Question about Cuisinart Grind and Brew 10 Cup Coffee Maker
Programming... Works fine manually, but will not make coffee at set time. Have read thru manual - hold down program button, set time and then set...is that it? Am I missing something. I have 10 c. thermal grind and brew. I would really like to wake up to coffee!
  • altall Dec 16, 2008
    I figured it out - thanks. The manual only talks about exiting the program function, i.e. setting the time. It does not tell you to push the program button again and make sure it is lit for the program to work...After I unplugged and plugged the machine in again the program button lit. And, I had coffee this morning. Thanks!
  • 8,596 Answers
Yep. Press program again. Also, check am vs. pm. Enjoy!
Posted on Dec 17, 2008
Outside Lights will not shut off
You posted under Intermatic EJ500 timer.
Add a comment and say if this is new installation, or if timer suddenly stopped working.
Open following link for manual and wiring.
http://waterheatertimer.org/Flipdown.html
1) For new installation:
-Problem is probably in the programming.
-Check that each program has ON and OFF times set for same days.
-Re-read manual carefully, and add a comment if one part seems difficult to understand.
2) For old installation that stopped working
-Re-set timer and see if that corrects problem.
Hold down on-off button and then push reset button. Release reset button, and hold on-off for a few moments longer. Then re-program timer.
-Replace battery
-Read troubleshoot section in manual
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 28, 2011 | Intermatic Inc. EJ500C Digital Wall Switch...
I need to find instructions on how to reprogram an Intermatic indoor wall timer.
You posted under ST01C Intermatic battery operated timer.
If you have different timer, then add a comment.
Let's review ST01C timer for a moment.
Programming will stay inside timer memory indefinitely until timer no longer works.
Even if battery is removed, programs remain. Current time setting does not remain in memory.
If battery goes dead, then current time will disappear, but programs remain forever.
If previous programming was correct, you might only need to set current time,.
In that case, you do not want to 'reset' timer and clear memory.
If you want to clear old programming entirely, then you can 'reset' timer using following instructions.
Press and hold on-off button, and then use paper clip to push in reset button for 3 seconds.
Release reset button but keep holding on-off button until INIT displays momentarily.
Release on-off button.
If display does not show, then timer battery is bad, or timer is bad.
For instructions how to set current time, click link below.
In addition to current time, the link has ST01C manual and also has EZ to follow instructions and photos for setting on-off times (but not astro times)
http://waterheatertimer.org/ST01C-program.html
Instructions are different for astro dawn to dusk.
Add a comment at any time if you need free help with specific steps in the manual.
If you do not want to read the manual or open a link and read the steps or add a comment for further free help, then you can pay a fixya expert for phone support and that person will walk you through the steps while on the phone.
Keep in mind that ST01C timer has 1 year limited warranty, and your timer might be broken.
In that case you should try the free steps first.
Dec 16, 2010 | Intermatic Inc. ST01C Digital In-Wall...
Intermatic Timer HB88RC unable to program it following instructions. Will not turn on in Automatic mode. Works fine in manual On mode.
HB88RC manual online:
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/hb88rc%20-%20english.ashx
These timers are frustrating sometimes, fortunately this timer can be unplugged to set programs under good lighting.
When I have problems, I set it down for a while and then go back to it later.
Right now I own 25-30 different Intermatic, Woods, GE, Utilitec timers for testing and programming difficulties. Each one offers different points that are confusing.
Some new timers are simply defective. One guy today had 2 defective Woods timers, which made me suspect electric line needs line analysis. You might try your timer in another plug, for example indoor plug in another part of house to double check line is not interfering with timer electronics.
Reading HB88RC manual, there is not Dusk-dawn option, and programming steps are pretty straightforward compared with other timers.
This leads me to believe there is some small thing missed or line is bad, or timer is defective.
Return it if it's defective.
Here are some trip-up points, and they may not apply to you.
1) Current day has to be set. Hold clock button down while setting current time.
2) When programming, each event requires ON time and OFF time. For example event1 ON has to be set and then event1 OFF has to be set. Then set event2 ON and then event2 OFF.
3) When programming, check screen carefully to make sure 1ON appears, and then 1OFF appears in screen exactly like Fig1 and Fig3 shows.
Now I frequently e-mail Intermatic asking for manual clarification, and they e-mail back ... sometimes their manuals are a little bit off here and there. But this manual looks clean and matches what I see in other timers.
4) Each ON time requires OFF time for same choice of days. For example ON 7pm Tuesday and OFF 9pm All-days-of-week will not work correctly.
5) ON 7pm Tuesday and OFF 7pm Tuesday will not work.
6) Conflicts in programming cause some timers to skip programming: For example event1 says ON
at 7 pm Tuesday and OFF 9pm Tuesday, but event2 says opposite.
7) Since manual override works correctly, we know Load is functioning, and we know plugs on timer are working. Timer load can be lighting or pumps or heaters, but manual does not specifically say florescent. So timer MIGHT not work for compact florescent bulbs. If you have CFL bulb, try another type of Load: for example incandescent table lamp.
And that's everything I know, like Bubba Gump shrimp.
Nov 25, 2010 | Intermatic HB88RC - 7-Day Programmable...
I have a faema due automatic single group. Works fine except I cannot program shots. I hold down the "stop" button as per the manual, but there is no "beep" initiating the programming mode. What is wrong?
Hold down button for 8 to 10 seconds. If that is not working then you might have the older model in which you have to hold down the stop plus the button that you are programming until you get the desired volume then release button and stop button.
Jun 26, 2010 | Faema FA60081
Need instructions for la barista tronik 3 group expresso machine.
do you need calibration for brewing??? if it is so than you can try this instructions:
Hold down the stop button for 8-10 seconds or until you hear the faint beeping sound, press button to program when you get the correct level press stop button. On some models you have to hold the button until you get the correct level then release. When you are done programming press stop button a second time to exit program mode.
PS : this solution works at many of older machines, as Emonec, la Cimbali.... THIS SOLUTION WHAS POSTED TO ME FROM
ES WORLD
Mar 04, 2009 | Coffee Makers & Espresso Machines
Melitta mill and brew 10 cup grinder/maker
  1. Press and hold the TIME button for 2 seconds. The green TIME light will come on and display will read 12:00. The unit is now in the timer programming mode.
  2. Press "HR" and "MIN" button to program start time. Small dot in upper left corrner signifies clock is programmed for A.M. No dot in upper left corner means clock is programmed for PM.
  3. The Timer Display and LED light will flash 5 times to indicate that timer is now set. Press and release the TIME button. The green TIME light will come on.
Sep 06, 2008 | Coffee Makers & Espresso Machines
Programable Timer
After you follow the directions in the manual, you have to press the Program button one more time so that it lights up - THEN it will make coffee at the set time.
Aug 22, 2008 | Cuisinart Thermal DGB-600 Grinder
Won't make coffee
Could you please advise how I obtain a manual for a Saeco Magic deluxe
Apr 28, 2008 | Saeco Magic De Luxe Espresso Machine
Operating instructions
I have this manual (CM500) and can scan/email it to you if you send me your email address...also I am looking for a replacement lid for my carafe for this machine if anyone is looking to get rid of theirs!
Mar 29, 2008 | Gevalia CM-500 12 Cup Coffee Maker
Programming how to
there are quite a few models, but mine is the 'deluxe', and ther eis a 'program' button on the right side of the panel... .hold that down until it 'blinks' a number thru the LED screen. ...there are H and M buttons below the LED screen (one left, one right).... you can use those to program the hours and minutes.
if you are not sure what you programmed the time to be, u can always just hold down the 'program' button, and it'll flash with the set time.
when u go to sleep at night, just push the program button down, and it will light up, so u know it is 'set'.
Sep 24, 2007 | Hamilton Beach BrewStation 47214 Coffee...
Cuisinart Grind and Brew 10 Cup Coffee Maker Logo
132 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Michael Galve
Michael Galve
Marvin
Marvin
Tom Howe
Tom Howe
Level 1 Expert
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
