nov 29, 2017 | DeLonghi Coffee Makers & Espresso Machines
Where can I locate Coffee Urn replacementThermostat?
Abtec seems to be the only place.
Search Results
DeLonghi DCU72 Coffee Urn Parts - eReplacement Parts
https://www.ereplacementparts.com/delonghi-dcu72-coffee-urn-parts-c-122345_1223... Need to fix your DCU72 Coffee Urn? We have parts, diagrams, accessories and repair advice to make your tool repairs easy.
Amazon.com ' Delonghi DCU72 Ultimate Coffee Urn: Coffee Urns
https://amazon.com/Delonghi-DCU72-Ultimate-Coffee-Urn/dp/B00064XTDK Enter your model number to make sure this fits. 20-60 Cup Capacity; Keep Warm Function - Once it's finished brewing it automatically switches to the warming cycle and keeps your coffee at the perfect temperature. Freshness Indicator is activated by the keep warm function and tells you how long the coffee has been ...
Delonghi coffee urns - Abtec Parts
abtecparts.com/Delonghi_coffee_urns.htm Large glass knob with nut for lid holes measuring 1.1/2 to 2.1/2 inches. ... Glass knob for models DCU50T, DCU60, DCU60T, DCU61, DCU62, DCU62B, DCU70, DCU70T, DCU72 manufactured before 2001. ... Glass knob (fits 2 inch diameter hole) for models DCU50T, DCU60, DCU60T, DCU61, DCU62, DCU62B ...
delonghi model dcu72 coffee urn thermostat Google Search
Mar 06, 2018 | Coffee Makers & Espresso Machines
I need to purchase an instruction manual for Delonghi model DCU72, Where can I get one and how much?
There is a manual for the DCU500T / DCU600& / DCU720 Stainless Steel Coffee Urn available here:
http://www.delonghicanada.com/downloadpdf.php?nid=59
Hoefully these are similar to your model and will save you from purchasing.
Feb 06, 2011 | DeLonghi Ultimate Coffee Urn
I broke the pump tube for my Farberware Urn #155-A, 55 Cup. Does anyone have one?
New tubes are available from Goodman's, 10914 NW 33rd Suite 107, Miami, FL 33172. Tele: 305 278 8822. If you broke just the ceramic outer tube, it will still work alright. The purpose of that cermaic tube was to prevent the hot water being perked up the stem from heating the other water that hasn't been perked yet.....
Jan 17, 2010 | Faberware 12-55 Cup Coffee Urn
Looking for glass tube for delonghi 60 cup coffee urn and glass button top, i believe the model is dcu60t
Here is a number you can try, to obtain a replacement part:
Contact Center
1-877-882-8604 Monday – Friday
8am – 8pm EST
Hope this helps... Good luck!
Sep 22, 2009 | DeLonghi DCU60T Coffee Maker
Need pump tube for 55 cup farberware coffee urn.
Hi. Go to repairshack.con. Good luck. bobbyone
Sep 10, 2009 | Faberware 12-55 Cup Coffee Urn
Farberware Coffee Urn won't make coffee
Be sure that the washer at the bottom of the pump stem remains loose.
If coffee grounds lodge in this area, remove under running water or with
a wooden tooth pick. Dan
Dec 27, 2008 | Faberware 10-22 Cup Coffee Urn
Broken cover with glass top
I had the same problem. Out of frustration I purchased the DeLonghi 1.5 inch glass knob top and nut and it worked perfectly. For less than $10, my coffee urn has a second life.
Nov 16, 2008 | Salton Coffee Makers & Espresso Machines
Faberware Coffee Urn 55 cup
I was able to buy a spigot for my Farberware Coffee Urn FSU236 from Mxim/Toastmaster in Macon, MO PHONE: 1-800-233-9054
Jul 25, 2008 | Faberware 12-55 Cup Coffee Urn
DeLonghi DCU72 Coffee Maker Logo
5,373 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Steve Allison
Steve Allison
Marvin
Marvin
Paul Bade
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
