Question about Mitsubishi WD-62327 62" Rear Projection HDTV-Ready Television
TV, Mitsubishi WD-62527 comes on for sec goes off, error code 56
Television was working for a bit, now it comes on for a second and goes off. Status light and lamp light both come on and blink. Have pressed device and menu button and come up with error code 56. Lamp is relatively new, all fans work, filter was cleaned, was working fine and has beautiful picture when working, is it fixable?
  • jgarelick Dec 27, 2008
    My Mitsubishi WD-62527 turns on for aprox. 10 seconds with no picture and then turns off. I have tried pressing rest button but this does not help. Does any one have a suggestion?
    Genius:
  • 2,920 Answers
Have the flyback checked
Posted on Dec 15, 2008
2006 mitsubishi tv WD 62627. Tv wont come on i hear a click when I hit the power button. Blinks green on timer for about 60 sec then goes to solid yellow light on status. Error code 46.blew fan out.
Those blinks are fault indications. From the number of blinks occur at one time switch on, you can get an idea about the fault circuit section inside it. http://electronicshelponline.blogspot.com/ Visit the site linked here to know more details about the blinking codes.
Feb 18, 2017 | Mitsubishi Televison & Video
Mitsubishi wd 62527
hello there it could be a loose connector that u may have disturbed or broken look again inside if it worked before with
sound the chances are its ok
Jan 21, 2018 | Televison & Video
My tv a mitsubishi d 62527 the green light kees blinking
Called the blinking green light of death---set should if power lost when put back blink for 70 seconds or so---digital unit booting up.
About the only simple cause is in the main power supply are four 1000 uf caps that puff up and fail--provide boot up voltage.
follower power cord to supply and look for bad caps (they will be easy to spot) and see attached photos of what to look for.
Nov 06, 2012 | Mitsubishi WD-62527 Compatible TV Lamp
Mitsubishi wd 62527 blinking status light what can I look at? No Picture, Flahing TImer light goes off agter 2 min then tv turns off and if you power it on it flases Lamp and Status multiple times?
This is a common issue with bad capacitors in the TV. You can call in a shop or repair it yourself. You can google the parts using this number Z1234TV
Mar 31, 2012 | Mitsubishi Televison & Video
Turns itself off immediatley after turned on
mitsubishi projection TV turns off by itself after a couple minuts of viewing TV?
WD-62527
Apr 28, 2009 | Mitsubishi TS-5545 55" Rear Projection...
Yellow status light on mitsubishi wd-65733 tv
When tv goes out, press the menu and input buttons. The green light will flash with a 2 digit code.
Jul 26, 2008 | Mitsubishi WD-65733 65" HDTV
Television
Press menu and the device buttons on the tv both in together and hold them in for 5 seconds and see if the led will blink a two digit error code, then let me know the blinks.
Jul 06, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Tv 62527 light goes off when after a few seconds when turned on
This is generally a Power Supply problem, usually the SMPS so it's replacement or repair.
Jul 15, 2007 | Mitsubishi WD-62327 62" Rear Projection...
Mitsubishi WD-62327 62" Rear Projection HDTV-Ready Television Logo
305 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
