Question about Lexmark X6170 All-In-One InkJet Printer
Hardware error 0502
What is going on? I put the new ink cartridges in and when it goes to realign it says hardware error 0502 and stops..............
  • Anonymous Dec 26, 2008
    continue with the same problem
    Genius:
  • 2,035 Answers
The encoder strip may have gone out of range of the sensor, or it might be dirty.
  1. Switch off the printer using the power button.
  2. Disconnect the power cable from the back of the Lexmark X5100/X6100 Series.
  3. Leave the power cable disconnected for 30 seconds.
  4. Slide the cartridge carrier to the middle of the printer by taking the top part of the belt and moving it gently to the right.
  5. Take out both cartridges.
  6. Place an index finger on the encoder strip on either side of the cartridge carrier.
  7. On the back of the cartridge carrier, there is a small slot that the encoder strip fits into. Slightly push the encoder strip down and then back up to get it into the slot.
  8. Lightly press the strip first to the rear and then forward, if necessary.
  9. Clean the encoder strip with a dry tissue. Also clean the contacts of the printer.
  10. Reconnect the power cable and switch the printer on again.
  11. Try to print....
Good luck...
Posted on Dec 15, 2008
Printer won't print--error 0502. What is this and how do I fix?
After months of use, your printer might get the habit of stopping in the middle of a page and showing "Hardware Error 0502" on the LCD display. If you leave the printer alone for a while, it might start printing again. Then again, it might not. Pretty annoying.
The Lexmark support site will let you power off, remove the power cord for 30 seconds, take out the cartridges and fiddle with some encoder strip. This whole procedure might take you up to 30 minutes and it will not help (been there, done that).
On the multi function machine seems to be a coating on the metal rod that the cartridges travel on. Just wipe this rod with a kleenex and the problem seems to go away. Somehow it presents a drag on the cartridges and causes an error.
Clean that with a paper towel. The towel will be black from the ink residue, but you will be able to print again.
Feb 09, 2011 | Lexmark X5150 All-In-One InkJet Printer
What does "Hardware Error 0502" mean?
The shaft that the ink cartridges travel back and forth on get buildup on it. If you clean it, your problem should go away...
Your answer and fix is here:
http://blog.forret.com/2006/02/lexmark-printers-with-hardware-error-0502/
Jan 21, 2011 | Lexmark X6150 All-In-One InkJet Printer
Receiving message Error 0502
hello
this should help
Lexmark printers with "Hardware Error 0502? Published on February 11, 2006 in hardware. 252 Comments Tags: 0502, error, fix, hardware, lexmark, printer. Good tip for the Lexmark All-in-one inkjet printer owners (mine is the X6170):
98393867_e286ea59ca_t.jpgAfter some months of use, your printer might get the habit of stopping in the middle of a page and showing "Hardware Error 0502" on the LCD display. If you leave the printer alone for a while, it might start printing again. Then again, it might not. Pretty annoying.
The Lexmark support site will let you power off, remove the power cord for 30 seconds (!!), take out the cartridges and fiddle with some encoder strip. This whole procedure might take you up to 30 minutes and it will not help (been there, done that).
The real answer is given by a person called 'clem':
98393885_c4f82c99a9_m.jpgHardware Error: 0502.
Clem
(from fixyourownprinter.com)
This works! Clean the ****** with a paper towel (another page talks about re-lubricating the thing, but that was not necessary in my case). The towel will be black (ink residu, presumably), but there you go printing to your heart's desire again
Nov 30, 2010 | Office Equipment & Supplies
Lexmark x6170 Error 0502?
After some months of use, your printer might get the habit of stopping in the middle of a page and showing “Hardware Error 0502” on the LCD display. If you leave the printer alone for a while, it might start printing again. Then again, it might not. Pretty annoying. The Lexmark support site will let you power off, remove the power cord for 30 seconds (!!), take out the cartridges and fiddle with some encoder strip. This whole procedure might take you up to 30 minutes and it will not help (been there, done that).
The real answer is given by a person called ‘clem’:
Clem
This works! Clean the ****** with a paper towel (another page talks about re-lubricating the thing, but that was not necessary in my case). The towel will be black (ink residu, presumably), but there you go printing to your heart’s desire again.
Feb 13, 2010 | Lexmark X6170 All-In-One InkJet Printer
What is a hardware error 0502
98393867_e286ea59ca_t.jpgAfter some months of use, your printer might get the habit of stopping in the middle of a page and showing “Hardware Error 0502” on the LCD display. If you leave the printer alone for a while, it might start printing again. Then again, it might not. Pretty annoying.
Clem
Jan 26, 2010 | Lexmark X5150 All-In-One InkJet Printer
Hardware erro 0502
Hi there
On the multi function machine seems to be a coating on the metal rod that the cartridges travel on. Just wipe this rod with a Kleenex and the problem seems to go away.
Myself I would put a little bit of oil after on a cloth and wipe along the bar.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Jan 04, 2010 | Dell A940 All-In-One InkJet Printer
Printing error says: Hardware error 0502 (?)
he real answer is given by a person called ‘clem’: 98393885_c4f82c99a9_m.jpgHardware Error: 0502.
Clem
Jul 12, 2009 | Lexmark X5150 All-In-One InkJet Printer
Lexmark X6170 printer shows hardware error 0502 when printing
On the multi function machine there seems to be a coating on the metal rod that the cartridges travel on. Just wipe this rod with a kleenex and the problem seems to go away. Somehow it presents a drag on the cartridges and causes an error.
You may have to do this from time to time if the error keep reoccurring.
Mar 22, 2009 | Lexmark X6170 All-In-One InkJet Printer
Error 0502
hi!!!
try to remove the cartridge of your printer
and put back on!! properly!!
may be your printer cartridge
not in ilignement!!!
Sep 21, 2008 | Dell A940 All-In-One InkJet Printer
Lexmark X6170 All-In-One InkJet Printer Logo
130 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
