Question about Lowrance LMS-337CDF GPS Receiver
My Lowrance LMS-337c df keeps going crazy.
My Lowrance LMS 337c df works for a little bit and then it starts going crazy beeping and flashing and wont turn off.
  • 2 more comments
  • Anonymous Mar 18, 2009
    Unit keeps powering back on by itself. when it is "on" it blinks constantly. i try to turn it off and it powers back up. it keeps draining my battery when the boat is parked.
  • tomgil Apr 16, 2009
    I have the same problem with my LMS-337CDF. I got it with a second hand boat I purchased in November. It has always powered itself up with the display flashing and audio alarm going off. Is the operating system upgrade worth trying? I don't have a card reader to experiment with.
  • tomgil May 20, 2009
    I tried the soft and hard reset, no joy.  Got a card reader and down loaded software.  System worked until I installed the SD card with maps on it.  Reloaded software and got it to work with Map card installed.  I was doing all this on my work bench with the battery from the boat.  Now that I have the system installed on the boat the problem returned.  I'm going to double check the wire connections and run the negative and shield wires separately as home runs back to the battery.  After that I'm going shopping for a Garmin.
  • nymp11 May 21, 2009
    Yup same problem here exactly. Lowrance want $200 to repair the unit.
Mine does the same thing when the voltage is low. The GPS part will drain the battery if left connected. Learned the hard way. I installed a battery isolator switch, the one with the big red key, and switch the battery to "Off" when finished. Either that or unplug your unit each time. Still, if the battery is not maintained during storage, the same problem will arise until the battery has been fully charged. Never has done this when the outboard is running and current is going to the battery from the alternator.
Posted on Jan 24, 2010
    Novelist:
  • 113 Answers
Normal 0 false false false MicrosoftInternetExplorer4 st1:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}This could be caused by glitch in the operating systemsoftware or by low voltage due to a short in the unit or somewhere in the boatswiring. To troubleshoot the problem Iwould recommend the following steps.
  1. Try a soft reset
  2. If the problem resurfaces, try a hard reset
  3. Update the the operating system software
Soft Reset (Does not delete GPSData)
1. Turn unit OFF 2. Press and holdthe PAGES key
3. Press and hold the PWR key
4. Release both buttons when the USA map
Appears
Hard Reset (Deletes stored GPS Data
such as Waypoints and trails)
1. Back up any waypoints, routes,and trails that you want to save on a blank MMC card
2. Turn unit OFF
3. Press and hold the ZIN&ZOUTKeys at
the same time
4. Pressand hold the PWR key
5. Release both buttons when the USAmap
appears
To update the operating system software, check out this link:
Lowrance337c df update
If you don't have a card reader I can program an update card for you.
Posted on Dec 16, 2008
  • Jay Finke
    Jay Finke Mar 25, 2013
    seems there is 3 files in the update witch one should I use ? it says version 1.6.0 the new one is ..LMS-337C DF 12/20/07 1.9.0 7.1MB. .. might be I don't know how to load it on my 1gb sd card ?
Have the same problem. Have you resoved it?
Posted on Jun 20, 2009
LMS 337c DF. The LCD backlight seems to jump from bright to off and back continually after the unit has been on for 10-15 mins. holding finger on the power/light button stabilizes the problem until the...
the lcd is going out and will cost more to fix it then the cost of the gps....my advice is to get a new one from bestbuy and get the 4 yr performance service replacement plan so next time you have a problem like this they will replace it for free.
Mar 06, 2008 | Lowrance LMS-337CDF GPS Receiver
Lowrance completely dead
my lowrance lms 337c df will not power up. I checked all the cables and poer and they are good . can you assist me
Aug 14, 2011 | Lowrance LMS-337CDF GPS Receiver
My LMS-522C keeps losing it's position on the GPS.
I'd suggest calling Lowrance.. Those guys are very helpful with step by step support... I just purchased a used boat with a 525c df on it and been troubleshooting some problems with it. Central time zone and best to call right when they open or turn on the phones at 8:15.
Mar 07, 2010 | Lowrance Lms 522c 5" Screen Color Internal...
Can i replace my 330c head unit with the 525c using the same wires antennae etc lowrance
Hope its not to late, before you replace (buy a new one) call Lowrance. I have a 525 and working through some problems and they advised me that they would replace my unit for $200 no questions asked. To answer your question not 100% positive but I did see a recent question where Lowrance lost his unit and sent him the 525 as a replacement and the connections were different. I believe my 525 has a 5 pin system with one notch. Does yours have a external gps module? The 525 does!
Mar 01, 2010 | Lowrance Lms 525c Df 5" Df Sonar...
I need CD, or DVD to learn how to use my Lowrance it is modle LMA-332C & LMS-337C DF.
Here you can buy the DVD for $13:
Bennett Training DVD For Lowrance LMS-332C
Here is the user manual:
LMS-332C and LMS-337C DF Owners Manual
Do not forget to rate the solution appropriately.
Many thanks.
Aug 31, 2008 | Office Equipment & Supplies
Gps
I have a manual for this unit but i'm still using mine so not willing to sell it to you. I'm in Melbourne and you're welcome to borrow it for a week or so or i could probably photocopy/scan certain sections for you and email them if it helps. Let me know if you still need it by emailing me at joshklat@hotmail.com
Cheers,
Josh
May 21, 2008 | Lowrance LMS-337CDF GPS Receiver
Lowrance LMS-337CDF GPS Receiver Logo
3,558 people viewed this question
Top Lowrance GPS Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
Wbix
Are you a Lowrance GPS Expert? Answer questions, earn points and help others
