Question about Supersonic SC-301MP3 MP3 Player
I cannot transfer music
Hi my name is marino and I got a mp3 player and I cannot import the music form my PC to the item.
0 characters
1 Points
I can't use my itunes account to add or subtract my music, since adding the gogearVibe. had the same set up approx. 5 months ago with a different unit that worked fine. What happened?
You need to use the Philips songbird software to transfer itunes music into your MP3 player. If your player doesn't use Songbird, you need to first convert it into MP3 format under itunes then transfer using windows media player 11 or higher.
Here is how ot import files from itunes to Songbird:
  1. On the computer, launch the Songbird program. Select Tools > Options
  2. On the Songbird toolbar, select the Media Importer tab, then iTunes Import/Export.
  3. Verify your library location and options. Select Import Library.
  4. The software imports the iTunes library into Songbird.
Once this is done, your itunes music will show in Songbird library. You can now transfer it to your GoGear player. Here is how to transfer files from songbird to your MP3 player:
  1. Click "File" in the toolbar and select "Import Media". Choose the folder that stored your media files.
  2. Select the media files that you want to transfer and then Right Click to display a drop list (You can press and hold the Ctrl button on the keyboard to select more than one file).
  3. Select "Add to Device" and "(Your player model)".
Or you can to go to Songbird library and then drag and drop the files to your MP3 player's icon on the Songbird software.
Hope this helps..
Mar 05, 2011 | Philips GoGear ViBE Digital Media Player
No video software came with my Zvue Elvis Presley mp3 player now I can't put any on. What can I do? All the video's I want to put on it are in avi, mov, mp3, mp4, or mpeg form..
Conect the ipod player to the computer where controls are acquired. For example, the computer would provide accessibilty to the mp3 player. media playes like windows media player, real one player, apple media players, juke box media convertors are the audio, video management software programs on the computer. As long as the computer would acquire media as videos, the computer mediaprofram should provide the transfer buttons between external connectable devices like mp3 players. However, the media players have various compartibilities recognisable as media formats. The mp3 player should have dictated the compartible format that is capable of being encoded. Important notes includes that, mp3 playes would only encode medias that have been loaded onto the computer completely. For example, if wanting to acquire music transfer to the mp3 player device, the music CD has to be extracted first into the computers media player like windows media player from where transferability is achievable into the MP3 player. Usually, the computer media player should state that the feature functionality is capable of MP3 IPOD transfers. For example, once login to the windows media player software, copy available media files from the files library into the player list area to be manipulated as transfers/sync. Also, the media player of the computer should recognise connected media devices with popup logos indicating transfereabilities.
Jan 12, 2011 | Zvue Elvis Presley MP3 Player
Have transferred music from pc onto device, but it won't play. a message appears saying no DMS licence?
It sounds like you deleted an important item when deleting music previously. You will need to go online and download the software again so that this problem will not persist, or if there is a master reset that will help.
Here is the Online Support for Philips :
Dec 12, 2010 | Philips GOGEAR SA6045 MP3 Player
Transfer songs from the player to the computer
Yes you can copy out any songs and play list on to your computer into a folder of your choice.
May 03, 2010 | RCA H115 MP3 Player
A friend of mine loaded my sony walkman nw-e005f with music form his ipod. I want to download the music to my pc. The Sonic Stage software reads it, but won't let it transfer to the pc. What can I do? I...
download the latest drivers, then restart pc, then turn on device, then hook up to usb, then go to start menu, then my computer, then find your device and double-click to open the files.
Or go to media player 11, sync device and transfer the songs to music file.
Nov 13, 2009 | Sony Network Walkman NW-E005 MP3 Player
I have a nextar mp3 item ma933a and i cant figure out what to download to get it to work on my computer...i dont have the disk it came with
**Drag and Drop**
Connect your MP3 player to the computer. Some MP3 players connect directly to a USB port, while others connect to a USB port by way of a specific USB connector that comes with the MP3 player. Open the folder on the computer that contains the music files you want to transfer. This is usually the "My Music" folder; available from the "Start" menu, but it can be any folder where you save your music files. Scroll down to the song you want to transfer to the MP3 player. Right-click on the title. When the options are displayed, click on "Send To." Scroll down the "Send To" options and select your MP3 player. This can be listed as your MP3 player's name or as "Removable Drive." Click on this selection. Continue this process until you have transferred all songs that you want to your MP3 player.
--**Windows Media Player**--
If you have a large playlist to transfer, you may prefer to do it from your media player, such as Windows Media Player. Once your MP3 player is connected to the computer, open Windows Media Player. Click on the "Sync Music" tab. Drag songs that you want from your Windows Media Library over to the "Sync Music" column to create a playlist. Click the "Begin Sync" tab at the bottom once you have all of the songs on your playlist. This action will sync all of the songs to your MP3 player with one click. Disconnect your device once songs have been transferred by clicking on the "Safely Remove Hardware" icon in the bottom-right side of the desktop tray.
Sep 27, 2009 | Nextar MA933A MP3 Player
I do not know how to download songs onto my dad's rca jet mp3 player.
RCA EasyRip™ Media Software, installed
automatically when you connected this player to
your PC, lets you import music files from CDs and
other sources, organize your music library, and
transfer unprotected MP3 and WMA files to and
from this player.
To transfer DRM-protected files to this player, you
must use the application provided by the online
music store.
You can geth the full manual, etc from
-Tha Mp3 Doctor
Sep 27, 2008 | MP3 & Digital Media Players
Downloading music.
hi there gurdy!
Sony mp3 players are great mp3 players, except with one problem. You need to get Sonicstage, the mother program for their mp3 player, to put music in their. So, one way is to go here first:
download the Sonicstage program, and install it into your computer. (WARNING! First install the Sonicstage, then connect the mp3 player to the computer, otherwise it might not work.)
When you are done installing it, and you plugged the mp3 player, open up Sonicstage. It should open up with a screen saying many things such as My Library, Transfer, Music...
From there, go to add music (top left corner button next to My Library, next to it) and three choices should come out, saying add files, add folder, or import CD. From there just add files from your computer.
Then, click the Transfer button. There you should have a split screen, half My library half Transfer aka mp3 player space. Choose the songs you want to import and click the arrow pointing right (in the middle).
Give it a few minutes to download into the mp3 player.
After it is all done, either exit the program or just pull out the mp3 player and wha la music to your ears!
It's a nice mp3 player.
Hopefully this solution helped out.
Please contact or reply if you have anymore problems.
this is where you can read the manual and all the information about it.
Nov 23, 2007 | Sony NW-E002 MP3 Player
Sansa 250 - Having problems downloading music?
You could try opening the folder(s) with your saved music and highlight all the ones you want to transfer to your mp3 player and then right click on one of the highlighted files, left click on Copy, then go to My Computer > Sansa e250 mp3 player should be listed in there, double click on it, then right click in a open white area and left click Paste. It should copy the music right to your player. You could also try using Rhapsody and import your music into it. I use Rhapsody for transferring music to my e250 Sansa mp3 player.
Nov 07, 2007 | SanDisk Sansa e250 MP3 Player
MP3 & Digital Media Players Logo
Top Supersonic MP3 & Digital Media Players Experts
Are you a Supersonic MP3 and Digital Media Player Expert? Answer questions, earn points and help others
