Question about Brother IntelliFAX 1800C All-In-One Printer
Fax machine says error 41 unplug and call brother.
  • 470 Answers
Okay,here's the solution it is not a copy paste, its my own experience to repair ERROR41,, follow the instruction carefully.......
http://www.fixyourownprinter.com/printer/13/12131.html
I took out the print head, cleaned it with alcohol, and put it back in.
At first the copier would work, the fax seemed to be working (I didn'ttry but the functions worked up to the point of sending) but theprinter would not print. I kept getting an error message saying tocheck port, couldn't find printer, yada, yada...
I removed all software and then reloaded it and it seems to be working fine.
It does say that my cyan is almost empty which it said before I got theerror 41 message, and I did change it before doing anything else. Kindof weary of touching the print head but hopefully it will be okay.
Anyone interested in trying, here is what I did (thanks to the folks on the archived thread)....
To get the print head in the center after the error 41 message appears,unplug machine then plug it back in. As soon as you hear it moving,open the cover and grab the print head before it gets stuck inside.Once the error 41 message comes backs, it is almost impossible to getit to the center so that you can remove the cartridges and the printhead itself. Hold on to it until it stops.
Remove the cartridges.
On both sides of the print head is a clip. Long skinny piece of metalwith an eye at the bottom. Push/pull these and then pull the print headtowards you and it will come right out.
Mine was coveredwith ink on the bottom where the two copper strips are. I wiped theseoff as suggested in the other thread but it only worked long enough forit to clean the ink, then I got the error 41 message again.
I then repeated taking it out and cleaned the holes with a q-tip dippedin alcohol. They were so full that I didn't see how big/deep that theyare. There were actually ink flakes that came out. So I think the inkis drying inside and possibly causing the problem. That is my opiniononly after what I saw with mine.
Wipe it so that it is dry and replace print head, ink.
I unplugged mine before I replaced the print head and ink.
It started to clean right off. That is when I had to reload software and then it worked fine.
regards JAN_yuanjia
Posted on Dec 15, 2008
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Your concern is Print Head for Machine Error 41 (ME41).
A known/common error to this series. I was made to understand that "Brother will repair it for error 41 for 30 months from the date of manufacture. You won't need a proof of purchase. Contact Brother at 800-284-4329 and they can authorize the repairs or They will assist you on locating the nearest Authorized Service Center. If your product is within the extended warranty period, Brother will cover the repair cost to have your Print Head replaced. Brother has corrected the "Machine Error 41" error condition."
Good luck and Thank you for using FixYa. Happy Holidays.
    Sergeant:
  • 236 Answers
I can tell you that machine error 41 is an printhead error.
  • Dan
    Dan Dec 15, 2008
    I would try removing it and cleaning it before sending in for repair. Some reports of repairs costs are over the $200 mark.
  • Dan
    Dan Dec 15, 2008
    these comments here offer a good deal of info on how to remove and clean the print head
    http://www.fixyourownprinter.com/forums/...
  • 734 Answers
Check might be there is sum paper jaming in the machine.
Thanks
  • futureloginn
    futureloginn Dec 15, 2008
    please go to the following link for more info ----
    Thanks
    Master:
  • 479 Answers
Unplug all the connections and reconnect everything back.also checkout for any blocked paper or any paper jam.also remove and check out the cartridges from the printer and reinsert.either its the internal circuit failure error and has to be repaired to make it proper. thanks.
    President:
  • 2,110 Answers
There might be following problems
The head drive voltage has not been turned from Low to High within the specified time.
Causes could be the Carriage Assembly, Main PCB, Printhead unit or Power supply PCB.
So u have to take it to nearest service center...
4 Suggested Answers
SOURCE: Machine Error 41
Error code 41, Print cartridge is bad and gone out. Needs to be replaced by authorize dealer for just under $100.00 ($55.00 part & $40.00 Labor).
Posted on Jul 23, 2007
  • 121 Answers
SOURCE: wont print anything
Move the ink cartridge carriage (the printhead) to the middle of the printer like you're going to change cartridges.  Take out all the ink cartridges.  There should be two black springs on either side of the printhead.  Remove these and the printhead should pop out.  Clean the nozzels (the little parts that squirt out ink) and reassemble.
If this doesn't work, then you'll have to replace the printhead.
Posted on Oct 28, 2007
SOURCE: Error 41
code 41
Posted on Jan 30, 2008
I get error 41 how do i clear this problem
Sorry to say but the only way to clear out a error 41 is to have the print head replaced
cost around 150.00
Apr 20, 2009 | Brother Office Equipment & Supplies
Dear Sir I have a technical error 41 and i dont know what to do.
When did the problem start on the printer
Thanks
proton
Aug 06, 2008 | Brother Office Equipment & Supplies
My fax mfc3220c say message error 41 when I turn it on. It also say unplug and call brothers
Error 41 means there is a major problem with the printhead, usually
requires a print head replacement. My advice is to take it to a
Brother service centre while it is under warranty. If it's out of
warranty then it is cheaper to purchase a new, non Brother model. If you have been using non-Brother cartridges or refills, they can have too much water in them and it erodes the print head after a while. Usuall y just after warranty has expired!
Feb 18, 2009 | Brother MFC-3220C Plain Paper Inkjet Fax
Error 41 MFC 3220C
WELCOME TO THE ERROR 41 DELIMA. YOU WILL NEED A NEW PRINT HEAD, MAY BE U CAN BUY ONE FROM A BROTHER DDEALER AND INSTALL IT GOOD LUCK
Jan 27, 2009 | Brother MFC-3220C Plain Paper Inkjet Fax
Brother MFC 3100 Printer/fax
This is the only reference I could find on error 41: How can I clear the message Machine Error 41 from the display? (ME41)
Machine Error 41 indicates a mechanical malfunction of the Brother
machine. Unplug the unit from the power source and then plug it back
in.
If the error message continues to be displayed on the LCD, please call
Brother Customer Service at 1-800-284-4329 for assistance. The Customer
Service center is open Monday through Friday, from 9:00AM to 7:00PM,
excluding holidays If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Oct 16, 2008 | Office Equipment & Supplies
Brother MFC 3420C Printer/Fax
What do i do to fix Machine Error 41?
May 30, 2008 | Office Equipment & Supplies
Brother 1820 c error code 41
41 error for Brother generally means a printhead.  If I remember right, there should be two black springs on either side of the printhead (the thing that holds all the ink cartridges).  Take the cartridges out, unhook the springs, and pull the printhead out.
Clean it as well as you can with a damp cloth...especially where the ink squirts on to the paper.
If you put it back together and still get an error, you'll need a new printhead.  Let me know if you need the part number.
Oct 29, 2007 | Office Equipment & Supplies
Machine Error 41
Nov 14, 2006 | Brother IntelliFAX 1800C All-In-One...
Brother IntelliFAX 1800C All-In-One Printer Logo
212 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
