Question about Apple iPod nano 3rd Generation
IPOD how to move music
My original computer died. I have a new one and now when I plug in my IPOD it says I have to manage music manually, cause it is not registered to that computer. So I can't remove music from my Ipod or its gone forever. Is it possible to move music from my Ipod to the computer and then add new music?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 163 Answers
Follow these steps it will help you to copy music to pc
Open iTune
confirm that your iPod is configured to enable disk use. Essentially this means that your new computer will recognize your iPod as a USB device device or a external drive.
Step2
Enable disk use if necessary. Connect your iPod to your old computer and open iTunes. When iTunes has loaded, select your iPod and display "Preferences" in the main window.
Step3
Click on the "Summary" tab and select "Manually Manage Music." You should see a check mark in the box next to "Enable Disk Use." If you don't see it, then just check that box yourself. An alert will display informing you'll now need to manually unmount the iPod as well as ejecting it in iTunes before disconnecting it from the computer.
Step4
Hit "OK" and click "Apply Preferences."
Consolidate Music
Step1
Move all your music to one place to make the transfer easier.
Step2
Navigate to the iTunes Preferences menu. In Windows, this menu is located in the Edit menu, while on a MAC it's simply it's own menu.
Step3
Go to the "Advanced" tab, then "General." Check the box next to "Copy Files to iTunes Music Folder When Adding to Library" and click "OK." iTunes will copy all of your music to the hard drive of your computer. This shouldn't be a problem unless you don't have enough disk space.
Step4
Go to the "Advanced" tab and then "Consolidate Library." Read the message that warns you that this step will place all your music in the iTunes folder and that it can't be reversed. Click "Consolidate."
Determine Storage Capacity
Step1
Make sure there's enough space on your iPod to hold the iTunes music files. In essence, you will be using your iPod as an external storage drive to bring your iTunes library to the new computer. Without a large enough storage capacity, this can't be completed.
Step2
Determine how much space is available by opening iTunes on your old computer and checking the size of the library. Click on "Music" and make note of the amount of space your library takes up. Then connect your iPod, click on it in iTunes and note the amount of free space indicated at the bottom of the pane.
Step3
Calculate to make sure that the amount of available space on your iPod is greater than the space required by the iTunes library. If not, you'll need to free up some space.
Step4
Free up space by clicking on your iPod in the Source pane and then clicking on "Music" or otherwise navigating to the contents of your iPod. Click on any song in the main library window and go to "Edit, then "Select All."
Step5
Be prepared to lose any music not contained by your iTunes library if you haven't been updating automatically, because that music isn't on your computer and will be deleted. However, if you've been updating, there's no need to worry. Press your keyboard's "Delete" button and click "Yes" when you receive the confirmation message.
Copy and Backup
Step1
Exit from iTunes and locate both your iPod and your iTunes folder. On a Mac, the iPod should be visible on the desktop and the folder is "/Users/username/Music." In Windows, the iPod is located in "My Computer" and the folder is "\Documents and Settings\username\My Documents\My Music\." Drag the folder to the iPod and wait patiently as the data transfers.
Step2
Copy your iTunes folder to your iPod. Drag the folder to the iPod and wait patiently as the data transfers. When it's done, eject the iPod from iTunes and disconnect the iPod.
Step3
. Connect your iPod to your new computer and backup any music that's in your new iTunes library. Go to "Preferences," "Advanced" then "Reset." Click "OK." Then navigate to "Advanced," "Consolidate Library" and click "Consolidate."
Step4
Copy your music to your new computer. Locate the Music folder on your new computer--it will have the same name as on the old computer--and drag the iTunes folder from it to the desktop. Find your iPod, double-click to open it and drag the iTunes folder copied from your old computer to the new computer's iTunes folder.
Step5
Wait as the music is copied to the folder and then open iTunes. The music and all of its accompanying information should sync without problem.
Posted on Dec 15, 2008
Songs from ipod onto computer
iTunes is always the best tool for us to transfer music from iPod to computer or from computer to iPod, but for the situation of transferring music from iPod to new computer with iTunes is really difficult.
But there are some ways can help us to achieve it, like belows.
http://support.apple.com/kb/hT1329
http://smartphonething.blogspot.com/2012/07/how-to-transfer-music-from-ipad-to.html
http://www.leawo.com/knowledge/transfer-music-from-ipod-to-computer.html
Jul 30, 2012 | Apple iPod mini 2nd generation MP3 Player
Tip
How to set your iPod to manually manage music
<p>Depending on the settings of your iPod, the iTunes software on your PC music on the device automatically every time you sync your iPod with iTunes. This can be avoided by changing the settings on your iPod so you can manually manage the files on the device. The ability to manually manage music on your iPod, you also have the option to sync the iPod with other computers without the music on your iPod automatically deleted. <br /> <p><br /> <p>1. Open iTunes. <br /> <p><br /> <p>2. Use a USB cable to connect your iPod to manually manage a computer's USB connection works. <br /> <p><br /> <p>3. Click the iPod in the category called "Devices" on the left side of iTunes. <br /> <p><br /> <p>4. Select the "Summary" tab at the top of iTunes. <br /> <p><br /> <p>5. Select the "Manually manage music and videos" box by adding a check mark in the box. <br /> <p><br /> <p>6. Click "Apply" at the bottom of iTunes and the iPod settings to be saved and you will be able to manually manage music on the device. <br />
on Aug 09, 2011 | Apple iPod touch
Tip
How to get music onto an iPod without removing the previous music
<p>Sometimes when adding music to your iPod through iTunes on a new computer or another computer, the program will attempt to synchronize the device with the music available on the computer. All songs on the iPod, but not in your iTunes library will be removed. This can cause problems for people who just want to add songs to your iPod without losing their old music. Fortunately, Apple allows users to manually add music to the device, avoiding the problems of synchronization. <br /> <p><br /> <p>1. Open iTunes. <br /> <p><br /> <p>2. Connect your iPod to your computer using the USB cable. A prompt will appear warning that the device will synchronize the music to remove. Click "Cancel" if this happens. <br /> <p><br /> <p>3. Click the iPod listed under "Devices" in "Library". This opens the "Summary" page for the device. <br /> <p><br /> <p>4. Check the "manually manage music and videos" box to the bottom of the page. <br /> <p><br /> <p>5. Click on "Library" on the left sidebar of iTunes. Mark all the songs you want to add the device. Drag and drop it on the iPod listed under "Devices." <br />
on Jul 21, 2011 | Computers & Internet
All I want to do is be able to choose what goes from my Itunes on my computer onto my Ipod. Can I do this without Cosmi? I have Windows 7 -- is this too new?
You can do this by turning off Automatic Syncing.
  1. Open iTunes.
  2. Plug your iPod into the PC
  3. Select your device in iTunes
  4. In the Summary screen, tick "Manually manage music and videos"
Now your iPod no longer syncs all the music on your iTunes.
May 07, 2011 | Cosmi Music Tools Utility Software For The...
I've never used my new ipod Nano. How do I load songs and albums from itunes
You'll need iTunes - the software that Apple has developed to do this sort of thing. Get it at:
http://www.apple.com/itunes/download/
Once you've downloaded and installed that, open it up.
Now, you have two options as to how you're going to "sync" your iPod. ("Sync" means synchronisation - loading the music onto your iPod). There are two ways, automatically and manually.
Automatically is where you have your music library on your computer. When you plug in your iPod, the computer checks the music library on your iPod and does what it has to do to make the iPod's music library identical to the one on the computer, whether this means deleting things off the iPod or copying music over. This is great if you just want to manage one set of music. You just manage it on your computer, then when you plug your iPod in you don't have to worry about it - the computer just does it. This is the simpler option.
However, this means you need to keep a copy of all your music on your computer - and you can't plug your iPod into any other computer. That's why you can manually manage your iPod. When you manually manage your iPod you drag and drop the music you want on to it - the computer DOESN'T do it automatically. This is good if you don't have much room on your computer, so you can't keep a copy of the music - or if you want to get music off more than one computer.
Plug your iPod in to the USB port of your computer. Follow any prompts that come up you should be presented with a screen under "Devices > Your iPod" (on the left hand side of the screen) that shows your iPod and some information about it (software version, how much space you've used, etc.)
If you decide to manaully manage your iPod, then there's a tick box towards the bottom of the screen with "Manually Manage my Music". Obviously, tick that if you want to do so.
If you choose to manually manage your music, then you'll need to drag music from wherever (My Computer or from your iTunes library) onto the icon for your iPod. However, if you choose to automatically manage your iPod then sort out your music libray and add the music you want. Then, go to the "File" menu and hit "Sync iPod". The computer also does this automatically whenever you plug the iPod in.
Hope all that helps!
Jan 15, 2011 | Audio Players & Recorders
Tip
How to use your iPod to move your music to a new computer
***** THIS DOSE NOT WORK WITH IPOD TOUCH OR IPHONE*******
open itunes connect ipod
from the summer page at the bottom
put a check next to manually manage music and video
ok - close itunes
go to : start > my music > itunes
right click on itunes folder and select copy
go to : start > my computer > choose the drive of the ipod > then right click >Paste
take your ipod to a new cpu
connect ipod
go to : start > My Computer > choose the drive for the ipod > find itunes folder > right click on it choose cut
go to : Start > my music
If there is an existing itunes folder in here delete it unless there is music in the library - this will remove the existing library
right click > paste
after you paste it - restart the computer
( download itunes if you have not already )
open itunes and all your music and playlist will be here
if you get a message the the library was created from an old library then follow this step to resolve
http://support.apple.com/kb/ht1451
on Apr 15, 2010 | Computers & Internet
I am having trouble adding new material to my ipod shuffle I bought this last year and it is one of the matchbox sized ones I'm not sure what you call these. I tried to add some music to this on my home...
When you initially set up your ipod on one computer and then plug it into a different one, it will ask you if you wish to sync the songs with the new computer.
THIS WILL WIPE OFF ALL OF YOUR SONGS!
If you wish to manually drop and drag songs, you can do this as well and it will ask you if you want to use your ipod like a disk (like a flash drive.)
My suggestion is to import all of your songs you want on your home computer. You can drag songs from your "Library" to your ipod, simply select and drag them to the ipod icon.
If you want to charge your ipod at work just plug it in, don't click anything and then eject it. Or click import songs manually.
http://repair-scratched-ipods.blogspot.com
www.huskyipodrepair.com
May 04, 2010 | Apple iPod shuffle MP3 Player
Ipod nano 4th ger. was download from a differt computer,trying to download new music from my computer to ipod and ipod will not show up on itunes.
yes it wont...plug it back to d original computer..open itunes...click on ur ipod icon..change d settings to manullay manage files or music...then u can plug it to any pc
Aug 31, 2009 | Apple iPod nano
Cannot put movie from i-tunes on 3rd geneation i-pod nano
I just had this issue- I bought a movie off iTunes, and could view it on the computer, but it wouldn't go on to my iPod. I looked around and found instructions to open iTunes and on the home page of your iTunes where it shows you how much space you have, you can restore original settings, etc., if you click on "manage iTunes manually" or "manage music and videos manually" and then click apply you will be able to move your movie on to your iPod. In your iTunes library you just have to drag and drop the movie onto the iPod icon that appears in the left menu when your iPod connects to iTunes. It took about 10 minutes for mine to fully upload onto my iPod- so make sure you wait to disconnect until it tells you to. I hope this helps! What I read is that when managing the music and videos manually instead of it doing it automatically, you can move the videos and music as you'd like.
Jan 03, 2009 | Apple iPod nano
Grays songs in ipod when connected to Computer
You need to set your iPod to update manually, instead of syncing automatically when you plug it into the computer.
To do this, plug your iPod into your computer, and on the iPod info screen that pops up in iTunes when your iPod is connected, click "Manually Manage Files."
You'll now have to click and drag your songs from your library to your iPod, but now you can also play songs on your computer directly from your iPod and delete songs from your library without deleting them from your iPod at the same time.
Hope this helped!
Sep 05, 2008 | Apple iPod MA446LL/A MP3 Player
Apple iPod nano 3rd Generation Logo
175 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Computer Repairing
Computer Repairing
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
