Dear sir/Madam i have a PC 800mhzVIA , 256DDR2, 40GB, PC model is TC700 and its PS2 keyboard ,Mouse are nor working due to some hardware designing .Help me in this matter thanks
  • 449 Answers
The best solution is to get USB mouse since PS2 muuse is not working. and if you cloned the system yourself i suggest you take a look at the motherboar and youy will see a jumper labelled on the board PS2 keyboard and Mouse, place the jumper in the next pin. and try and see if it will work.
Posted on Dec 15, 2008
My tower takes for ever to load and it wont read my mouse or my keyboard so my keyboard doesnt work please give me some help
Loading problems are usually due to a hard drive that is almost full, leaving windows with no "swap file" (or virtual ram). It can also be down to a very badly fragmented hard drive.
The mouse and keyboard problem ( I;m assuming you are using a Ps2 mouse and keyboard) point to a failed connector on the back panel. Try using a USB mouse and keyboard, (if you are using one already and this model supports ps2, try the other way)
If the USB ports on the computer do not work, to use a keyboard or mouse, then the problem is more serious and you may have a damaged motherboard
Jun 19, 2011 | E-Machines T2682 (000002965) PC Desktop
My mouse and keyboard won't work...after i restart it several times,then it works,,,it will wake up out of standby or start up,but the mouse won't move,sometimes when the mouse does move the keyboard won't...
i assumed that you use device PS2 (Mouse & Keyboard), this rarely situation, but you haved installed and not more better, because the problem not with your system, but with your hardware, maybe you can change with USB Mouse Device and for Keyboard PS2 is better than USB Keyboard.
Mar 01, 2011 | HP Pavilion Media Center TV M8200n Desktop...
Wireless mouse and keyborad will not work. replaces batteries and hit reset button on mouse and keyboard. can not get access to computer
Sounds like your USB circuit may have gotten fried due to a static discharge (assuming your keyboard and mouse are USB). You can purchase an "add-on" USB pci card or a PS2 Mouse and Keyboard.
Feb 01, 2010 | Dell XPS 400 PC Desktop
Ps2 on acer x1700 don't work
connect both the mouse &keyboard restart the machine.if then also it not works then there must be some hardware problem&your desktop does not support.try the usb mouse&keyboard.
Mar 08, 2009 | Acer Aspire™ T180 PC Desktop
PS 2 port problem
What is the model number of your motherboard? VIA does not make Processor's/CPU's.
VIA makes chipset's for motherboards.
In order to answer your question I'll need the manual for the motherboard. No manual listed here: http://www.via.com.tw/en/products/mainboards/others/p4xb_m.jsp
Here is a picture of the VIA P4XB-M motherboard. This model can not use DDR2 memory. (Only, 184pin PC2100 DDR266 DIMM)
Found here: http://www.upgradecomputermemory.com/ram.cfm//memory/V/VIA-Technologies/P4XB-M-Motherboard/256MB-VIA-Technologies-Desktop-184pin-PC2100-DDR266-DIMM.html
VIA P4XB-M
http://www.via.com.tw/download/mainboards/4/11/P4XB-M.pdf
99.0% of motherboards still use PS2 ports. One colored purple for the PS2 keyboard female port, back side of the MB & the other colored light green, female port, back side of the MB PS2 mouse port. By default, most motherboards have the jumper for PS2 keyboard enabled. Location for this two-pin jumper varies from board to board.
A USB port looks like this:
http://www.rickysays.com/images/usb-port.jpg
The PS2 port's are found in the upper left hand corner of this same picture. This next link will show how to connect USB motherboard jumpers including their wire locations. (Standard for most motherboard USB connections).
Mike
Dec 15, 2008 | VIA P4XB-M Motherboard
PS KB .MOUSE PROBLRM
that means you didnot clone the system yourself and it will be difficult for you to fix it. so get USB mouse and keyboard. thats the only solution for now unless you can talk it to a qualified repairer in your area.
Dec 15, 2008 | Computers & Internet
ACER 5315-2326
Disconnect it and connect again.
Oct 27, 2008 | Acer Aspire 5315 Notebook
Mouse trouble
start (button) select control panel / system / hardware / device manager / mice & pointing device / double click, select wheel mouse (or whatever mouse you have) right mouse click, properties, select use this device (enable) - But I'm surprised you are having trouble with it.. Have you changed anything recently? Have you always used a ps2 mouse? Try connecting the mouse & re-booting the pc.. Also make sure it's plugged into the correct port, not the ps2 keyboard port.. Especially checkif you are using a usb keyboard.. Rgds
Jun 08, 2008 | Compaq Presario 5000 PC Desktop
Computers & Internet Logo
344 people viewed this question
Alun Cox
k24674
