Question about Plumbing
Apparently valve not working, how can I check it?
Radiator nor warming up whatever setting. There is no air lock.
    Scholar:
  • 44 Answers
Sounds as though the thermostatic radiator valve is stuck although the valve settings can be set to max. sometimes hitting the side of the valve will free the stuck spindle & get it working again.
If not a drain down of the system & a new valve fitted
Kindly
Richie
Posted on Dec 15, 2008
My yruck only blows cold air wont blow warm
Could be the air flaps of the heater unit are set incorrectly or not working at all or possibly the heater radiator is blocked or semi-blocked or perhaps there is something wrong with the heater hoses or the heater water valve if one is fitted.
These things need checking before a cause can be established.
I am sometimes called upon to flush out a heater radiator. Sometimes it works and sometimes it doesn't and sometimes it causes a leak and the heater radiator must be replaced. Not an easy job on many vehicles made in the last couple of decades..
Feb 03, 2015 | Cars & Trucks
I have a 1996 Suburban that will blow cold air if it sets at an idle very long instead of heat? If the vehicle doesnt idle long the heat will stay warm.
Check your radiator for cold spots when its warmed up. I think you may have some blockage either in your radiator or the hose going to your heater core. Also check the serpentine belt tension and the pulley on your water pump.
Jan 09, 2015 | 1996 Chevrolet Suburban
I Have a 2002 lincoln ls v6 that is overheating i've change valve cover gaskets,water pump,ignition coils,ts tat ,i let it run for about30 min with the heater on it took awhile for the heater to get warm...
you have wasted money on fixing what has not consequence on the oproblem
overheating is from 4 things
1--- no/insufficient water in the cooling system--air lock in system- fill radiator to cap level and bleed air out
2--blocked radiator cores -- have a radiator shop do a flow test
3-- fan not working--no power from relay, ECM. coolant temp sensor , fuses-- have an auto electrician check the circuit
4--- blown head gasket /cracked head-- have a compression test done
Jul 31, 2017 | Cars & Trucks
The heater is blowing cold air
Coolant system is a closed system. If you are loosing water there is definately a leak somewhere. Check all hoses after filling the system and letting it run until it's warm. Be careful when checking most systems have the water at 185-210 degrees once the vehicle is warmed up. Also check the Heater Control Valve. It allows hot water to travel to the heater core when you set the ac controls to "heat". Could be bad and leaking there. But bad hoses are the most likely culprit. Only takes a pinhole.
Jan 12, 2013 | Rover 75 Cars & Trucks
2003 lincoln aviator water boiling and car overheating
Check to coolant level after it cools off and check to see if coolant-water mixture is correct. If those are ok. You could have to much air in the coolant system. Most radiator caps will automatically vent the air out of the coolant system. It could be as simple as a coolant cap that gone bad. Or you may have a air bleed valve on it and you need to bleed the air out manually. To bleed it you will have to crank engine and get it warm. Touch top radiator hose to see if its warm. If not then the thermostat has not opened yet. That could also be the problem. After it gets warm open the bleeder valve if equipped and bleed all the air out. Once the steam and hot air from the valve starts to be gone and pure coolant coming from the valve. You have successfully bleed the coolant system. Cool engine back off and check coolant level once more. Hope this helps.
Nov 27, 2012 | Cars & Trucks
2002 Ford Taurus SE. Heater motor and fan work fine on all speed settings but the air coming from the vents is moderately warm at best and not hot when temp selection is to hot. When I move the temp...
Check the heater valve is fully open when in the hot position , this valve or tap often get stuck half open. if all is ok there flush the heater radiator as they can silt up.
Apr 19, 2017 | 2002 Ford Taurus
I've had my 2004 Nissan Sentra to several mechanics. It's still there. No one can figure out why I'm only getting cold air, no heat. (for weeks now). I paid for new thermostat, water hose, radiator. ...
Assuming they checked the controls under the dash and everything is working, lets try to bleed the air from the cooling system. An air lock in the heater core could stop it from getting warm. You will need a gallon of antifreeze and a jack to raise the car. Here we go: remove the radiator cap. Set the parking brake, transmission in park, block the rear wheels. Jack up the front of the car so that the radiator is higher than the engine. Start the engine and put the heater controls on the hottest setting but don not turn the heater on. With the engine running, look in the radiator, the coolant at this point should not be moving, or flowing through the radiator because the thermostat has not reached the temperature required for it to open. If the coolant is flowing at this time, then the thermostat is open and should be replaced. Let the engine warm up and watch the coolant level. When the thermostat opens up, the coolant level will drop, and you will be able to see the coolant flowing or moving in the radiator. Add enough antifreeze to fill the radiator ack up. The coolant level will probably drop again, Add more coolant as required. Repeat this process until the coolant level stabilizes and no longer drops while there is flow or movement of the coolant. Replace the radiator cap and lower the jack. Turn the heater on. If the problem was an air lock in the heater core, you should now have warm air blowing from the heater.. Something else to observe is the cooling fan for the radiator. If the electric cooling fan was running the whole time the engine was running, then the switch controlling the fan is bad. The fan should not come on until the radiator is hot. If it runs all the time, the coolant won't get hot enough for the heater to work. Let me know is this works.
Jan 11, 2011 | Nissan Sentra Cars & Trucks
Heater dosne't put out warm air
either have a bad heater control valve, thermostat is not opening, or heater core is stopped up
Nov 12, 2009 | 2004 Chrysler Sebring
We receive warm air, when turning on the ac
If set to position cold and hot air comes out, there is either a leak or there is a" two way valve" that hasent switched over. One needs an aircon tech check it out.(Two things to check though, look if radiator fan is working and if condenser is clean).Important factors..
Sep 14, 2009 | Heating & Cooling
Plumbing Logo
236 people viewed this question
Top Plumbing Experts
Andrew Bugbee
Tom Chichester
Gil Shultz
Are you a Plumbing Expert? Answer questions, earn points and help others
