Question about Canon DC20 DVD Camcorder
Canon DC20 only powers on and operates with side screen closed
The DC20 works perfectly if I use the eyepiece and not the side screen view. If I am recording, through the eypiece, and open the side, the entire camcorder shuts down. If I hook it up to AC power, the side can be open and record properly, when doing this, if I unplug the
AC power, the Canon powers off, like a light switch turned off. The camera has never been dropped that I know of, but maybe the kids did drop it and didn't tell me.
  • 1 more comment
  • bchepa Dec 16, 2008
    How do I realign the inside, or is there a place I should send the camcorder to?
  • bchepa Dec 17, 2008
    Thanks for the help, I did go to Circuit City and bought a new battery, charged it, and once I removed the ac plug and powered it on with the side door open, goodnight, she went to bed.
    Any more thoughts?
  • bchepa Dec 18, 2008
    New energizer battery fully charged,same reult, power down when side door is opened. Any other ideas?
  • 4,234 Answers
The side LCD panel requires more power to run than the viewfinder. There is a small switch inside the unit that enables/disables the side panel from working. This switch seems to be working as the unit works when powered from the AC adapter. However, the higher current draw may be causing the voltage to drop slightly when using the battery and thus causing the internal protection circuitry to shutdown the camera. This is done to prevent damage to the camera when the battery becomes faulty. The problem here sounds more like the voltage detection circuit being faulty. This is not a problem that will be solved remotely. Unfortunately you will need to have this unit serviced by a shop where they can run the camera while opened up on a jig to track this down. Measurements will need to be taken while the camera is being run. My suggestion would be to invest in a detailed estimate from an authorized Canon service center. Report the results here and we may be able to walk you through the actual repair.
Please note that the "fix" for this may involve a board repalcement as few shops perform component level repairs on these cameras.
Dan
Posted on Dec 18, 2008
  • 112 Answers
Hello sir,
that problem you ask us
is based on hardware problem you
maybe its damage your LCD strep thats make a links to LCD TO CAM
you need to repair your self are hare a professional
repair
coz if you do it your self you make some other thing broken
try it from other man
Posted on Dec 17, 2008
  • 275 Answers
Hi, sounds like you have a technical problem with your camcorder Canon DC20. Your problems sounds like it is a mecanical problem rather then something that can be easelly fixed . If you are wondering about what you can do to fix it or where to take it, I would defeetly recommend that you rather contact the manufaturer so they can fix it for you. If you are interested go to this link: https://www.usa.canon.com/consumer/controller?act=OnlineRepairBookingAct&fcategoryid=261&modelid=11817
I also recommend you call the technical support team at 1-800-OK-CANON for further information.
Posted on Dec 16, 2008
    Sergeant:
  • 306 Answers
jus follow tis...
1. Remove any videotapes in camcorder.
2. Remove memory sticks, cards, or other media.
3. Power off the camcorder.
4. Remove the battery if on battery power.
5. Plug in the camcorder AC adapter.
6. Power on the camcorder.
else you may have a faulty charger or internal battery. If your camera is still under warranty take it back to the shop where you bought it, explain what is happening, and ask for a refund or exchange.
Posted on Dec 15, 2008
    Genius:
  • 2,035 Answers
This is the problem with leak battery as its work in the AC mains,
If you want to buy a new battery pack please use this link:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=171&modelid=11817#SNAModelSuppliesAct
Good luck....
  • Anand Kumar
    Anand Kumar Dec 18, 2008
    Well if this problem exists even after replacing the battery ,then the battery compartment is inside the LCD display slot as soon as you open the LCD screen its makes the battery to loose contact hence powering down , as soon as you open the LCD screen press the battery and power it on....
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
It would appear that the electronics of the "side screen view" is consuming power over and above its rated/specs. Thus opening and activating while the camera is on battery triggers a shutdown. With the AC adapter plugged in, the power is supplied by the adapter and the built-in over current protection from the battery does not engage:
Initially, pls try to clean/scrape make shiny the battery contacts both of the camera and the battery. If this is not corrective, then it may be to your advantage to seek the services of an authorized Service Center rather than consider a DIY (do-it-yourself).
Good luck and Thank you for using FixYa. Happy Holidays.
  • 10,594 Answers
As you said, camera works fine on side LCD if powered by AC adapter, so Battery is suspected and seems weak. Try to use new battery.
If camera has some problem in circuit board, then It should not be function on ac charger too.
  • Shahid Electronics
    Shahid Electronics Dec 18, 2008
    OK, seems bit complicated problem in Canon DC20.
    Problem can be in door hing assembly that being touched in battery power section and caused shutdown immediately or connecting flexible wire between LCD board and camera main board.
    Above ideas need camera to be apart for confirmation.
    Thank you.
  • Canon Master
  • 19,396 Answers
Try a replacement battery, if you have the problem only when the camcorder is working on batteries, it is possible that this is caused by a defective battery.
Go to any repair shop and test the camera with a replacement battery.
    Master:
  • 479 Answers
It due to the internal parts have lost its allignment in the device.the camera needs to be opened and realligned properly.something is got moved internally.
  • 734 Answers
Did try a new ac Adapter?
Thanks
  • futureloginn
    futureloginn Dec 15, 2008
    there is a problem in battery.
    your Canon DC20 battery is gone.
    try a new battery.
    Thanks
My camera screen wont come on?
Generally when there is no power, the camera simply needs to be serviced by a professional. This came up as a Canon as someone had mentioned Canon in one of the answer. If it is in fact a Canon Powershot, your best bet for service would be: www.CamerasAndParts.com That is who we recommend for the Powershots. They do outstanding work and they are very affordable (generally $79 or $89) including all the servicing for the camera, parts and labor for the no power problem, and return shipping, they're unbeatable for the Canons and they do excellent work. Best of luck with the issue at hand.
Nov 05, 2014 | Cameras
Dropped Canon - Display Broken
Repair expensive, if possible. Replacement best option.
May 25, 2017 | Canon PowerShot SD600 Digital Camera
Problem viewing planets using 25mm eye piece. which eye piece works the best? nextstar 80 slt
The smaller the number on the eyepiece the greater the magnification-- the maximum magnification of any telescope is about 50 times aperture. You scope is about 3 inches -- so 150 power is the maximum usable magnification.
BUT-- only under perfect conditions -- perfect sky-- perfect optics -- perfect eyepieces. Usually 30-40 times aperture is all you will get on a typical night with some turbulence in the atmosphere.
Read my tips on my profile page and listen to my podcasts at :
www.telescopeman.us
May 13, 2011 | Celestron NexStar 80 SLT Telescopes 22086...
I lost me roxul software for dvd burning and not available from cannon. What will be the solution.
Try DVD Author Plus, it will backup, copy, and burn your DVD's. It is easy to use and works perfectly. Download the free version here:
http://www.deskshare.com/dvd-authoring-burning-software.aspx
Jan 15, 2011 | Canon DC20 DVD Camcorder
Canon EOS 1000D LCD screen
Check your manual...does it say your camera has "live view"?
Sep 30, 2009 | Canon EOS Digital Rebel XS / 1000D IS...
Can't get image in viewfinder
Your camera works just like a film camera SLR,. You use the eyepiece to frame and focus your picture. The LCD screen is for reviewing pictures taken or menu operations.
Jan 09, 2008 | Canon Rebel XT / EOS 350D Digital Camera
LCD Screen does not work properly
Your camera works just like a film camera SLR,. You use the eyepiece to frame and focus your picture. The LCD screen is for reviewing pictures taken or menu operations. You cannot preview a shot on screen before it is taken with the camera.
Jan 07, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Canon dc20
disc that came with camera - still works ? if not ( no disc works , now ) put the camera to your ear , before closing door : if there is no noise after door closes , the switch on the door may be out of alignment - but if there are whirring sounds , your lens may be dirty ( cleaning with q tip and windex risks voiding your warranty ) or your discs may be scratched - the index is near the center hole of the disc , and must be clear of smudges etc .
Sep 04, 2007 | Canon DC20 DVD Camcorder
Camcorder recording problem
if 600 sgd is labor only - around 400 usd - you might consider cost of trading up to a newer model ( check ebay for second camera , while you wait for . . . warranty repairs ) ;
Aug 23, 2007 | Canon DC20 DVD Camcorder
Canon DC20 DVD Camcorder Logo
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
