Question about Minolta EP1030/1030F CS/PRO Copier
Code C0500 We had to turn the electricity off in our building, and, when we turned the copier back on, it had the C0500 code and will not work. What should we do?
    President:
  • Minolta Master
  • 990 Answers
Hold down exposure key (<) while turning on power, u-1 will display. prss start, select clear mode, prss clear/stop
Posted on Dec 15, 2008
  • Everett Lin Dec 17, 2008
    did this work? was this helpful? if so, I would appreciate your rating my posting.
    thank you
HOW TO SOLVE ERROR CODE C0500 FOR KONICA MINOLTA 211
Error code C0500 and C0501 means Fixing unit's temperature abnormality.
How to reset these codes?
To reset Error codes C0500 and C0501, perform the following steps.
1-Turn the machine "OFF".
2-Press the "STOP" button on the basic panel.
3-Keep the button pressed and turn the machine "ON".
4-Do not release the button, until the machine warm up.
5-After few seconds Error code will remove and machine will reset.Basic menu will show no error on LCD screen.This means error code has been removed and photocopier machine is ready to use.
http://servicekonicaminolta.blogspot.com/2012/03/error-code-c0500-and-c0501.html
Jun 14, 2017 | Konica Minolta Office Equipment & Supplies
Reset c0500
Aug 08, 2016 | Office Equipment & Supplies
C0500
May 01, 2014 | Minolta Di3510f Bizhub Copier
ERORR C0500
Sep 26, 2013 | Konica Minolta Office Equipment & Supplies
How to reset error c0500
The error code means that the fuser is not warming up correctly. There is a small black rest botton on the main controler PCB on the back of the copier. You are going to have to take the back cover off, I believe in is four screws. Turn the power off and remove the back cover and find the small black botton, once you have found it, turn the copier back ON and press the botton and see if the error code can be rest. If it dose you are good to go... If not you may have to replace the fuser unit..... I did have a problem that was not solved with the fuser unit.. It turned out to be right side door switch... I would look there as well with the back cover off... Good Luck
Apr 04, 2012 | Minolta DiALTA Di183 Copier
I am getting an error code C0500 after changing the toner. What do I need to do to get the printer back online?
Depends on the model of you Konica Minolta. The CO500 is usually related to fusing temp. It's possible that a power spike or a thunder storm that knocked out power to the building would caused this.
Jun 27, 2009 | Konica Minolta Office Equipment & Supplies
I'm getting a malfunction code C0500
C0500 is a heater failure, the fuser section failed to get to the desired temp in a given period of time.
Try resetting the code, there is a reset switch behind the access panel,at the contrast knob inside the machine.
Hope this helps.
ed
May 04, 2009 | Konica Minolta Office Equipment & Supplies
IMAGISTICS 2620 Error code C0500
How to reset malfunction code C0500 of a imagistic
Feb 03, 2009 | Konica Minolta DiALTA Di200 Copier
Minolta di 2510 code c0500
lo ke pasa es ke mi copiadora ya no responde mas y me sale este error una averia "a sido detectada avice a su servisio tecnio y digalke el codigo c0500" ya no se ke hacer... ayuda por favor..
Jun 24, 2008 | Minolta Di2510 All-In-One Laser Printer
Malfuntion Call a technician Code C0500
FUSER CODE. NOT SURE ON THIS SAME MODEL BUT ON OTHER DiALTA'S YOU NEED TO DO WHAT IS CALLED A "WARM RESET OR WARM REBOOT". tURN COPIER ON AND FIND A VER SMALL HOLE (PAPER CLIP SIZE) ON KEYBOARD OR SOME TIMES ON RIGHT HAND SIDE OF KEYBOARD, SOME TIMES SMALL SQUARE HOLE. STICK PAPER CLIP IN HOLE AND THAT WILL BRING YOU INTO SERVICE MODE. PANEL WILL SAY TROUBLE CODES, DEPRESS. TURN COPIER ON AND OFF AND SEE IF IT GETS YOU GOING. IF PROBLEM COMBES BACK YOU HAVE A BAD FUSER, EITHER FUSE, THERMISTER OR CONNECTORS.. GOOD LUCK
Jun 11, 2008 | Konica Minolta DiALTA CF910 Copier
339 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Ed
Ed
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
