Question about Matrix HANNSFREE 19 Analog and Digital Widescreen Active TFT LCD Display HW-191D Monitor
Switch from Analog to Digital
Things changed after hooking up monitor. Game shuts down completely when certain "moves" are used. This did not happen before new monitor was hooked up. In fact, I was using game with best sound in order to decide if I wanted to use monitor speakers. (no) Game worked yesterday. Monitor is only change. While troubleshooting, I found monitor was on Analog mode. That doesn't sound right. I tried to switch to Digital mode and got nowhere. I found no valid way switch to Digital. I'm not even sure that's the problem. I used the buttons on the front of the monitor to try to solve this then went into troubleshooting programs. Couldn't find a HannsG troubleshooter. By the way, I don't have a widescreen. HannsG JC199D is what I have. Square flatscreen. The directions given by HannsG are choppy and seem to be a translation. (someone did not a grip on their prepostions) My depth of knowledge of computers is a mixed bag.
    Habit-Forming:
  • 13 Answers
To move to Digital (you need to have a DVI cable for this)
I'm using the monitor now and typing these instructions Mine is a HW191D Silver:
Button Layout:
(1) Menu
(2) Auto Adjust (does nothing when in digital mode)
(3) Move up in menus
(4) Move down in menus
(5) Power
Press the Top (1) button to display the OSD Main Menu
The Press the button Next to the Bottom (4) twice (Input Setting should be highlighted)
Press the Top button (1) once to allow you to select between Analog and Digital (use the button next to the bottom (4) to select between the two)
Press the Top button (1) and it will change to the input that you selected.
If you selected Digital and you don't have a DVI cable connected, the display will go black and then return to Analog (VGA)
(1)(4)(4)(1)(4)(1)
I hope that helps
toypaj
Posted on Mar 24, 2008
How do I turn off the Samsung sync-master p2050 monitor?
If it doesn't turn off by holding the power button down for 10 seconds, then it cannot be turned off by the power button alone, like most modern lcd monitors. Most modern monitors goes into standby mode. To completely cut power, you must unplug the power cable.
I've enclosed a link to the install manual for reference.
Samsung SyncMaster P2050 User Manual Page 7
Nov 24, 2014 | Samsung Computers & Internet
I have a nVidia Quadro2 MXR/EX video card which works fine on the analog input but when you use the digital input the screen sometimes flashed at startup and then goes blank. If you move the mouse,...
There are a few things that come to mind here. Number one is to try a different and known functioning DVI cable. Maybe see if you can recreate the problem simply by wiggling the dvi cable. If there are any splitters/adapters, remove them and plug the cable straight from the video card to the display. Make sure the display is set to digital input mode. When you are using the digital cable, make sure to completely remove the analog cable. See if this problem happens outside the operating system (such as in the system bios, if it does, this indicates a hardware issue). Finally, the digital input on the monitor could be having an issue, try a different monitor or try this monitor with digital input from another system.
Sep 24, 2011 | HP NVIDIA Quadro2 MXR (32 MB) AGP Graphic...
Have a technics SHGE70 and trying to hook it up to a sony STR-K660P. the receiver has a red and white rcs for dvd audio in and red and whitre video audio in. thats all the rca outlets it has. i unhooked...
I see an EQ and a Receiver with NO Tape Loops or external audio sources mentioned.
Are you implying this used to be hooked up and working? Or are you asking how to integrate the EQ NOW after a move?
Normally the receiver would have a defeatable external loop for Tape recording. THAT is where the EQ or any other processor would go.
The following is mostly boilerplate for receivers WITH a tape loop. You need to understand what will and will not work even if you could attach the EQ.
--- Be advised that the engagement of any device in a Tape Monitor loop on a late-model Audio/Video Receiver will effectively tie the receiver down to stereo-only analog sound reproduction. I'll explain.
The connections themselves are fairly simple but it pays to understand what happens in the loop.
In general, any Line-Level external processor (EQ, dynamic range expander, etc) will go into a Tape Monitor loop on a receiver. A Tape Monitor, when engaged, sends the stereo analog signal Out to the Processor, massages it and returns it to the receiver via the Tape Monitor IN connectors to be passed on to the receiver's internal processes (volume, tone, whatever).
Old school analog stereo-only receivers consistently work this way. Newer digital and audio/video receivers introduce a couple of problems: 1) digital sound processing to simulate a variety of soundfields; 2) multiple output channels, either discrete or digitally-generated.
The latter requires that whatever signal is being processed experiences a maximum of one analog-digital-analog conversion.
EVERYTHING analog coming into the modern digital receiver is automatically converted to a digital signal for internal processing unless you choose a STEREO-only or STEREO-Direct setting. Consequently, no further external analog-digital conversions would be allowed if, say, a Tape Monitor circuit was activated, and a possible feedback loop could otherwise be created in a digital-sourced selection (output to its own input), so the unit is wired to treat the Tape Monitor as the first analog step in the process and defeats any pure digital sources.
In a multichannel unit, what would happen to the other channels if you sent ONLY the Front Left & Right out for processing? The rest would NOT be processed. That logical problem also plays into the decision to defeat digital sources if the Tape Monitor is activated. I don't totally agree with the engineers but that's the way it is. Nature of the digital beast. --
http://4.bp.blogspot.com/_TaoBB_L8lt0/TDi__0VSpoI/AAAAAAAAACc/uS9ODAazZi0/s1600/HPIM0718.JPG
If you wanted to Equalize a single external analog source you would have to connect the EQ Line output to either of the two analog inputs ("DVD" or "Video" in your case) and connect your external source to the Playback jacks on the EQ.
Mar 15, 2011 | Technics SH-GE70 Home Equalizer
Yamaha eq70 hook up to yamaha rxv-2600 tried to hook to tape connections do not have main in hook up do have the preout on back of rec help me
The following is some boilerplate I made up that should explain some usage limitations.
In a multichannel unit, what would happen to the other channels if you sent ONLY the Front Left & Right out for processing? They would NOT be processed. That logical problem also plays into the decision to defeat digital sources if the Tape Monitor is activated. I don't totally agree with the engineers but that's the way it is. Nature of the digital beast.
Okay, back to the hook-up:
You have to select any available 'tape loop' containing an overrideable analog 2-channel Out and In. That would be MD Tape, CD-R, VCR1 or DVR/VCR2 in your case.
Receiver Tape Out (Rec) - to the External Processor (EQ, whatever) Preamp-, Rec, Line-In;
Receiver Tape In (Play) - from the External Processor (EQ, whatever) Preamp-, Play , Line-Out.
So, to sum up, you can only use the EQ or any outboard processor for analog stereo sources. If you actually want to use an analog recording deck you could place it within the typical Equalizer
Feb 12, 2011 | Yamaha EQ-70 Home Equalizer
My monitor keeps on blacking out whenever i play a game (bout 5 minutes into it). i think its automatically switching from digital to analog... however when i tried to fix this through the monitor the...
Game uses GPU power, it needs more resource to generate picture then when you are surfing. If you use not integrated video card check GPU cooler fun is working or not, it may overheated and stops responding until cools down.
Dec 15, 2017 | Samsung SyncMaster 920WM LCD Monitor
Going to sleep
Problem not in your monitor, but in your videocard, I've got the same. Your videocard overheats and your monitor shut down. You need to check cooler on your videocard. Maybe it full of dust. Sorry for my bad english) hope it helps to someone.
Jul 04, 2010 | Samsung 760BF (White) 17 inch LCD Monitor
LG FLatron W2252TQ Not working properley in DIgital mode.
Fixing power problems with your LG Flatron Monitor (LG1753S) ' Just ...
blog.lopau.com/fixing-power-problems-with-your-lg-flatron-monitor-lg1753s/
Fixing power problems with your LG Flatron Monitor (LG1753S) ... So after checking the power isproperly plugged, I shut down my pc again. .... I can start a game and then change the resolution, Popp of "energy saving mode digital" led goes ..
Mar 21, 2017 | Computers & Internet
Samsung 931B SyncmMaster
DO YOU MEAN WONT SWITCH FROM ANALOG TO DIGITAL!!!
THE ONLY WAY THIS WILL CHANGE IS IF YOU HAVE A DIGITAL INPUT SOURCE CONNECTED to this mointor like HDMI AS THIS MOINTOR AUTOMATICALLY SENSES ANALOG SIGNALS AND DIGITAL INPUT SIGNALS if a digital signal is available it will switch over if a digital input singal is not available you will only be able to use the analog option
Jan 11, 2008 | Samsung SyncMaster 930B 19" LCD Flat Panel...
Matrix HANNSFREE 19 Analog and Digital Widescreen Active TFT LCD Display HW-191D Monitor Logo
1,730 people viewed this question
Top Matrix Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you a Matrix Computer and Internet Expert? Answer questions, earn points and help others
