Question about HP LaserJet 4 plus Printer
Print coming out gray even with brand new HP cartridge
I have Laserjet 4L, (black and White) which has operated well for number of years, since the print was coming out almost gray, instead of black, I changed to brand new HP Laserjet cartride (92274A), but still get the same gray print.
Please help
  • garthgraves Jan 26, 2009
    Same problem with a new cartridge which I probably didn't need. Self Test ... click recycle button twice produces a good black image but printing from a scanner or wp file produces faded gray images. Any tips?
    Sergeant:
    Novelist:
  • 327 Answers
Either it could be set in the printer properties to print in gray scale or it could be the lens of the printer that needs replacement as if the lens go weak the prints come out very light.
Posted on Dec 15, 2008
HP LaserJet 2600N All colors are empty, but Black is brand new. It still says Replace Supplies and the light keeps flashing. Oh, and it won't print anything. So even if I want just B&W, do...
None of the cartridges can be empty if you want to print.
Even if you only want to print black, just black you need to
replace the other three cartridges.
Yes color laser printing is expensive.
Jul 14, 2011 | HP Color LaserJet 2600n Printer
I JUST NEED ORDER NUMBERS FOR ALL THE COLOR LASERJET CARTRIDGES FOR CP4525 PLS. THANKS,
You can find the user's guide here which lists all the parts and supplies. Here's the cartridge information from the manual:
  • HP Color LaserJet black print cartridge Standard black cartridge CE260A
  • HP Color LaserJet black print cartridge High-capacity black cartridge for CLJ4525 models only CE260X
  • HP Color LaserJet cyan print cartridge Cyan cartridge CE261A
  • HP Color LaserJet yellow print cartridge Yellow cartridge CE262A
  • HP Color LaserJet magenta print cartridge Magenta cartridge CE263A
You can use the HP numbers to look for original or after-market replacements.
Apr 29, 2011 | Office Equipment & Supplies
Using an HP LJ1320 printer. When I print my page comes out with a faint gray look to it (not white). When I duplex the gray intensifies. I thought my toner cartridge was leaking toner so I replaced the...
Your Print density could be set too high.
Try to Decrease the amount of Density through the device configuration utility.
You Must have teh HP Toolbox installed to change printer settings
Feb 15, 2011 | HP LaserJet 1320 Printer
Is there any way to disable the color cartridge in my HP 930c? I want to print only in black.
Under your printer preferences there is a way to print gray scale. SO even if your image is in color, it will print black and white. Every printer interface is different, but when you go to print, there's usually a properties or setting button that will bring you to another page from the initial print menu. here is where you would choose gray scale.
If you try for black with only a color cartridge, it'll come out a dark green or blue color. Or on some cases, it will tell you it's out of black and you can't print. Most HP printers need at both cartridges in the printer for it to print.
Jan 18, 2011 | HP DeskJet 930c InkJet Printer
My HP LaserJet 4L printer just makes a grinding sound-won't print
That printer has a gear on the motor that cracks. You can fix it with a new or used motor. Or get a different machine on craigslist. Thank you, Steven 805-520-3003
Jul 26, 2010 | HP LaserJet 4L Printer
HP Laserjet 4L just started printing black pages. After a few pages they print are normally. It all starts again when I begin another print job after some time passes after the last job. Put a new...
The image drum is not getting the correct signal at the correct time. It is time to retire the 4L and replace it with a newer, faster LaserJet. You'll be glad you did.
Nov 19, 2009 | HP LaserJet 4L Printer
Hp color laserjet 2600 n it will not let me print
There is an override sequence and it works well. Press the select button (checkmark) to indicate Main menu. Press right-arrow (RA) to select System Setup. Press Select , then RA to Print Quality, Hit select. RA to Replace supplies and hit Select. Now, RA to Override Out and Select. Confirm with Select again. Your 2600n will now run even with an empty toner cartridge.
Jul 08, 2009 | HP Color LaserJet 2600n Printer
Gray background only on odd number pages
your cartridge is defective.. just replaced a new one.
May 17, 2009 | HP LaserJet 1020 Printer
Old LaserJet 4L working perfectly. Just bought new generic toner cartridge and now getting shading over entire page, turning paper an almost-even gray, darkest at left edge. I'm suspecting cheap cartridge...
You're right about the cartridge and I suppose cleaning it means all the toner that the generic cartridge dumped. Turn off the machine, take out the cartridge and use a vacuum cleaner and a soft brush to get that extra toner out. After that use a soft cloth (not terry) to wipe down the inside.
Apr 06, 2009 | HP LaserJet 4L Printer
HP LaserJet 4 plus Printer Logo
476 people viewed this question
Clive
Clive
