Question about Goodman GMS90703BXA Heater
Blower fan I installed a goodman gmp050-3 heater. lp not hooked up yet but the blower fan will not come on when set to fan only. can you help thanks
  • Stephen Evans May 11, 2010
    In order to have the fan come on by itself you need a minimum of 3 wires from the thermostat to the furnace. If you have no A/C you probably have 2. Steve
    Problem Solver:
  • 22 Answers
You could use only 2 wires, R and G terms all you would get is blower fan. so on stat make sure you connect to R and G also. also did it have a fresh air return and you miss hooking up those wires, i have seen that before.
Posted on Jan 09, 2009
Our Goodman furnace just started making a a very loud grinding noise when the furnace turns on. Also the temperature in the house keeps dropping so we have to keep adjusting teh thermostat. Any advice on...
If it makes the noise before the blower comes on it would be the exhaust fan. If it makes the noise when the blower comes on then I would say either the blower motor or bearings to the fan.
Dec 27, 2010 | Goodman GMS90703BXA Heater
Have a 2 stage 70000btu 2 stage furnace by goodman. I have hooked up a honeywell steam humidifier. and when it calls for humidity the high fan speed does not kick in. The only fan speed that kicks in is...
Sorry to read about your problem, I hope this helps you out.
well its best to let the low fan do the humidity work, and not the high.. you did not provide the model of the goodman, but you ether went direct to the heater control card, to the humidity connection . or wired to the low side call contacts. you can hook the humidifier to the high fan speed contacts
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 24, 2010 | Goodman Heating & Cooling
I have a builder installed Goodman GDS80904BHA that is approximately 5 years old. Recently, when the furnace completes a heat cycle, approximately 1-2 minutes after the cycle has completed and after the...
I would guess that the fan off setting on your limit is set a little to high. If you have the manual you can see what it says about changing the running time for the fan after the burner has shut off look on the control board and you should see two switches,one to set the time for burners to fire before main blower starts and one to set time for fan to run after burners shut off. To help with the problem you are describing set fan run time up so fan wii run longer. Hope this helps. Thaks.
Nov 22, 2010 | Goodman GDS80904BNA Open Flame Heater
Blower will not shut off
That has to be in the board OR you might have the thermostat set to manual instead of auto. If you suspect the board remove the red wire from the motor to the board and see if the fan quits.
Jan 09, 2010 | Goodman GMS90703BXA Heater
Goodman model 135-5 furnace fan and induce motor run all time even with thermostat off. Theermostat and wire were replace
Is there a thermal Fan/Limit switch in this furnace? If so you may need to tweak the low range setting so it can turn off the blower.
Nov 04, 2009 | Goodman GMS90703BXA Heater
I HAVE A USED GOODMAN GMS8 FURNACE I HAD INSTALL IN MY HOUSE WITH AIR THE PROBLEM I'M HAVING IS THE BLOWER RUNS ALL THE TIME KNOW WHAT ???? HELP ME PLEASE
Check your themostat. The fan switch may be in the on position and not in the auto. If that is not the problem, try turning the power off to the furnace, wait 1 minute and turn the power on. It may have went into a lock-out which causes the blower to run.
Oct 14, 2009 | Goodman GDS80904BNA Open Flame Heater
Goodman furnace\ blower comes on,unasked
Sounds like the fan switch on the furnace is set to low. Turn power off to furnace, take door off of furnace look for a fan switch, it may be a fan - limit together. The limit settings should be approximately 160° to 200°, and the fan settings should be about 100° to 140° set it to 120° it it's already set there then you probably need to replace it.
Aug 03, 2009 | Heating & Cooling
Fan and heater run fine but fan does not shut off for a long time
Check the diagnostic indicator.
1. If the blower runs for hours make sure the fan switch on the thermostat is set on "auto".
2. The furnace safety system must be in lockout. This is the furaces way of telling you there is a problem.
3 Most common problem is a dirty flame sensor.
Feb 20, 2009 | Goodman GMS90703BXA Heater
The insulation used in the blower fan cabinet has fallen off
get a good can of spray adhesive and follow the directions on can....can get at most hardware stores! good luck!
Dec 11, 2008 | Goodman GMS90703BXA Heater
Blower starts ans stops
Your system has a number of blowers and fans. Are you refering to the "Room Air Blower"? If so, at what point does it start? 30 seconds after you turn the air on, 1 minute, etc...? Does it ever come back on? The more you help us with information, the more we can help you!
Jun 09, 2008 | Goodman GMS90703BXA Heater
Goodman GMS90703BXA Heater Logo
88 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
