Question about Toshiba Satellite A105 Notebook
Dropped Toshiba Laptop...
I dropped my Toshiba laptop from about a foot and a half off a table and onto a hardwood floor. The Device was in sleep mode when dropped and now when i try to boot i get ethier a "boot mgr error" or a "disk error".
I tried the windows repair solution on it and it didn't reconize any current OS's being installed. When i tried to just freshly install windows i got an copy error. Any suggestions? Is the hard drive a bust or is it something else.
Thank you for your timr
    Scholar:
  • 46 Answers
Very good guess. If the computer is turning on and going through POST and it's coming up with that error, then it's the hard drive (hopefully not the platters).
If it makes noise (like clinking or grinding on startup), then you may be done for.
If it makes no noise (not even a hum) then the spindle isn't starting or may be stuck.
If it sounds fine, then it's the platters, and that's something on the microscopic level to fix.
You could google disksavers, they are an expensive company, but they have the correct means to save your data if you really, really, really, want.
Otherwise, if you have nothing to lose, take the hard drive out (usually there are some screws on the bottom which lock the hard drive in, just unscrew and simply pull it out, when the lappy is OFF) and put it into an enclosure (a seperate thing you can pick up for 20 bucks and return later if the hard drive really is bust. You can get them from most places, just make sure to bring your hard drive so they can help you with finding the right connector),
After it's good to go, plug it into another computer.
If you can't read from it (even with the additional power provided by the enclosures power cord(usually usb powered too)) then you can try putting the drive in a ziploc bag, and freezing it in a freezer for about 3 hours. Then try to read from it again (quickly).
If that doesn't work, then I don't know what to tell you mate.
Posted on Dec 15, 2008
  • Myke Prior
    Myke Prior Dec 15, 2008
    It needs to be able to read and write from the platters, which is why you can't install anything anyways, probably not even erase.
Dropped my HP D7 laptop. It slid out of my backpack from about 2 feet onto hardwood floor. On bootup, lights turn on for the keys and around the touchpad perimeter, and everything works fine with an HDMI...
You possibly cracked your screen or caused the ribbon cable to disconnect when you dropped it and just can't see what the error codes are saying. Is probably asking you if you'd like to start in safe mode with the beeps but you can't see it with a cracked screen or disconnected ribbon cable. Take it to a repair shop for a diagnosis.
Aug 29, 2014 | Computers & Internet
Dropped my remote on floor and now no buttons work
your batterys probably got loose inside the remote. take the battery cover off and push them back into place.
Jul 13, 2012 | Samsung TV Remote Control
Dropped off a glas of water on my toshiba laptop and now it's not longer turning on
Given that your laptop is not water resistant, the water probably leaked onto the mainboard, fried it thus rendering it unusable. Replace any of the fried part (usually the mainboard is one-piece, so sending it to advance circuit technician is advised).
Dec 14, 2011 | Toshiba Satellite P35-S611 Notebook
Dropped our Toshiba PA2611U external floppy
check all the cables. if you can open the case without breaking it, check all connections inside ensuring no broken visible links from the drive to the connections on the back. retry it in the computer after reassembling. IF it requires more than this effort it needs to be replaced.
Jun 03, 2010 | Toshiba PA2611U External Floppy Drive
Dropped my laptop off the table. now it just won't do anything
go to bios,see your harddrive is there,if not get a new one
Apr 04, 2010 | Toshiba Satellite A105-S2712 Laptop
Hardwood Floor Repair.
take a damp washcloth and a steam iron
put the damp washcloth over the dent and iron the dent with the steam iron
that should slowly raise the grain
be careful not to get the iron too hot where you scorch the floor
and work slowly, don't get in a hurry
Jan 02, 2010 | Farberware Manual Hardwood Flooring Nailer...
I dropped my laptop
YESSS REINSTALL WINDOWS AND DRIVERS.....IF THIS DOESNT WORK..U HAVE INTERNAL DAMAGE GL
Aug 30, 2009 | Gateway MX6421 Notebook
Toshiba satellite a75-s209
Probably not. Not only could the motherboard could be damaged but so could the keyboard, hard drive, CD/DVD, the cabinet, and possibly the screen.
It would take several hours of repair work and if you notebook hasn't been made in a few years it may be hard to get a mother board.
Jul 17, 2008 | Computers & Internet
Laptop HP Compaq nx9420 Screen goes Blank
From the Symptom you described, it seems like the thin video cable's connector is loose and is barely connected to the video adapter on the motherboard. You won't be able to tell until you remove the Keyboard and/or the Palmrest to check it. Also, there is a slim possibility that the Laptop has knocked something loose and is going into sleep mode. Normally, a Laptop user can configure it to go into Sleep mode or 'Hibernate'. These settings can be found in the Control Panel under 'Power Settings'. http://www.Computer-Repair-Today.com
Jan 06, 2008 | HP Compaq nx9420 Notebook
Lightly Dropped Seagate 100GB External Hard Drive
Unfortunately, this probably means the read/write heads were jarred and can no longer function properly. That's usually fixable, but it's a very expensive fix because the parts are inside the hard drive and the data surfaces are very delicate... Most people are better off simply replacing the hard drive unless the data is absolutely vital.
Dec 06, 2007 | Seagate USB 2.0 External Enclosure + 400GB...
Toshiba Satellite A105 Notebook Logo
110 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
