Question about KDS Radius RAD-7c 17" Flat Panel LCD Monitor
KDS radius 17"LCD RAD-7C shuts off during boot and won't come back on (mostly)
I have been using the same 2 KDS monitors side by side, on my pc for several years. About a year ago I began having a problem with one of them. I would turn on the pc, and both monitors. The "bad" monitor would light up as normal at this point. As the boot continued, and the screen went black (normal in booting) it would go into standby (yellow led), but would not come back on. Attempting to "reboot" the monitor didn't work. I have tried swapping the monitors to verify it is the monitor, and it is. For a while I simply waited until the computer was already booted to turn it on. Eventually I had to use a line power switch to turn it on. This got worse until now it does not come on at all even though the led is on, and green, the screen is black with no light at all. I now have the thing apart, and I suspect a power supply capacitor is the problem, but I don't know which cap to check. Checking them in circuit is not reliable, and taking them all out would probably ruin the circuit board. Part numbers on the board are typically TC1... TC19 etc. for caps. Any advice, drawings, or info would be apreciated. Thanks in advance, Mike, AKA pcrider
  • Mike Brooksher Apr 05, 2007
    At present I plug it in, the green light comes on, but nothing else happens. Pushing the power button does not turn the green light on or off, its just on when you plug it in. If I unplug it for a few moments when I plug it back in the green light is gone, and won't come back on unless I leave it unplugged for about 24 hours.
    I see on what apears to be the back light power supply board it says 11v-0 94v-0 I am not seeing 94 volts anywhere on this thing.
    I have a good meter, and a basic knowledge of electronics, but without schematics, or some test point info I'm afraid its hopeless.
    Help if you can,
    Thanks for looking,
    Mike
I am having the same problem and this seems to be very similar to the problem these users are having but that is a different screen. So I was hoping someone would have more info on this specific monitor. I am seeing no budging capacitors on my boards.
Posted on Jun 12, 2007
KDS Rad-7c struck by lightning
try to use another monitor power cord if is can turn on, otherwise immediately contact your monitor manufacturer to repair such device since it was struck by lightning
Dec 06, 2011 | KDS Radius RAD-7 17" Flat Panel LCD...
Hello, I have a Kds Radius RAD-7C monitor and the original power supply is no longer working. I have a universal power supply with a range from 15 to 24 volt and 6 amp, my question is, can I use this for...
6A is OK, HIGHER CURRENT is OK but not higher voltage, the main key is that the pwoer supply MUST be REGULATED power supply. Does it say that on the universal power supply that you have?
Basic LCD monitor and LCD TV troubleshooting guides:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed LCD monitors, LCD TV's pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Dec 20, 2010 | KDS Radius RAD-7 17" Flat Panel LCD...
I bought a used KDS 17" color monitor, Rad-7,
I agree that the overheat was the supply being too small. Not only the voltage rating is wrong, but I'd bet the amperage is alsotoo low for correct operation. Check this link. I have bought power bricks from them for laptops, monitors, and power tools - all good quality without breaking the bank. They ship pretty quickly as well. http://generalsaving.com/productfile/G_LCD12V3A/1000/G_LCD12V3A_z_0157.php
Jun 08, 2017 | KDS Radius RAD-7 17" Flat Panel LCD...
Brightness!
mcdevito75 here, You can try this, 1 of the buttons should say AUTO presss this button and the monitor will automatically adjust, and Or press the MENU button and see if there"s a brightness feature, I believe there is, you can use the little arrows on your monitor within the MENU options. First try the AUTO.
Jul 04, 2010 | KDS Radius RAD-7c 17" Flat Panel LCD...
Lost the instructions - don't know how to adjust color and resolution - what the buttons on side are for. Actually this is a RAD-7c, model 780 mfd Jan 2003, probably starting to fail.
The buttons on the side panel is are the ones you need to do the color adjustment and resolution. One of those buttons is the Menu, two of those buttons are used for selecting the options from the menu and maybe another pair of buttons to adjust the selected option to increase or decrease.
Jan 02, 2010 | KDS Radius RAD-5c 15" Flat Panel LCD...
Power plug to monitor??
This model uses an adapter shown here. I also included one link to the cheapest price I found.
And here's that link I mentioned.
Computerlogin.com
Sep 21, 2009 | KDS Radius RAD-7c 17" Flat Panel LCD...
KDS product 17s, model 700p. I am getting the follwing message "mode not supported H 82.8khz V77.7hz" whenever I boot the computer. I cannot escape from the message. The computer it is attached to is...
Start in SAFE mode (press F8 wile booting) and choose SAFE mode from the menu to see if it works in Windows DEFAULT setting. Then reboot and reset to 32Bit, and 78Hz max.
My guess is that MSoft pushed a patch or SP to your box and IT replaced the dll your monitor was using.
Good Luck!
Let me know if this fixes it
Mar 26, 2009 | KDS Radius RAD-7c 17" Flat Panel LCD...
KDS Radius RAD-7c 17" Flat Panel LCD Monitor Logo
188 people viewed this question
Top KDS Computers & Internet Experts
Siul Oyaratgam
Steve Allison
Steve Allison
Marvin
Marvin
Are you a KDS Computer and Internet Expert? Answer questions, earn points and help others
