What is basic difference between dual core and core2dual
Memory wise,speed wise
  • 57 Answers
Technically there is no difference depending on the different one you get. They will all function the same but there are different speeds that you can find out by searching for Dual Core Processors.
Posted on Dec 16, 2008
What is the main difference between a dual core CPU, and a Core2 Duo CPU ?
A dual core processor has two cores (essentially, two CPUs on one chip). Core2Duo is a specific dual-core processor design. Thus, all Core2Duo CPUs are dual-core CPUs, but not all Intel dual-core CPUs are Core2Duo designs.
Essentially all current Intel consumer dual-core CPUs today are Core2Duo designs. They have different names, but vary mostly in terms of their FSB speed (mostly, how quickly data can be transferred to/from RAM) and in the amount of cache memory in the CPU (cache memory is a relatively small amount of high-speed memory on the CPU chip that stores frequently-used data and instructions; it can improve performance 4-15% or so, depending on the amount).Best Regards, Luis.
Mar 02, 2012 | Computers & Internet
Acer aspire m5100, AMD Athlon 64bit x2 dual core processor 5000+ 2.60Ghz. Win Vista Business 64bit. When i upgrade and put more than 3GB of ram into the machine, it turns off the lan and my display driver...
Acer official site says:-
Up to 4 GB DDR2 533/667/800 MHz SDRAM
(dual-channel support on four DIMMs)
Try these bus speeds and for dual-channel support read this article :-
Dual-channel architecture requires a dual-channel-capable motherboard and two or more DDR, DDR2 SDRAM, or DDR3 SDRAM memory modules. The memory modules are installed into matching banks, which are usually color coded on the motherboard. These separate channels allow each memory module access to the memory controller, increasing throughput bandwidth. It is not required that identical modules be used, but this is often recommended for best dual-channel operation. It is possible to use a single-sided module of 512 MB and a double-sided module of 512 MB in dual-channel configuration, but how fast and stable it is depends on the memory controller.
If the motherboard has two pairs of differently colored DIMM sockets (the colors indicate which bank they belong to, bank 0 or bank 1), then one can place a matched pair of memory modules in bank 0, but a different-capacity pair of modules in bank 1, as long as they are of the same speed. Using this scheme, a pair of 1 GB memory modules in bank 0 and a pair of matched 512 MB modules in bank 1 would be acceptable for dual-channel operation.
Modules rated at different speeds can be run in dual-channel mode, although the motherboard will then run all memory modules at the speed of the slowest module. Some motherboards, however, have compatibility issues with certain brands or models of memory when attempting to use them in dual-channel mode. For this reason, it is generally advised to use identical pairs of memory modules, which is why most memory manufacturers now sell "kits" of matched-pair DIMMs. Several motherboard manufacturers only support configurations where a "matched pair" of modules are used. A matching pair needs to match in.
Good luck
Rate the solution if got help
Dec 06, 2010 | Acer Aspire M5100 AM5100-U5313A AMD...
AMD 64 x2 dual core processor 3800+ speed problem.
increse your RAM to a heigher one.it is necessary to load large graphics.or insert a graphics card
Aug 19, 2009 | AMD Athlon 64 X2 3800+ Dual Core Processor...
WHAT IS THE DIFFERENCE BETWEEN THE INTEL CELERON 450 AND THE INTEL PENTIUM DUAL CORE
HI,
The celeron you are looking at is single core
The pentium you are looking at is dual core (this is the one you want)
They are both physically the same size, and have the same speed, but you will get ALOT better performance out of a Dual core. A Pentium Dual-Core is a real production chip, where the Celeron series is just the chips that weren't good enough to be Pentiums. Much cheaper in quality ENJOY! RATE THISOLTUION
RNJ VINOD KUMAR
Jul 15, 2009 | Dell Computers & Internet
Dual Core VS Single Core
basically it depends on the Bus speed of the processor. if u r using the single core processor with high bus speed it means u r using faster one then the low bus speed core 2 duo. n the other thing is depends on the system memory (ram), if the Ram is compatible with Processor speed n processor bus speed, ur pc will work faster...
good luck
shafky
Jun 15, 2009 | Computers & Internet
Difference b/w Core to duo and daul core
Core 2 Duo is a Brand name by intel to identify his class of Dual core CPU
a Dual core CPU is basically two CPU in one package, which dramatically improves performance over previous architectures.
Pentium Dual Core is another brand name by Intel to identify his new entry level CPU offer.Basically Pentium dual-core are similar to Core 2 Duos except they(pentiums) are slower and cheaper.
they both are dual core CPUs.
I would prefer a core 2 Duo having to choose a laptop because of better performance, but the prize is different for the two solutions.
Jun 28, 2008 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
CPU
Nothing!!:) They are both dual core cpus but core2due are the intel brand and dual core are the amd ones. Intel are the top ones just now if you are into overclocking but some of the amd ones are better if you are not.
hope this helps?
Jan 06, 2008 | Computers & Internet
Computers & Internet Logo
63 people viewed this question
Alun Cox
David Payne
David Payne
