Question about Akai LCT2715 27 in. LCD Television
Will not go on
Timer light is on and that is all that works can not get menu or any thing.
if you have a book on it let me know
  • GIXXER750 Dec 17, 2008
    THIS TV IS **** MINE TURNED OFF AND WONT COME BACK ON
  • 30 Answers
These TV's are prone to power supply failure and this sounds like it may be the case for you. I offer to repair/recondition the power supplies in these TV's for a flat rate and I also have an instructable on how to remove the power supply located here (http://www.instructables.com/id/AKAI_LCT2715_Power_Supply_Removal/) If you are interested in having your power supply repaired you can contact me in my profile (http://www.fixya.com/postBuddyProblem.aspx?budid=763646)
Posted on Dec 18, 2008
Temp and lamp lights flashing
can you let the projector work well
if the projector projects the image,
does the projector light?
if the projector work well ,but the indicator lights flashing,that means the projector is ok ,
you only need to reset the timer of lamp and to reset the timer of the filter,
menu-setting-advance-reset-the timer of the lamp
menu-setting-advance-reset-the timer of the filter
Apr 28, 2014 | 3M S15i 165Watt 2000Hrs HSCR Projector...
How do I select between media use
Perhaps you ask this question in the category Digital video cameras? This category was reserved for camera flashes. You know the thing that gives a bright light for a short time?
Nov 15, 2013 | Panasonic HC-X900M HD camcorder with 32GB...
I have an HP 2709m full lcd monitor and it shows osd lockout and I dont know how to unlock it. Ive tryed doing it with the menu with know help. I have to shut it down and then turn it back on and it works...
the manual say push the menu button for 10 seconds, and it unlocks.
sleep mode too go in and turn off power saver
its clock timer that and goes to sleep on time inside the monitor
why not read the manual costs nothing to read
at hp
http://h10032.www1.hp.com/ctg/Manual/c01725831
read page 25
and then read
page 27
amazing no, books, yah, books are so OLDSKOOL
Dec 31, 2017 | HP 2709M Monitor
CAN ANYONE HELP i'm having a problem keeping the timer from going off and shutting the whole tv off. My kp-46wt510 sony widescreen from 2003 is doing the same thing, picture is bowed in the middle and...
Most likely you have turned on the sleep function. 2nd button from the left on the top of the remote hand unit. Keep pressing until "sleep off" appears on-screen.
Or
Timer in user's menu is activated to turn off TV a specific time. Go to timer menu and adjust timer, then push cancel on the remote, this should reset timer to zero. Same with current time, adjust and select cancel, this should reset current time.
If you do not have the original remote, you are in trouble. Service tech will have remote.
easyab
Feb 23, 2011 | Sony KP-46WT510 46" Rear Projection HDTV
Turn signal lights are not working...
read your owners manual, go to the back of the book and then look for fuses, go to page and the book should tell you every thing you need to know
Feb 24, 2009 | 1995 Volkswagen Jetta
Turn on the TV and only Timer light is on , no sound & picture
after holding down the menu and device the led will blink a two digit error code such as 3 blinks pause then 4 blinks then repeat that sequence a couple of times. Need that blink code to help let you know whats going on. The 34 code means lamp abnormality which translates to the power Pwb capacitors have most likely failed.
Jan 23, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Blinking timer light nothing works
have you tried the menu and device buttons held in together to activate the led error code feature? Let me know the error code.
Jul 05, 2008 | Mitsubishi WD-52525 52" Rear Projection...
I lost my book for my camera and i wanted to know how to set the timer on it
Some cameras have a dial for shooting modes so look for a three quater circle with a timer arm or just go to the menu settings you should see it there. If no luck with either, the easiest way to get the book is visit the manufacture web site. Most major brands have a support tab where you can get the manual. On another small note, when asking questions being specific on the brand/model of a product will generate more responses.
May 21, 2008 | Cameras
Why won't it work?
I had the same problem with mine. Set your timer and then hold the start/stop button until the light in your timer starts flashing, it will then start warming up.
Oct 12, 2007 | Maximatic MST6000 Slow Cooker
Akai LCT2715 27 in. LCD Television Logo
Top Akai Televison & Video Experts
Jaime Hernandez
Marvin
Marvin
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
