Question about Kenmore 15864/15862 Top Load Washer
SERIES 90 WASHER
NOISE DURING RINSE CYCLE WILL NOT SPIN IN EITHER RINSE OR SPIN CYCLE
  • 1 more comment
  • Anonymous Dec 22, 2008
    my kenmore stoped in the middle of a cycle theni noticed a smell i was wondering if they have over heating switch?
  • hyrump Dec 22, 2008
    does the Washer Kenmore 90 Series Lint catcher
    The lint is stopping up my plumbing
  • onthethejob1
    onthethejob1 May 11, 2010
    a little help...wash and rinse are the same only in 1 you add detergent..are we dealing with noise or no spin,,????
    Novelist:
  • 101 Answers
Easy fix. This is a direct drive washer. What happened is the part between the motor and the transmission broke. It's a cheap and easy fix. If you unplug the machine and tip back the washer you will see the motor. Disconnect the wires and unscrew the 4 screws holding it in place. Once you take the motor off you are going to see broken pieces that look like little white teeth fall down. There are three plastic teeth that insert into a black rubber washer that make the transmission spin. Take that broken part into your local appliance repair shop and tell them you need a new one. Probably cost you about 10 bucks. Put the new one in and put the motor back on. You will be working again like new. These break when the machine is over loaded or old. The part you need is called a motor coupling. It's common and cheap to fix. I hope this helps you out and if you have any other questions let me know. Good luck.
Posted on Jan 22, 2009
Kenmore 90 plus series washer won't spin, barely agitates, will drain - but makes loud noise
It sounds like the transmission is done. Can't pinpoint what it is exactly, but I would start there.
Aug 21, 2012 | Kenmore Washing Machines
Tip
We have a Kenmore 90 series hvy duty top loader, it works fine in wash cycle but...
This advice is for all Whirlpool manufactured TOP LOADING washing machines. This includes Kenmore, Estate and Roper models as well. This is an easy repair that anyone with a little know-how and determination can perform.
First of all, unplug your washer. You will need to remove the console in order to get to the lid switch. The washer may have release tabs under the console at each front corner. Simply slide a putty knife straight in from the front at each corner and push in while lifting up. You should feel the release tabs push in and the console will pop up.
If not equipped with this type of console, you may have a console that has removable end caps. They can be removed by gently prying up on the top of them from the rear on each side. You may have to use a small screwdriver for this. The caps should pop right off. Once removed, you will need to loosen a screw under each cap. Once you have the console loosened, carefully lift it up and lay it back over the rear panel of the washer in its resting position. Be careful not to damage the small plastic hinges that hold it in place. Now you will need to perform the following steps:
1. Under the console you will find the white plastic lid switch connector plug. Unplug the switch from the connector.
2. There will be two brass colored clips. You will need to remove these to remove the machine casing. Place a flat blade screwdriver straight down into the opening on top of the washer and into the groove of the clip. Push the screwdriver away from you while holding into the groove and the clip will release.
3. Open the lid of the washer and place your hand under the front rim of the opening (DO NOT grab the wash tub). Now pull the case from the frame by lifting from the back first.
You do not have to remove it all the way from the frame, just enough to gain access to the switch. All there is to the switch is a couple of screws holding it in and a ground wire. It's a pretty easy repair job. Some models will have the switch located on the right-hand side of the lid rim opening, while other models will have the switch located adjacent to one of the lid hinges in the rear.
Once you've completed your switch installation, make sure you get the case back on the frame correctly by following these steps:
1. While looking down through the lid opening, place the front lip of the machine case UNDER the washer frame and start leaning it back onto the frame. There are four small cleats that must fit into four slots on the case or the washer will vibrate. Make sure the frame is seated properly, lean forward from the front of the washer, grasp both sides of the rear panel and pull towards the case. The rear panel should be seated and flush with the casing before inserting the retaining clips.
2. Insert the brass-colored clips into the slot on the washer rear panel first (this is the end of the clip with the 90 degree bend), and then push straight down into the opening on the top of the washer with some force. If you have the case seated correctly, the clips will snap back in.
3. Make sure you plug the connector from the console back into the lid switch receptacle BEFORE you reassemble the console. This is easy to forget.
I hope this information is helpful..
on Jul 26, 2010 | Washing Machines
Loud banging noise during rinse
Most noises from a washing machine occur during the rinse or spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.This will solve your problem.
Apr 08, 2010 | Whirlpool GHW9100L Front Load Washer
Kenmore 90 tub spins excessively clockwise during wash cycle.
there should be 2 or 3 springs that hold it, they mite have broke, take off back panel an check.
Jan 04, 2010 | Kenmore 24032\24036 Top Load Washer
Shreiking spin in rinse cycle
Your pump is probably what's causing the noise . Usually the bearing starting to go out , causing the pump to freeze up , begins with this noise .
Oct 11, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Kenmore 90 Series Heavy Duty Washer - Agitator doesnt spin
THIS IS A TYPICLE PROBLEM . BETWEEN THE MOTOR & THE TRANSMISSION THERE IS A COLLECTOR ASSEMBY (THREE PIECE
SET) REAL EASY TO GET TOO EASY TO FIX . ALSO COST EFFICENT
Sep 21, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 90 series loud whirring/howling noise during spin cycle
Sounds like you have a broken motor coupler. They are inexpensive. Can be a little tough to replace but I can walk you through it. You can purchase a coupler here.
http://www.shop.washermd.com/product.sc?categoryId=1&productId=1
Dave
Dec 18, 2008 | GE WBSR3140DW Top Load Washer
90 Series Kenmore Washer Not going to spin cycle not draining water
I've had the same problem...you can purchase a replacement lid switch at your local appliance parts store for about $35. Fortunatly, the sales person at the appliance store had diagrams and provided instructions to replace the switch. I was able to finish the job and fix the switch in less than 1 hour. Good Luck.
Oct 25, 2008 | Kenmore 15864/15862 Top Load Washer
90 Series Top Load Washer shakes during spin cycle
The Guide Plate underneath is out of alignment,, You might have to call me on this one. The only reason I am sure of this is because when my delivery guys would deliver a direct drive washer such as your, sometimes when the machine is laid down to far on its side, it gets out of alignment. Easy fix,, Just hard to explain.
Mar 24, 2008 | Kenmore 22422 Top Load Washer
Kenmore 15864/15862 Top Load Washer Logo
185 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
