Question about Maytag MTB1504A Top Freezer Refrigerator
Freezer not getting cold
I have a maytag performa fridge that has the freezer on the top. about a week ago we heard a hissing noise, kinda like water being dropped onto something really hot, since that happened our freezer is not staying cold. the temp is cranked all the way up yet my popcicles are squishy instead of frozen solid... please help
  • suzytee Dec 28, 2008
    Purchased my Maytag less than 4 years ago - always sounded like it was demonised from the day I had it installed. Hissing when the ice dropped onto the element. Then about 6 months ago it stopped doing that noise. Then in November the freezer wasn't freezing and the food storage was getting warm. Had a part replaced only to have it freezing everything 4 days later. Now only 4 weeks later it got warm again. First round was 2 days before daughter's wedding, 3rd was 2 days before Christmas. Not happy and lots of food wasted. Bad advert for Maytag to say the least. Now have to wait until Jan 2 to get a technician look at it!!!!!!!!!!!!
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 7 Answers
Sounds like you heard the heating element melting ice as its supposed to do so your frost free feature / defrost is working. After that the melted water has to drain down the tube, in the pan underneath, to be dried by the fan. Possibly there is still ice blockage blocking that drain hole. Sucks (unplug and let thaw out for 48 hours...move food naturally) ...or...take apart the back panel / wall in freezer...see...heat gun / hair dryer. Hot water down that drain also till you see it run smoothly down into the pan.
Posted on Dec 05, 2017
    Top Expert:
  • Maytag Master
  • 53,733 Answers
Get in a technician to check gas pressure as the noise may have been gas escaping
  • 10 Answers
SOURCE: Maytag MSD2454GR
compressor relay shot. needs ground wire to frame of fridge also.
Posted on Sep 28, 2008
  • 101 Answers
SOURCE: My refrigerator is not getting cold
You should try to clean the coils under the fridge . Thats a simple thing to try .If your fridge /freezer cant remove the heat it wont cool ,also please make sure your doors are closing tight. We can start on all the free things you can try first..
Posted on Dec 14, 2008
  • 686 Answers
SOURCE: fridge is warm even when i adjust temp. control.freezer is good.
if your fridge has 2 set of dials one numbers and the other letters than you need to adjust the dial that has letters on it. If the fan in your freezer is not blowing, then it won't force the cold air from the freezer to the fridge. Make sure fan blows then adjust the letter knob.
Posted on Feb 17, 2009
SOURCE: I have a maytag MSD2754GR, the freezer bottom is all iced
The drian hole has become stopped up and ice has accumulated in the the drian hole. You will need to unplug the fridge and remove the cover on the back (located at the bottom, 6 screws). On the freezer side there is a drian hole with a rubber 90 and a clear line that runs to the drain pan. Remove line and unstop. Don't not put the line back on yet.
Now for the fun part, remove the basket and the two bottom shelves from the freezer. Half way up the back there are 2 screws that need to be removed. After removing screws pull up on the top cover to so you can remove the bottom cover. The bottom cover maybe froze to the coils and to the inside drain pan. Break the ice with a butter knife, and remove cover ( do not hit the coils). Now you need to break the ice that is froze to the the pan and under it. Once you have remove all the ice you will see the drain hole, use a small pointed object to break ice that is in drain hole. Now you can put the drain line back on and make sure that the other end is in the drain pan under the fridge. Now reassemble the fridge and plug it back up.
It took me about 20 minutes to do this.
Hope this helps.
Posted on Sep 11, 2009
SOURCE: Maytag Performance PTB1953GR making buzzing noise
refrigerator and freezer not getting cold
Posted on Mar 09, 2010
Maytag Performa PTB2153GR making a clicking noise and food is thawing in freezer, fridge not staying cold
check no ice around pump unit. then try manual defrost both.no hot water. clean filters/drain holes.dry as best you can then switch on.
use thermometer to check temp -20c in freezer
Feb 07, 2010 | Freezers
My performa refrigerator,on top,of unit is freezing all the food .where should the dial be set?
The fridge section shouldn't ever freeze anything.
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Sep 02, 2009 | Maytag Performa PAV2200
Fridge is not cooling
A failed start relay could be the culprit. The relay/overload assembly (12555902) and the run capacitor (C8931612) should be replaced.
Be sure to unplug the refrigerator prior to service.
Apr 27, 2009 | Maytag MBB2256G Bottom Freezer...
Maytag msd2456dew not cooling / not freezing after noisy fan
my Matytag msd2456dew fridge fan is running, no ice bulid up on coils in freezer section, but no cold air to freeze anything in freezer section or cold air in fridge section. what can be the problem?
Sham
Feb 15, 2009 | Maytag Refrigerators
Fridge and freezer not cold
It happenedn to my performa fridge just yesterday. It was bought in 2005. Now there is humming and clicking sound from the lower back side once in a while and the fridge is not cold. the compressor is hot/warm and it seems to be where the noise is coming from.
Jun 21, 2008 | Maytag Performa PAV2200
Maytag MTB1504A Top Freezer Refrigerator Logo
105 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Marvin
Marvin
Carlos Alvarez
Level 1 Expert
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
