Question about Black & Decker HCC100 Coffee Maker
Black and Decker hcc100
Just bought this and the lights either blink constantly or come on for 30 sec and then shut off. Will not brew. Thanks for any help!!
Mine never, ever pumped water. Like yours, the light came on (like it was brewing) for 30 sec., then all the lights blinked and shut off. The best I ever got was a little steam at the top. To fix this, I put it on the driveway and bashed it with my largest sledge hammer. It fit very nicely into my trash can. Then I bought a real brewer.
Posted on May 21, 2010
    Genius:
  • 1,074 Answers
Check the power supply there is chip theren the board that needs to be changed if you cannot do it your self take it to a tech.there is also tw transistors on that same board replace them.that that will remedy your problem.good luck.
Posted on Apr 06, 2007
Black decker problem
Sounds like it could be a bad battery pack that's not accepting a charge.
Jul 14, 2014 | Vacuums
BLACK AND DECKER HC100 COFFEE POT
HI,
You will have to contact the main support no.1-800-544-6986 and tell them to email you a copy of user manual to you.
Sep 13, 2008 | Black & Decker HCC100 Coffee Maker
Sony KDF-60XS955 LCD Projection HD Grand Vega. Turns itself off every 30 secs or so. Flashes green light 32/33 times. Comes back on with picture but no sound. Then sound comes on at green flash 37 and...
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
https://homenol.blogspot.com/
https://electronicshelponline.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Feb 20, 2018 | Sony Grand WEGA KDF-60XS955 60" Rear...
The program light won't stop blinking
Same here. I'm dead in the water. This started happening a few weeks ago and with patience and luck and different combos of buttons I'd get it to stop and I was able to brew. Today it just stopped completely. The program light either blinks constantly or stays lit constantly, but I cannot brew coffee. I see lots of people online with this problem, but have yet to see a solution.
Dec 08, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
My Black and Decker Firestorm 24 volt charger is not working
change batteries, your charger should indicate wheather you battery is good or noot on the pause inbetween blinks.
Aug 13, 2009 | Black & Decker Black And Decker FS24C...
Black & Decker TCM800 won't go all the way through brewing cycle
I have the TCM700 and it would turn off before the brew completed.  This was because it had some sort of buildup from use.  The manual recommended to brew with white vinager and water.  The exact mix was in the manual, but my wife just did all vinager.  Worked great.
Nov 26, 2008 | Black & Decker TCM700 Coffee Maker
7oz and 9 oz blinking
Unplug and then plug the machine back in. The stop light should be blinking.
Hold down the lid release lever until the lid opens up. Close the lid enough so that the sensor thinks the lid is closed, but not enough so that it actually latches closed. You'll hear a "click" where the sensor engages before the latch takes hold. Hold the lid in that position until the red stop light stops blinking, then close the lid all the way until it latches.
Press the clean button (with water in the tank) and it should begin working properly again. Good luck!
Apr 16, 2008 | Black & Decker GT300 Coffee Maker
Black & Decker TCM700 Coffee Maker problem
All coffe makers have a thermal cutoff fuse located on the bottom heating plate. It is usually in series with one of the leads to the actual heater. This should read "short" with an ohm meter. If it is "open" it needs replacement. They are rated in Degrees celsius, and are sometimes difficult to find. Black and Decker may be able to send you one.
Mar 11, 2006 | Black & Decker TCM700 Coffee Maker
Black & Decker HCC100 Coffee Maker Logo
197 people viewed this question
Top Black & Decker Coffee Makers & Espresso Machines Experts
Steve Allison
Steve Allison
eyecam
jason
Are you a Black & Decker Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
