Question about JVC AV-27850 27" TV
Thin Bright line is all I got on the tube
I already paid for service on this set, different problem. The picture went "thin on me, with black belts on top and bottom. Shortly after it went to a thin white line, side to side. I threatened it with my 9mm, but it just smelt hot... kill it or what?
  • Anonymous Mar 16, 2008
    SAME PROBLEM , THIN LINE SIDE TO SIDE, AUDIO OK, BUT NO VISUAL!!!. I`M GETTING STRESSED,,,
  • airfido May 03, 2008
    I have a thin bright horizontal line also, but it is at mid-screen. Bottom half of screen picture is normal. It almost looks like the top half of the screen picture is tightly compacted into this thin bright line. Help!!
I got this problem too. I have the same exact TV. This is going to sound stupid, but I pushed down on the top and it came back.
Posted on Jan 05, 2008
    Genius:
  • 1,694 Answers
Solder bad connections vertical output IC...........should have
been done by servicer as prevent maintenance.....T.
Posted on Dec 11, 2007
    Genius:
  • 1,694 Answers
Solder bad connections Vertical output IC......should have
been done by servicer as prevent maintenance.........T.
No no no, is this by any chance a widescreen set??? its just the 4:3 16:9 settings... Read the Manual!!!!
Posted on Sep 30, 2007
Check on polarized capacitors on the vertical section of the tv... ranging to 100 uf- 2000 uf/50v
Posted on Sep 13, 2007
    Novelist:
  • 192 Answers
Sounds like a capacitor and/or the Vertical amp Ic has gone out in the set. Maybe a bad solder joint. Depending on where you live, the cost of repair could be between $100.00 to $150.00. Kill it or what? What would Braveheart do. FFFRRRREEEEEEEDDDOOOMMMM
Posted on Mar 18, 2007
4 Suggested Answers
  • 236 Answers
SOURCE: jvc 32" has grouping of thin white lines at top of picture extending 4" down from top of frame
It sounds like you have a bad capacitor in the vertical circuit. The circuit needs to be checked out by a technician. Stargazer
Posted on Aug 20, 2007
  • 71 Answers
SOURCE: Horizontal ines---original post got wiped. Sorry.
leaky cap(s) in vertical circuit. shouldn't be more than $125 (plus taxes) parts and labour
Posted on Jun 19, 2008
SOURCE: orion TV model TV_798 sl (thin line no picture)
problem is with the vertical output circuit. take it to a repair shop and have them fix it.
Posted on Aug 29, 2008
Big black square in middle of screen picture top to bottom about 36 " wide good audio and picture 6" on right and left side displaying.
If you have tried using different input devices, looked for loose contacts
in power outlet, RC Jack, cable and connectors, the TV might need service.
Aug 26, 2012 | Hitachi 55HDS69 55 in. Plasma Television
Center bow on picture top and bottom with 1" black showing
Projection TV2_bing.gif sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - TV2_bing.gif makes a chirping sound.
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 06, 2010 | Toshiba TN55X81 55" Rear Projection...
A bright thin white line, side to side.
You need to replace the vertical IC and all the dry capacitors near to him.Good luck
Jul 06, 2008 | Sylvania 202SL8 TV
Mitsubishi VS-60705 Large Screen Projection
thanks for your detailed description of what happened.
replacing the vertical output i.c will correct the problem.
the reason it failed was bad connections on it.
Apr 22, 2008 | Mitsubishi VS-45605 50" Rear Projection...
Picture is now a thin horizontal line
now only visible in a thin horizontal line. first of all you reduce brightness to monimum. it just to protect your tv from crt demage. your problem is in horizontal output section as you have mentioned that week or so ago the right and left bottom edges of the picture began to move in like a sideways triangle filled with black so this sympton is due to hor. section problem. your flyback transformer or horizontal output might be defective. but remember check for power supply is ok from surge protector hope this will help.
Oct 07, 2007 | Hitachi 35UX80B 35" TV
Top half of screen black
The vertical circuit is going bad,this is the one in charge of opening the picture up and down,try taping on the side to see if the picture reacts ,if it does your set has a loose conection and the vertical IC will need to be resoldered only but if it does not react the IC will have to be replaced,if you are familiar with tv service this will give you a place to start but if you are not be safe and seek the help of a servicer,please let Us know how it goes.
Oct 11, 2006 | Sony KV-XA34M66 34" TV
Picture went black
The good thing is you see something in the screen,with age the set has developed loose conections in a few different places,my suggesion is to call professional for service now and the repair will not as expensive,if the picture quality is good is worth it.
Sep 22, 2006 | Sony KV-32V26 32" TV
Televison & Video Logo
394 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
