Question about Dell Dimension 5150 (DIM515MIN) PC Desktop
Installing a second internal hard drive
Hi My main hard drive is a Western Digital WD800JD the second drive i have installed is a Western Digital WD2500JS both are Sata,i was told these are compatible. The problem is as follows it is reconised in the bios setup and in Device manager it states this device is working but when i right click on my computer and select open the only hard drive shown is C drive,the second drive is not shown. Help! Cheers R.T.Holmes
Right click on my computer>manage, then a window will pop up, look down the list on left for disk management. In here you have to activate the drive (i think you right click the square where the red X is). Then make it a primary partition. At this point it should show up in 'My Computer'. Then you need to format before use.
If its a new drive do a full format not a partial or quick, to check for bad sectors. If find any. take the drive back to the shop.
Posted on Jan 16, 2009
  • 385 Answers
Yes, I agree with Sandrew. When you boot up the computer you should right click My Computer and then select manage. In the next window, go to disk management. For some computers, a disk initialization wizard will pop up asking to initialize it and then format it. Or you might see a drive with a red x or it might show as unallocated. Either way, it should be formatted. After the format, you will be able to use it in my computer.
Posted on Mar 19, 2007
    President:
  • 2,961 Answers
Windows may need recognise it through it's system, right click on my computer>manage, then a window will pop up. Look down the list on left for disk management; on the right bottom of window, you should see your drive there but it will need to be formatted. Highlight your disk,right click and select format. The drive should then show in my computer
Posted on Mar 18, 2007
Wdc wd800jd-75msa3 not reading disks
A Western Digital WD800JD-75MSA3 is a 80GB hard drive.
The usual cause of read failures of a DVD ROM is dirt in the device.
Try a cleaner disk.
Jan 21, 2014 | Western Digital WD800JD-75MSA3
Installing used WD800JD into external disk enclosure
The case must be designed for SATA drives. Once the drive is installed in the case, use a USB cable to connect it to the computer. Connect the power supply to the case and start the computer. There will be a new drive letter present.
Nov 25, 2012 | Western Digital Caviar SE WD800JD SATA...
I have a WD800JD hard drive which was on my old computer in which I want to recover data to my new computer. I have installed it in the computer with the one ribbon (only one available). The master has...
Hello Joe,
Please visit the link provided below :
http://wdc.custhelp.com/app/answers/detail/a_id/981/p/288,95/c/123/session/L3RpbWUvMTMxMzU4ODkxOS9zaWQvN1JOSzdNQms%3D
Aug 17, 2011 | Western Digital Caviar SE WD800JD SATA...
How to slave a wd800jd caviar se sata hard disk
Just install it. No jumpers are needed on a SATA drive.
Jan 01, 2011 | Western Digital Caviar SE WD800JD SATA...
Just installed a new hard drive in a Dell Percision do I need jumper settings for the second drive
depends entirely how they are connected. you have posted this under SATA har drive, sata hard drives do not require any kind of jumpers.
Dec 06, 2010 | Western Digital Caviar SE WD800JD SATA...
I bought a Dell Optiplex 745 with no hard drive. I bought a second hand WD800JD SATA hard drive with no CD's and installed it. The computer does not recognize it so I cannot load an OS. Can you help?
make sure that the leads are in there correct slots
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your motherboard to your hard drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
hope this helps
Dec 04, 2010 | Western Digital Caviar SE WD800JD SATA...
Western Digital Caviar SE WD800JD SATA Hard Drive Boot: Couldn't find NTLDR could this be bad drive installed xp a couple times now works ok but when i shut it off Couldn't find NTLDR comes up
Yes it looks like a Hard drive problem.
This error means that NTLDR is missing somehow from your computer,hard disk problem usually or virus.
You can go to that page and follow the instructions exactly as he says and will not have to install windows over and over again
http://www.tinyempire.com/notes/ntldrismissing.htm
Jan 02, 2010 | Western Digital Caviar SE WD800JD SATA...
What to delete from C:\ drive?
the operating system has to stay on the main drive. it gets all its commands from the main drive and puts it into RAM. it sees your external drive as a slave.
Dec 11, 2007 | Western Digital Caviar SE WD800JD SATA...
Dell Dimension 5150 (DIM515MIN) PC Desktop Logo
179 people viewed this question
Clive
Clive
Alun Cox
