I have an older Kenmore washer, model # 4225090 serial # cc4716815 it won't agitate or spin... it does drain the water though, I don't know whats wrong with it. can you help me?
  • witteveen_ni Dec 29, 2008
    My whirlpool washer fills up with water but wont agitate, spin or spin... I have water in the tub I can't get rid of... HELP
2 Suggested Answers
  • 113 Answers
SOURCE: kenmore won't agitate
the model# starts with 110. Sounds like you have a broken motor coupler. Its part 13 on diagram. part #285753
Posted on Dec 16, 2008
Tip
Washing Machines will not rinse or spin
If the water won't drain out of your washing machine, either something is stuck in the drain hose or pump, or the pump is broken. Both fixes are simple if you're even just a little bit handy with tools. We're showing the repair on a Maytag washing machine.
What is wrong with a washer that does not spin?
If your washer fills with water but doesn't agitate, the problem is likely to be a faulty lid switch, a broken belt, or a problem with the motor. (Note: Direct-drivewashing machines do not have belts.) To diagnose the problem, do the following: 1Check the washing machine's spin cycle.
How to Drain Washing Machine That Won Drain Family Handyman
Washer Doesnt Agitate or Spin
Error codes in front load washers
Washing Machine Not Rinsing How To Fix
My washing machine stops at Rinse Does not DRAIN or SPIN
What causes a washing machine not to drain and spin?
If the washer won't drain there might be a clogged pump or hose. It's common for small socks or other small clothing items to get into the water drain system and clog the hose leading to the pump or the pump itself. Remove the hoses from the pump in order to remove the article of clothing.
SOLVED Why won my washer spin or drain Kenmore 110 Series Washing Machine
Maytag Washing Machines will not rinse or spin Google Search
on Dec 12, 2017 | Washing Machines
Kenmore washer Model 110, Serial No. 27602690 won't spin
If wash cycle operates and water drains as should before spin indicates motor spinning. Chances are bad timer If your a real fixer you can remove timer control from panel check and clean all contacts internally making sure none are stuck closed . (Have had 3 110s in my time).not easy but can be done or buy new about 150$ reassemble and check operation.
Mar 28, 2013 | GE WBSR3140DW Top Load Washer
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE please show me a diagram
Jun 14, 2011 | Whirlpool LSR7333 Top Load Washer
Agitator just stop working. Spin cycle will run. Rinse will drain the water, add new water, but the Agitator will not work. Do you have any ideas? Do you know how old the machine is?
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump
removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
This problem points to a couple of places:
The first unfortunately is the motor. Kenmore / Whirlpool top load direct drive washers use a reversing motor.
When in agitate mode, the motor turn one way, When in spin mode it turns the other way for draining and spinning.
I'd check the following first before assuming that it's the motor though.
First, I'd pull the agitators and check for worn or damaged splines inside the agitator or on the agitator shaft.
Following is a description of how to take them out.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
If the agitator and shaft are OK, the problem may be in the transmission.
See the following Whirlpool / Kenmore installation and service manual for top load, direct drive washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/
$FILE/L-55.pdf
I'd also look at the troubleshooting section of the manual.
Starting at page 10, you'll see a description of how the transmission changes from agitate to spin mode.
The key (and likely problem) is the "agitator spring".
The spring holds the agitate gear down so that the two sets of splines on the agitate gear are connected and the agitate rack
can turn the agitators.
See the following Whirlpool parts list for a blow-up of the transmission and how the various gears and springs connect.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
See the following for how to remove the transmission and clutch.
Tearing apart the transmission is a bit messy but if the problem is the spring or agitate cams, it's a lot less expensive to
fix than a $170 transmission.
Remove the clutch (the spring holding the clutch to the spin pinion is a bear to replace.
Remove the 8 transmission screws carefully, the transmission is full (15 oz.) of 80-90 weight oil.
Remove the transmission cover and drain the oil.
Pull off the spin pinion.
Carefully remove the clip that holds the main Spin Gear on and remove it.
Push down on the agitate spring and remove the spring clip. Note where is attaches to the main shaft.
Check the spring, Agitate Cams and the cams in the Neutral Drain Assembly.
Re-assembly is obviously the reverse of taking it apart.
If you're reasonably comfortable with tools you can fix it yourself.
When we had a problem with ours, we ended up spending less than $30 replacing the agitate cams, neutral drain assembly and oil instead of $170 for a transmission. It was worth fixing.
As an aside, tearing the washer apart will give you the opportunity to completely clean it..
As to the age of the washer. Whirlpool / Kenmore washers use a part of the serial number to determine the year the washer was made..
Jan 11, 2010 | Kenmore 23822 Top Load Washer
Kenmore washer 80 series 110 model not spinning.
unless your washer is over 20 years old, then it wont have a belt. the temperature of the water wont have anything to do with it spinning or not.
need to know if it agitates or drains and just wont spin.
if it agitates but no spin or drain, then you have a bad lid switch.
if it wont agitate or spin, but will drain, then you have a broken drive coupling.
Jan 08, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore won't agitate
Dec 15, 2008 | Kenmore 44102 Front Load Washer
Kenmore Washer Won't Drain
yes, check the drain, could be clogged, or check the water pump assembly as well, the clothe could be stuck in the impeller.
the burning smell could be coming from a separate electric water pump and it can not turn that is why it is burning already.
tnx 4 using fixya,
drcool
Oct 07, 2008 | Washing Machines
Washing Machines Logo
46 people viewed this question
Top Washing Machines Experts
