Question about Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher
My fisher paykel dishwasher is filled with water and will not drain. I have looked for damage to ring( none) or any impingements( none). I get a F2 message which I believe indicates a rotary problem.
  • majidkiwi Dec 23, 2008
    hi
    i get f2 code on my fisher and paykel dish washer .
    i don,t know what is the problem can you help please
  • 734 Answers
no problem with our chat sesson...
but your answer is here----
if you pull out the lower drawer, there s aside release pin on either side of bottom corner of hte drawers when extended. a small maybe quarter sized hole( no need to mess with that only removes the face panel) but under it is a release that you can push in and back a little, this will unlock from the drawer hinges(slides) just nee to lift up and over to the left slightly, on the back wall behind hte drawer youll find a pretty good trouble shooter for this model, itll tell you what hte code is and will try to walk you through as to what might of happened as well as recommended repair
Thanks
Posted on Dec 15, 2008
  • futureloginn
    futureloginn Dec 15, 2008
    F2= The motor has notbeen sensed rotating
     Foreign object has jammed the rotor
     The rotor has failed
     The hall sensor has failed
     The electronic controller has failed
    I think there is somechocking in your dishwasher, I've had this problem a couple of times with my dishwasher. In both cases, the cause was a shard of broken glass that had managed to get past the filters and jam itself underneath the impellor. Hard to see, but easy to fix. First ladle out the water.
    Pull off the lower rotor arm, unscrew the filter and take out the filter bowl, tray and cylindrical filter. Get as much water as you can out of the filter cavity.
    Then, using a Torx-20 driver, remove the screw holding the impellor cover and lift the cover off. (this is the small bit of plastic at the left end of the filter cavity.) Check whether the impellor can rotate freely by spinning it with your finger several times - if it jams or grinds, then there's probably something jammed under it. (It may seem to be fine at first, so do check thoroughly, as any debris can move around with the water flow and only jam occasionally) You may have to use a cocktail stick or similar to poke out anything that's stuck underneath.
    Glass is a particular problem, since it's almost impossible to see when there's any water around (it's easy to cut yourself too!)
    Thanks
Fisher & Paykel dishwasher top drawer is filling up with water when bottom drawer is ran.
It is the drain water from bottom drawer that is finding its way to the top drawer. This could be due to incorrect drain hose height. Check in installation manual. Alternatively you will have to buy an air gap kit and connect the two drain hoses separately to the kitchen sink.
http://www.genuineapplianceparts.net/ecart/item.php?item_id=250&category_id=58
Mar 22, 2014 | Fisher and Paykel Dishwashers
Fisher paykel cross draining
As the drawers share a common outlet to the kitchen sink drain, it is the drain water from bottom drawer going to top drawer. Can happen if the drain hoses are not following the correct specifications for installation. An air gap kit is available to solve the problems.
Refer
http://www.genuineapplianceparts.net/product/WT50/WT50-Dual-Air-Gap-Kit/?preadd=action&key=WT50
Fisher and paykel nautilus dishwasher
Does it fill with water? I would guess a fill/ drain/ heating problem. See if you can eliminate any of those.
Apr 12, 2013 | Fisher and Paykel Dishwashers
Fisher and paykel dishdraw model DD603
P2 is for drain. Make sure there is a bit of water in the base of drawer before you start P2 otherwise the rotor may rub and burn. You can run the diagnostic with drawer open. Be careful not to start P1 as the wash water will splash and flood the dishwashwer.
Jan 28, 2013 | Fisher and Paykel Dishwashers
F2 error code won't drain
The problem is with rotor assembly of the drawer that is causing the F2 error. Turn power off. Empty water using a small container and towel to dry base.
Remove the washer arm and drain filter sump cover. Twist the rotor at the base out from the socket gently but firmly.
Clean the cavity and check the rotor for damage. Put everthing back in and turn power on.If F2 does not go away then replace rotor.
Aug 21, 2012 | Fisher and Paykel 24 in. DD603H W Built-in...
F1 flashing on both doors on my Fisher&Paykel dishwasher. Just turned on by themselves.. was not running either top or bottom at the time.
F1 - on dish drawers means there is a H2O leak on the machine which has activated the flood sensors.. Causes
Lid not closing.
??¢ Overfilling.
??¢ Foaming.
??¢ Not draining.
??¢ Lid seal damaged.
??¢ Dispenser or water softener or their seals leaking.
??¢ Damaged water inlet or drain hoses.
??¢ Leaking heater plate or motor seals, or drain o-ring seals.
??¢ Yoke jammed or broken.
??¢ Inlet hose to inlet valve connection loose.
??¢ Inlet valve body leak.
??¢ Heater plate damage (chipped enamel).
??¢ Dry F1 - PCB mains filter, harness or connectors, electronic controller
May 09, 2011 | Fisher and Paykel 24 in. DD-602 Built-in...
Used dish washing liquid dishwasher damaged?
Hello- NO- Use about 1 gal warm water to: 1- fill bottom of tub. 2- turn on briefly- 5sec - 3- Push Drain button. 4- Press cancel. ---- Repeat. Let me know if this info helps. -ED
Mar 04, 2010 | Fisher and Paykel Dishwashers
F1 fault code flashing
Damage to the fill or drain hoses
Seals/O Rings (pinched, contaminated or poor join)
Dispenser (seal, diverter valve or weld leak)
Lid area (lid motors not functioning correctly, lid off
yoke or foreign object interfering with lid seal)
Dec 28, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher & Paykel double dishwasher bottom dishwasher starts to fill with water then a noise comes on and a flashing F2
F2 is indicating a fault for the motor. This motor has 2 directional operations. One direction of rotating for spraying water for washing. The other for draining at the end of washing cycle. I don't think it is a problem with the motor, but there is some food clogging up its rotation path causing this issue. Need to take out the bottom stainless steel exposing the motor to clean up. I do this some times. Just need to pay attention to remove and put things back properly. Now if you are not comfortable in doing it, then call F&P serviceman. Don't call any handyman, since without knowledge about this dishwasher a person can do more harm than good and you know who will take care of the bill. Good luck.
Dec 27, 2009 | Fisher and Paykel 23 in. DD603H SS...
Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher Logo
907 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Simon Flummox
Simon Flummox
Jose Pino
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
