Question about GE Monogram ZICS360NR Bottom Freezer Refrigerator
GE Monogram Condenser Fan Motor
Our GE Mongram ZIS 42D - built in seems to need a Condenser fan motor. It stops daily now and we restart it to keep things cold. My question is, is there an inexpensive solution or do we need a service tech to replace the motor and is there are range of costs for that type of service call
  • Rythum Dec 20, 2008
    The freezer side is cold, the fridge side is warm,.........please advise.
aborcass
  • 2651 Answers
SOURCE: My monogram refrigerator leaks water
you have a blocked/frozen evap drain tube leading to the pan, located directly above the freezer section. in all honesty donot believ this to be a repair homeowner should attemp i would contact an authorized ge servicer.As a maytg/ whirpool servicer myself , i know in our built in refigs we have new heated drain tube/evaporator pans that we installe possible that GE has as well
Posted on Mar 14, 2008
  • 184 Answers
SOURCE: GE monogram side by side built in refrigerator: fan behin Climate control drawer makes noise when it starts
IS THE NOISE SOMETHING HITTING THE FAN BLADE?
CHECK THE FAN ASSEMBLY BY REMOVING THE BACK PANEL IN THE FREEZER COMPARTMENT.
NORMAL NOISES IN THE UNIT ARE A GURGLING NOISE OR THE SOUND OF RUNNING WATER OR HISSING. THIS IS DUE TO THE FREON BEING PUSHED THROUGH THE SYSTEM AS THE COMPRESSOR RUNS. POPPING OR SNAPPING CAN OCCUR WHEN THE COILS IN THE FREEZER MOVE DUE TO A CHANGE OF TEMPERATURE.
Posted on Apr 08, 2008
docjohn174
  • 943 Answers
SOURCE: GE Monogram side by side freezer and refrigerator
HI thanks for your question. the problem could have been, a defrost timer, stuck on defrost. or a failing thermostat. keep a close eye on it, if it stops again. get in touch and we fix the problem. thanks
Posted on Oct 15, 2008
  • 358 Answers
SOURCE: condenser coil fan not runningon GE pds22scrrss
The fan can rotates freely even if there's no power to it(fan probably burn out).You can check if power is going to the fan motor by folowing the two wires fron the motor picking up power from the compresor connections under a black plastic cover on the side of the compresor.If you nave power going to the fan its needs to be replaced.
Posted on Apr 26, 2009
SOURCE: GE side by side refrigerator. Fridge side not cooling - help!
Hi, they have changed lots of parts, were they defected, did they tested parts for faults or they just change parts, because it's available, there's always a reason why a certain part, go bad. so far you change most of parts in ref. check refrigerant (gas, freon) pressure, check compressor, for faulty suction and high side valve, it's possible your compressor loosing efficiency. or say if compressor normally pump 50 psi. now it's pumping 40 psi. is the refrigeration cycle balance ? is there restriction in your ref. system? is compressor running long enough? plug on ref. let it run for 1hr, listen to compressor for any clicking sound, fans and everything else could be working, be compressor not, compressor could be short cycling (not working long enough) also check voltage in receptacle(outlet) with digital multi-tester, get accurate voltage reading, let me know, could also be a faulty circuit breaker in house (building) not your ref. let me know, system could have very slow refrigerant leak, you could have a very small (slow) gas leak, that's why your refrigerator get hot first, then your freezer, there's a condensate line (loop) that passes through, ref body, close to doors to prevent door gasket from freezing, after few years sometimes develope leaks, cause by rusting. it's very possible there could be small leak in your system. let me know what happened.good luck.
Posted on Aug 14, 2009
GE monogram buildin refrigerator - climate control drawer cannot hold the temperature as set for meat. It always shows at 47F.
sounds like the damper door down there is not opening also the fan down may not be coming on to bring temp down to 32.
Sep 17, 2014 | GE Monogram ZISS420NRSS 42" Built-In...
My GE Monogram side by side built in refrigerator will not freeze ice or keep food frozen. It stays just under the freezing temperature. The refrigerator portion seems to work. Can anyone help?
its possible that its either short of gas or the little fan motor in frezzer/fridge is not working,but if its only making ice now and then its sounds like a gas shortage
Aug 28, 2012 | GE Monogram ZISS420NRSS 42" Built-In...
Model# gsh22kgmcbb. everything thawing out.coil was covered in dust, cleaned as best i could. fan motor running kind of slow,i think.
Are you talking about the Condenser Fan at the back of the fridge next to Motor/Compressor.
If that is running slow it means the fan motor bearings and lubricant inside the fan motor has turned into a sludge which is a common problem. Need to replace the condenser fan motor. You can put a normal household fan behind the fridge to cool the compressor in the meantime.
Ash
Sep 06, 2011 | GE Monogram ZISS420NRSS 42" Built-In...
Ge monogram zisw42emd, evap fan not coming on, Units been down a week, compressor seized,installed start kit. Compressor running 2.5 amps pressures 25/105 Replaced coil thermostats, evap fan not running.
that back pressures sound high to me and the hi side sound low may have a bad compressor not pumping right should run around 0 to 5 low 125 to 150 hi hope that helps
Oct 06, 2010 | GE Monogram ZISS420NRSS 42" Built-In...
GE Monogram Built-in refrig has blocked evaporator drain.
You should be able to see the drain under the coil. Part 804 on this diagram. Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing.
Aug 25, 2009 | GE Monogram ZISS420NRSS 42" Built-In...
Vertical divider separating the refrigerator section from the freezer section is extremely hot to the touch on the exterior surface. So, hot it almost burns your hand. What could this be and how would I...
The fan behind the fridge at the bottom which cools the compressor , is not turning . Remove the back panel covering the compressor and see if something is blocking the blade . If not , motor is bad , so put a small fan there to keep the coils and compressor cool until you can get a new motor .
Aug 09, 2009 | GE Monogram ZISS420NRSS 42" Built-In...
Refrigerator is not getting COLD
clean the coils on the back of the fridge and make sure the condenser fan is free and running normally. that is the fan at the back of the unit on the bottom where the compressor is. if it cant ge rid of the heat, it wont cool. also make sure the the fan that supplys the cold from the freezer to the fridge is working.
Jul 21, 2009 | GE Monogram ZISS480NRSS 48" Built-In...
Ge Monogram ZISS420DMAS compressor and fan not running
ICE CREAM WON'T FREEZE
The ice cream does not freeze, it stays soft. I have a GE Monogram 42" Built-in-Side-by-Side Refrigerator.
Nov 28, 2008 | GE Monogram ZISS420NRSS 42" Built-In...
Refrigerator is not cooling well nor freezing well
hi. did you check the freezer fan motor, or for frost build up in freezer
Oct 02, 2008 | GE Monogram ZISS420NRSS 42" Built-In...
Apr 08, 2008 | GE Monogram ZISS420NRSS 42" Built-In...
GE Monogram ZICS360NR Bottom Freezer Refrigerator Logo
247 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
