Question about MSI PROCESSOR SUPPORT INTEL CORE 2 DUO MEROM FSB800 T7100/7300/7500/7700 CHIPSET IN (171948-002) Barebone
My HP dv6226tx Laptop display shows only background light.
The display was intermittantly showing some problems for sometime. Closing and opening the lid for sometime, giggling near the hinges etc. did no improvement. This system is hardly 13 months old. It runs Vista home premium licensed version and not used for gaming. Daily around 4 hrs. use for research related data storage and retrieval. Contacted a few people. No proper solution from anywhere. It is not opened by anybody. The Laptop is in Cananda now and it is difficult to find any reliable and quick repair agencies.
How to recover the data from the laptop?
How to get it back to normal within short time?
    Problem Solver:
  • 4 Answers
There is a program you could use called RAdmin.When you connect the laptop to a normal PC,RAdmin allows you to see on the PC monitor what is on the laptop screen.You could possibly use this to transfer data from the laptop to a PC
Posted on Dec 15, 2008
HP Dv7-1130us LCD screen displaying vertical blue line
the actuall screen LCD is bad.
in most cases.
supper common failure.. 2008 PC.
see page 31 , part 5 here. bingo, change that out.
there are 2 types used, only your full PC part number on
the service tag show this, post that and we go to the HP parts surfer and look it up.
http://h10032.www1.hp.com/ctg/Manual/c01918142
Sep 28, 2017 | HP Pavilion dv7-1130us laptop
Laptop LCD/Display Problem, Green and Pink Tints???
Their are a couple things that could be causing this, My first thought is that the screen its self is damage. A LCD screen is composed of millions of tiny pixels so when some fails others will still work.
That other thought is that the GPU or video device on the laptop could be failing and creating video problems. Have you tried closing the laptop and opening it agian, this would help rule out a bad cable connection.
Dec 24, 2013 | Computers & Internet
HP pavillion dv9000 has black horizontal lines across screen and looks like a snowy background
Sounds like the screen is going bad. Isolate the problem by plugging an external monitor to the laptop. Borrow a monitor from a neighbor, friend, relative or co-worker to plug to the laptop. It can be any kind of monitor even the old big fat crt monitors as long as it has a vga cable to connect to your computer's vga port. If the Borrowed monitor does not show the black lines and snowy background, that proves your video card is ok and the problem is your lcd screen. If the borrowed monitor shows the same black lines ans snowy background it means your video card inside the computer has the issue.
The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
May 18, 2012 | HP Compaq Business Notebook nx7000
I have had the monitor plugged into my HP laptop. Suddenly, it showed a "Power Saving Mode" message on a blank screen. I have gone through my troubleshooting guide. The screen now shows my background...
Depending on which version of windows you have the directions may be slightly different but in the display settings check to see if it is set to extend the display or to duplicate the display both do very different things. Hopefully adjusting this will correct your issue.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/larry_1fe25e09c54eece2
May 31, 2017 | Princeton Digital VL193 19 in. Flat Panel...
I have an HP DV 9700 and recently the lcd display is showing discoloration around the edges of the screen showing up as kind of grey on an all white background. The cursor shows up ok across those areas...
The display is dying unfortunatley. The laptop is about 2 years old? You can connect an external monitor to confirm. If teh external looks fine, it is definitely your display.
If you have a warranty, it shoudl be covered. If not, might be best to get a new laptop. Netbooks are faily inexpensive.
Hope this helps. Please comment and rate :)
Thanks,
Oz
Feb 12, 2010 | HP Pavilion dv9000z Notebook
Dell xps,no video output and it sows only white backgrounds
hi good day,
on this situation the best way you need to do is to reformat and reprogram the laptop...
Feb 15, 2009 | Dell XPS M1530 Notebook
Dell Vostro 1710 display problem
Hello My Dell Vostro Laptop Display Not Working Correctly it showing Dim but in other desktop when i connect to the Laptop Of Mine it showing Correctly With No Dim Problems? How can I fix the Problem?
Nov 19, 2008 | Dell Vostro 1500 Notebook
Displays desktop background but nothing else
I discovered that my laptop supports two monitors and the projector was acting as monitor #2. By changing the priority of the monitors I have got the information I need on the screen, but now not on the laptop. However, I can work the two from the screen and that will suffice for the moment, until I can find a way of getting the information on both!
Sep 05, 2008 | Philips bSure SV1 Multimedia Projector
Intermittent display problem
There's a small plunger just beyond the keyboard which switches the screen off when you close the laptop, this could be sticking. Failing that check the screen cables are secure, reseat the screen
May 18, 2008 | Compaq Presario X1000 Notebook
MSI PROCESSOR SUPPORT INTEL CORE 2 DUO MEROM FSB800 T7100/7300/7500/7700 CHIPSET IN (171948-002) Barebone Logo
123 people viewed this question
Top MSI Computers & Internet Experts
Alun Cox
Computer Links
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
