Question about Fedders RDG40 Dehumidifier
Humidifier is very hot
The humidifier seems to be working OK in that it extracts water from the air in good quantities. However, it gives out what I think is an inordinate amount of hot air. What's more, the top of the unit cabinet is almost too hot to touch. The dehumidifier stands on a tiled floor and the floor near the unit has become very, very hot. I have recently switched the dehumidifier over to drain directly i.e. there's now no collecting bucket in the machine. Might this be a reason for the excessive heating?
    President:
  • 1,462 Answers
Doubt if there is a fault. if something gets cold ie freezing section then something else gets hot
Posted on Mar 20, 2007
The dehumidifier is getting cold condensation on the top outside of the unit and no water in the bucket. Model BGD-510A. I cleaned the filter and the coils and still have this problem.
Kathryn, if you are operating it in a basement application, the problem is that air temperature at floor level, is colder than at shoulder level. Dehumidifiers struggle to work at temperatures between 40 & 65 degrees F (Unless they are Low Temp model designed for basement applications). And will ice up at times. Raising the unit up off the floor onto a sturdy table, counter top, etc that can handle the weight of the unit, plus a full bucket of water, will usually resolve the problem.
If it's not a basement application, try lowering the humidity extraction level to 35%. In you have an analog unit, turn the control knob to Maximum.
I hope this helps you and thanks for choosing FixYa.
Aug 10, 2011 | Dehumidifiers
My LG Humidifier turns on and seems to run fine for a few minutes then the present humidity % starts going up and up all the way to high then the whole thing shuts down. Of course it does not run long...
Chef, you need to turn the Master ON/OFF Switch to OFF and unplug the unit from the wall outlet for 15 minutes. While you're waiting, remove the air intake filter and clean it, if necessary. After the 15 minutes has elapsed, plug the unit in, turn the Master ON/OFF Switch to ON and set the control to Manual Operation. Lower the humidity extraction level to 32% or 35% and allow the unit to run in that mode, rather than automatic. This will give you a good indication if moisture is being extracted or not.
If it is working as it should, you can leave it in manual timed mode (normally 2 or 4 hour segments). This way, cycle On and OFF as necessary, based on any rise in humidity above 35%.
I hope this helped you solve the problem. Please let me know. Thank you.
Jun 08, 2011 | LG LHD45EL Dehumidifier
Dear Sir , the dehumidifier is running the motor is running, but not sending out any water. I have cleaned the filter.n Any recommendations?
Is it only the fan motor running that you hear? Or is it the compressor motor and the fan motor in combination?
If it's just the fan motor, it running to circulate the air, in an effort to sense humidity in the air, above the level you have the humidifier set on. Speaking of which, you may have the level set higher than what the humidity is in the house and the unit is just maintaining it. 50 to 60% is high, as opposed to 35%, which is what most folks want to maintain in the hot, humid, summer months.
If you want to test the unit, place in the bathroom, turn a hot shower ON, turn the humidifier ON and set it for 45% or minimum if your unit does not have a LED readout screen. Do Not turn the bathroom exhaust fan ON. As you leave the bathroom, close the door and don't return for 20 minutes. When you do, turn the shower OFF and check the humidifiers water collection bucket. If you see any water, the unit is working as it should. If you don't see any water, it's time to replace that unit. I say that because, at best, the parts and labor to repair the unit would be equal to or almost equal to, the price of a new dehumidifier.
Hope this helped you troubleshoot and solve the problem. Please let me know. Thanks
May 20, 2011 | Fedders A7DH45B2A Dehumidifier
When my dehumidifier is on, it says there is 90 humidity. I come back an hour later, it is still running and no water in the bucket.
If there's no water in the reservoir, first make sure that water is getting to the humidifier. The humidifier must have a good stream of water available to it. If there's water in the water line but the reservoir doesn't fill, replace the float mechanism inside the humidifier.
Take care.
Jul 29, 2010 | Haier 45-Pint Dehumidifier
Start up instruction for dehumidifier
A dehumidifier does not need water in the tank.It takes humidity out of the air and the moisture goes into the bucket. A humidifier has to have water in the tank.Note ,a humidifier puts moisture in the air, and a dehumidifier takes the moisture takes moisture out of the air.
Feb 16, 2010 | Kenmore 54501 Dehumidifier
Dehumidifier headaches!
There are three things that must be working to extract water. The 'coil' (a finned metal part that allows air passage) if it's filled with dust and obstructions, no air can move...no water. There is a blower motor that mus move the air. If it is seized up an not blowing air...very little or no water. The compressor uses condensation from the air moving across its coils (like the moisture than forms on a cold glass on a humid day) to extract the water from the air. If it's not working then no water.
So, if there is air blowing out of the dehumidifier the blower is working. If the air is room temp the compressor is not working. If it's real hot air, and the humidifier keeps cycling on and off quickly, the coil is dirty. Those are the 3 things that need to be working.
Jul 27, 2009 | Kenmore 54501 Dehumidifier
My kenmore 50 pint dehumidifier 54501 runs but it does not taking in water
You need to determine what's "running". Here's why: There are three things that must be working to extract water. The 'coil' (a finned metal part that needs air to flow across its surface) may be filled with dust and obstructions, so no air can move...then no water. There is a blower motor that must move the air. If it is seized up and not blowing air...very little or no water. The compressor creates condensation from air moving across the coil (like the moisture than forms on an ice filled glass on a humid day) to extract the water from the air. If it's not working then no water.
Jul 18, 2009 | Kenmore 54501 Dehumidifier
Humidifier Fan Doesn't Stop
RH at 70 % seems to me a little excessive you really should be working somewhere around 50 to 56% the fan has to move Air through the system.
I would like to know your room Air temp what is the Air temp comming off the system. what are your parameters.
Jun 08, 2009 | GE AHG40LA Dehumidifier
Does not collect water
ok Carmo
first remove the back of the unit and turn it on. it sounds like the fan motor may not be working.there by making the dehum get hot. make sure your filter and coils are cleaned. you may need a new motor. if so buy a new motor and fan blade.be careful with the 5/16th nut holding the fan blade. the blade might look good but you have to check the hole where it rides on the motor shaft. if you into the hole it should look like the letter "D" because the motor shat is shaped that way.---good luck
Nov 11, 2007 | Kenmore 54501 Dehumidifier
Humidifier Runs but no water collected
Are you talking about a dehumidifier or a humidifier. If you are talking about a dehumidifier, it works by blowing air across a cooling coil causing condensation and the water will drip and pool. The cooling is caused by a compressor working like refrigerator, but using the effect to dehumidify. To check if the cooling coil is working there will be a metal can like in it with tubes in and out. One of the tubes should be warm(input) and the other tube should be cold, if not your compressor is not working. If freezing up, low freon. Check to see if the compressor shuts off very quickly, that would be too much freon. This is not user servicable. Now a humidifier works several different ways. One way is a fan with cloth belts rolling through water using evaporation to humidify. Another way is for a circular fan like on a motor to turn. It has a hollow piece into the water. It picks up water and then through centrifugal force aerates. One way is for a sonic humidifier. All the types have a problem with eventual calcification or mineral build up in the water handling paths. Lime-away or Concentrated Lemon Juice will dissolve this. The lemon juice is the most fun. It will turn your toilet bowl white and also remove rust stains from laundry...
May 01, 2007 | Maytag M7DH65B2A Dehumidifier
Fedders RDG40 Dehumidifier Logo
229 people viewed this question
Top Fedders Dehumidifiers Experts
Bill Long
jasbo
jasbo
Albert
Level 1 Expert
Are you a Fedders Dehumidifier Expert? Answer questions, earn points and help others
