Question about LG 32LC2D Television
Frozen lcd screen
The screen on my TV has frozen. Using the remote control makes no difference. The same channel name is in the top righthand corner when I switch on the TV, but that's all. Otherwise, the screen. It happened suddenly, no warning. I can use the remote to switch the TV on and off, but that's all. Can anyone help? Is it a bug?
  • Margaret Zsigmond Apr 02, 2007
    I've recently heard that this problem occurs with LG LCDs when switched to Channel 9 in Sydney. Weird. Apparently, LG are working on it but they don't know why it happens. There's not much worth watching on Channel 9 anyway, so I've solved the problem by not switching to it.
  • Anonymous Dec 09, 2008
    I have the exact same problem...how did u fix it??
    Genius:
  • 1,074 Answers
That problem is a factory defect in the if and video section of the tv only the manufacturer could remedy that.take it to a tech so that the video board and the IF board be replaced
Posted on Apr 06, 2007
My firestick is frozen on home page
Fire Stick frozen on home screen
Restarting your device can resolve many issues-just disconnect the power cord (from the back of the device or from the power outlet), and then plug it back in. You can also use your remote to restart your device. Press and hold the Select and Play/Pause buttons at the same time, for about five seconds.
Amazon.com Help: Fire TV is Frozen, Blank, or Won't Power On
https://www.amazon.com/gp/help/customer/display.html?nodeId=202154650 Search for: Fire Stick frozen on home screen
firestick is frozen on home page Google Search
Jun 12, 2018 | Televison & Video
Digital tv channel stuck on Setup blue screen
Just contininue to try that it if not then you'll have to do a hard reset.
Feb 01, 2014 | Philips Televison & Video
Old Sinotec TV. Screen open blue with a "padlock" in top righthand corner
It is locked. If you have the original remote (RC-A07) for Sinotec tv, then press and hold down the Music button for about 10 seconds. If you wish to get more details, surf the site linked here. http://electronicshelponline.blogspot.com/ Pull up previous posts there, either by type in the model name to your set in its search box, or view it in Timeslide / Mosaic option.
Jul 13, 2013 | Televison & Video
On my Tv Hitachi CLU-4321UG appears locked
Turn on the TV and grab the remote. In most cases, you will need the original remote to unlock the TV if you aren't sure of the unlock code. If you don't have the original remote, you will need to purchase one.
Look at the screen. If you see a blank screen with a red key on the bottom of the screen, press 'Function' and 'Mute' at the same time. This should unlock the channel. This is an option for people who want the TV to stay locked but, want to be able to bypass the lock to watch a certain show or channel. All other channels will remain locked and the TV will fully lock when it is turned off.
Unlock all of the channels on the TV by entering the factory reset code. There are three main reset codes that TV manufacturers set. These are 0711, 6688 and 3308. Try each one until you find the one that works. This will reset the TV to original factory settings. When you do this, you will loose any information that you have stored in the TV, such as favorite channels, automatic timers and the clock. You will have to go through the full initial set up.
Call the technical support service number in your owner's manual if none of those codes work. A technician can help you troubleshoot the television because the problem may not be the locking control. When you call, make sure that you have the model number and serial number of the TV.
Visit the site named 'Electro-help' for more details. Click this link. View it in Timeslide or Flipcard option, which can be selected from the drop down box menu by the Sidebar tag, at the top left corner of the display window. You can also click the Home tab to see the latest updates. It will make search easier. There are more than 1400 posts to different brand TVs till now. Setup proceedings and code list to different brand remote controls also included. Pull up older posts or do a search by type in the Brand Name of your device in the Search Box, at the top right of the display window
Dec 17, 2012 | Hitachi CLU-4321UG Remote Control
My Panasonic 26" LCD TV TX26LXD60 is frozen on return after trying to do a factory reset
Sounds that the firmware have been corrupted. You might have to upgrade the firmware. If you are confident, you can do it by yourself. If not, seek help of any experienced service technician.
Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" or "Flipcard" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. You can also click the [Home] tab to the latest updates. It will make search easy. There are more than 1350 posts to different brand TVs now. Pull up older posts there.
Nov 28, 2012 | Panasonic Televison & Video
How to reset Telefunken TTV280 to factory defaults
It is not with the the fault as you suspects. It is the fault with its main system control memory IC. Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" or "Flipcard" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. There are more than 1250 posts to different brand TVs now. Pull up older posts there
Nov 22, 2012 | Televison & Video
Philips 37PFL5322D
Your remote control need cleaning. Visit the site named 'Electro-help' for more details. Check this link and select the site named above. View it in 'Flip card' option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. Some times, the ads attached with each posts, both at the right and bottom, might help you to find the availability of spare parts. There are more than 750 posts to different brand TVs now.
Pull up older posts there. have all details about how to clean a remote control.
Sep 12, 2012 | Philips new universal remote control...
I have a small elemet tv with a en21645e remote control. My grandson did something to the remote and now I only get the local channels not cable channels although I have cable hookup
The little tyke has most likely pressed the INPUT button on the remote control and switched the TV away from the external input setting required for watching cable TV.
You did not state the model number of the TV and some TVs function differently with regard to the selection of external inputs, but you should be able to return to watching cable by pressing the INPUT button slowly but repeatedly until you can see the picture from the cable channels again. The INPUT button is located in the top right corner of your Element remote.
If an input selection menu appears on screen when you first press the menu button, use the arrow keys to highlight another input, then press ENTER to select it. I can't tell you which will be the correct input as I don't know the model number of the TV and it depends on which type of cable you are using to connect the TV to the cable box. You should try each input in turn until you are able to see the cable channels again. Please make sure the cable box is switched on when doing this!
If you are still having difficulty, please reply to me from within this page with the model number of the TV and the type of cable you are using to connect the cable box to the TV. I will then be able to provide exact instructions for switching your TV back to the cable input.
Hope this helps.
Regards,
BElectric
Jan 28, 2011 | Element Televison & Video
I have a 32 in insignia and a universal remote was used to try and turn channel..it turned the channel once and now its frozen on that channel even the tv remote wont work and the manual buttons on the tv...
Turn your TV off and unplug it for several minutes. Remove the batteries from any remote controls that you use for the TV, press all of their buttons, and install fresh batteries. Reset the TV to factory defaults. The universal remote control should not have caused any damage to the TV. If the problem persists, we recommend that you seek service by calling 1-888-237-8289 in the U.S or 1-866-237-8289 in Canada.
Mar 24, 2010 | Insignia NS-LTDVD19-09 LCD TV
Televison & Video Logo
955 people viewed this question
Steve Allison
Steve Allison
