Door wiil not open - Televison & Video
Please help me in solving this problem
Posted on Apr 21, 2009
  • 327 Answers
Its the faulty door assembly thats not moving so the door is not getting opened.the assembly needs to be replace the assembly the drive needs to be disassembled.
Posted on Dec 15, 2008
Rear door wiil not open. It is a manual door.
The latch has come apart is some aspect. Remove the inner panel and manually open the latch. In most cases its just a plastic clip that has broken.
Mar 26, 2011 | 2004 Mercury Montery
Door handles broke. how can i get in the car?
suggest you search for lockout kit at auto parts store or hardware store, the kit contains a door jack that is used to pry door open a little at top and contains tools you can put together and reach in through opening in top of door to reach the door handle to release from inside.i've done this for a living and know it sounds bad but door wiil spring back in normal position, just do not pry the door out to far, only enough to slide a rod down the size of a coathanger. hope this helps!!
Nov 11, 2010 | 1997 Ford Thunderbird LX
The light will not come on by the motor. One of the eye's(sensor) on left light is out. Door wiil not close.
Your door sensors are bad or they are not properly pointed at one another. Tweak them a bit to see if you can get both lights to come on. If not they are bad.
Aug 27, 2010 | Sears Craftsman LiftMaster Chamberlain...
2003 for focus doors wont open outside handle feels loose and wiil not open latch
plastic door handles on this model break easy, buy on ebay or similar cheap places, dealer could be fair also, you need to remove the door handle from inside with 10mm nuts / screws, you need to remove the door panel, google instrucitions, once door panel is off it is simple, make sure you do not disconnect the switch connected to the door lock cylinder otherwise the car will not restart if so equipped, switch turns off factory immobilizer if equipped...make sure you connect the rod to the door handle and make sure you lock the clip on it before you reinstall door panel, test first....
Jul 13, 2010 | 2003 Ford Focus
Door wiil not open is there an emergency release latch
Yes, there is a manual release. The following link explains how to access and open the door when jammed:
If you need further assistance, please let me know.
Dec 24, 2009 | Whirlpool Duet GHW9150P Front Load Washer
2006 impala passenger door won't open
have someone from the outside pull the handle up while you pound the door from the inside. the latch became frozen from lack of lubrication. once open, spray the **** out of it with wd40 or pb blaster and work the latch till it moves freely
Jun 16, 2009 | 1998 Mitsubishi Eclipse
Amana dryer timer dial wiil not rotate/temperature stays hot
The elctrical contacts in the timer have welded themselves together or the notch wheel is broke in the timer; either way you need a new timer, and this also explains why it runs until you open the door.
Apr 10, 2009 | Amana NDG7800AW Gas Dryer
We have an Ikon Image Runner 2200 here at our church building and the front door keeps popping open, please help if you can, thanks!
The door of the IR is held in possition with a magnet.You can just glue tye magnet back in it's housing and the magnet wiil hold the door inplace.Just remember to use a strong glue.
Jan 25, 2009 | Canon imageRUNNER 5000 Copier
Televison & Video Logo
193 people viewed this question
Top Televison & Video Experts
