Question about Smeg Ovens
SMEG DO4SS-5 double oven not heating up
The main (bottom) oven in my SMEG DO4SS-5 double oven isn't heating up though both the light and fan come on.
It'll be related to my wife saying that the oven ring main circuit tripped after a 'noise' from the oven so I'm thinking that there might be a fuse or trip switch somewhere inside it. Or else the element blew which isn't great for a 3 year old oven.
The top oven works normally - but I won't be able to get much of a turkey in it!
  • ColdSmeg Dec 15, 2008
    Forgot to say - I've already experienced the annoying 'set to auto cooking' mode problem which stops the bottom oven heating up. This isn't the problem. Thanks.
  • Anonymous Jan 10, 2009
    The main oven on my smeg double oven isn't working. Nor is the clock - totally dark. Other oven is fine.
  • Smeg Master
  • 3,463 Answers
If the fan is running, then it is safe to say that the oven element has gone.
Replace with a new one,(element that is).,
Plz rate this solution.
Thanks.
Posted on Dec 15, 2008
  • Smeg Master
  • 744 Answers
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  2. If you're Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped like us on facebook please
How to Video Tutorials on Domestic Appliances
Posted on Mar 05, 2014
Why is my oven not heating up?
Call an electrician. Sounds like a thermal cut out or a bad element.
Jul 17, 2014 | Smeg Ovens
Smeg SD012 top oven failed
Is the clock set to auto and not manual? Is the clock display flashing? If so then set to manual, this should do the trick
Jan 17, 2014 | Smeg Ovens
Smeg FU65-5 Oven temperature & timer & function knob lights not turning on and oven does not heat up but the fan comes on.
  2. If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Dec 02, 2012 | Smeg 24 in 60 cm Stainless Steel Electric...
SMEG DUCO4SS double oven electronic timer the bottom (main) oven does not work no light comes on and no heat but the fan does come on i have sitched the power off waited and then reset the clock
Apr 07, 2011 | Smeg DO81CSS Electric Double Oven
We have Smeg DUCO8CSS double electric oven. Bottom oven does not work, clock is blank and fan doesn't work. Top oven OK ! - though usually the fan runs when this is operating.
If the clock is blank, then the main oven will not work, as the clock timer is linked with the main oven.
You need to to get the clock working, or you will not be able to use the main oven
Jan 19, 2010 | Smeg DO81CSS Electric Double Oven
Smeg Oven
Their will be two elements in the oven a bottom element and a fan element, sounds like the latter has blown!
Oct 09, 2009 | Smeg SE250XUK Stainless Steel Electric...
Fitting Base Element for SMEG DO4SS-5
Some fan assisited ovens do have a base element, some do not.
If there is no heat at all in the oven , then it is safe to say that the fan element has gone, replace that first, if it does not reach correct operating temp, then it probably has a base element as well that needs to be replaced, this would mean removing outer oven panels to access it.
Plz rate my soution.
Thanks.
Jan 17, 2009 | Ovens
Smeg oven
Dec 08, 2008 | Smeg SE399X/5 Stainless Steel Electric...
I have a Smeg oven SA708, but all of the symbols on the front of the oven (functions / temperatures) have been wiped off by a previous tennant. Just after a picture or diagram of the front of the oven...
I have a Smeg Double Oven DO4SS-5 that I need to remove the control panel on
it. I've removed the 2 bottom screws but is still reluctant to come off. Help please
Apr 13, 2008 | Smeg S1100MFX5 Electric Single Oven
Ovens Logo
1,473 people viewed this question
Top Smeg Ovens Experts
Hjalmer Lamminen
Hjalmer Lamminen
Are you a Smeg Oven Expert? Answer questions, earn points and help others
