Question about Dryers
Hotpoint CTD00 dryer, drum not turning
The drum does not turn, the heating element heats up ok. Tried turning by hand but still doesn't start. Bought a new capacitor but still no good.
New cap has 4 connectors old one just had 2, think I wired it ok though.
  • 3,463 Answers
Provided you only have 2 wires to cap ,it does not matter which wire you put on terminals, as they are both common.
Assuming you got the right value cap, 8uf I think, and it still does not go, check for live and neutral to motor, if supply o/k then you probably have faulty motor.
If no power there check for bad or broken connection.
Pls rate this solution
Posted on Dec 15, 2008
CTD00 drum does not turn,heating OK,belt OK,motor OK
you have a bad motor,most likely.
Mar 03, 2010 | Dryers
My hotpoint ctd00 wont heat up
I would suggest that you check the heater and thermostats, these are located behind a removeable cover at the rear of the dryer.
You will need a meter to test them with, you are checking for continuity
Feb 10, 2010 | Hotpoint Dryers
Dryer not heating up
To be certain whether it is the element or thermostats that are faulty,you really need a test meter to check them with, as it is not obvious if they are faulty or not, simply by looking at them
Hope this helps.
Please rate my solution.
Thankyou.
Dec 21, 2009 | Hotpoint Dryers
Drying Problems with a Hotpoint CTD00
There is a thermal fuse at the back that you must check. The thermal fuse can be tested using a multimeter.
If the fuse is ok, then check the heating element , the temp probe, wiring harness to heating element and temp sensor, and if there is nothing in there , then test control timer board.
Regarding parts, contact the seller here to purchase parts. (here in UK).
Apr 27, 2009 | Hotpoint Dryers
Elements over heating on hotpoint ctd00 condenser dryer
Did you check the fuse in your unit ?
Check the fuse whether it is burned.
Mar 13, 2009 | Hotpoint Dryers
DRUM NOT SPINNING....and a burning smell
Motor going bad. Run windings inside are burneded up.  Start windings are ok. replace motor.
Jan 07, 2009 | Hotpoint TDC32 Electric Dryer
Hotpoint aquarius CTD00 dryer
how many fuses are there in a hotpoint tumble dryer CTD00 aquarius I know one is in the plug is there another one if so where is it?
Aug 18, 2008 | Dryers
Dryer cutting main power off after acouple of seconds
your heating element is the most likely cause of this. will need replacing
Nov 18, 2007 | Hotpoint TDC32 Electric Dryer
Dryers Logo
439 people viewed this question
Top Dryers Experts
