Question about Brother IntelliFAX 2800 Laser Fax
When I try to fax there is a beeping sound. the report says the line is busy/noresponse
    Problem Solver:
  • 4 Answers
In my case, the phone company has blocked the ability to make long distance calls (I refused to sign up for one of their expensive long distance packages). Local faxes (10 digits) work. 1-800 faxes work. For long distance faxes, I use calling cards with a local call in number.
Posted on Jan 24, 2009
    Champion:
  • 320 Answers
I would first reset up the machine in send and receive mode, is there dial tone. let me know what happens
Posted on Jan 16, 2009
Brother 7340 not sending or receiving faxes line busy
sounds like the modem on your printer has failed depending on how old it is most likely it would be cheaper to buy a new printer
Mar 24, 2014 | Brother MFC-7340 All-In-One Laser Printer
Willnotsendfax busy/noresponse
try sending a test to a known good fax number.
Jul 29, 2009 | Brother IntelliFAX 2800 Laser Fax
The machine seems to work ok, except when putting in a fax document, inputting the #, and pressing fax start, it pulls the document through, then just beeps every 2 seconds. It then does put out a...
The number that you are sending to is either busy, disconnected, or off the hook. To chek BEFORE dialing press the "HOOK" button (located to the left of the "1" key) and listen to the transmission this will help you in your troubleshooting. If you don't hear a dial tone BEFORE dialing, then the trouble is on your end.
A fast-paced busy signal could indicate a "downed" telephne line.
Finally, sometimes the line that you are sending to has so much stuff hooked up to it (56K dialup fax, multiple phones, alarm system dialer, credit card validator, teenage daughter) that you may be better off e-mailing instead.
GL
Jul 07, 2009 | Brother IntelliFAX 4100 Laser Fax
Beeping sound when try to fax. report says busy/no response
hi,
check it out weather it is in fax mode not in phone mode
Dec 15, 2008 | Brother IntelliFAX 2800 Laser Fax
Can't Send or Receive Faxes from MFC-7820 N
You may not need a separate fax line from Vonage. If you don't need a dedicated fax line, you can try changing the "Bandwidth Saver" settings on your Vonage voice line from your account on the Vonage website. Perform the following:
1. Login to your Vonage account online and click the "Features" tab.
2. Scroll down to the "Bandwidth Saver" link and click on the "Configure" button.
3. You will see a scrollbar with 3 settings: 30kbps, 50kbps and 90kbps
NOTE: My "Saver" was set to 90kbps (Highest Sound Quality) by default.
4. Click on 30kbps (Normal) and click "Submit".
5. Wait about an hour before testing as it could take that long for the change to take effect.
6. Send a test fax to the HP fax test service at 1-888-hpfaxme (1-888-473-2963).
NOTE: This is a GREAT service provided by HP. If your fax goes through correctly, you will receive a return fax within five minutes.
We upgraded to Verizon FiOS and never thought the increased upload speed (4mbps) would present an issue sending faxes. WRONG. We never had fax issues with DSL, Comcast or even Broadstripe VOIP service but for some reason Vonage + FiOS = no fax. That is until we set our Vonage VOIP sound quality to "Normal". Our phone voice quality has been much more reliable since throttling back. This sentiment has also been shared by other Vonage users who have experienced echoing and noise when utilizing the higher quality settings.
Your phone coversations may not have FM quality sound but they will have AM quality and usually that is just fine.
If your fax machine has a Telephone Answering Device (TAD) setting, you can share your voice line with your fax machine and be able to receive faxes and voice messages. Hopefully this will work for you.
Dave Grannas
Nov 04, 2008 | Brother MFC-7820N Printer
Faxes won't complete transmission
those noises you hear are line noises via your phone line, not machine related but they wreak havoc on faxing. first you need to replace the actual line connecting the fax machine to the wall. If this doesn't fix the problem then have your phone lines tested. also make sure your machine is set for digital or analog service, depending on which you have. Good Luck.
Sep 20, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Not connecting to fax out
Do you have a DSL or other digital phone line?
Jul 10, 2008 | Brother IntelliFax-2820 Laser Fax
Fax busy, no response yet fax is sent ok
NG or poor line condition on the transmission report means that there is interference on the phone line.you need to double check the quality of the dial tone-if it static or clear.now,other interferences could be caused by other devices on the same line as your fax such as DSL modems.make sure first that you connect the brother machine directly to the walljack and try resending a fax.modem settings can be changed.e-mail me if you need that info
Mar 18, 2008 | Brother IntelliFax-2820 Laser Fax
Vonage vs Brither 4100
Have you called your own fax line and just listened to the fax hand shake? might sound simple but I have called fax lines before and it just rang, or it was busy or static, if your not getting a clear fax hand shake, then it is the phone line, if there is no answer you may have turned your fax to manual receive mode, If you don't know how it should sound call a friends business fax line and listen to it. I have actually gone out to businesses that reported send or receive problems just to call the line and listen to a disconnect message, that would make it difficult to fax.
Jan 13, 2008 | Brother IntelliFax-4100e Fax
We can't send or received faxes
Just a suggestion. This effect can happen if you have plugged the line cord into the tel jack instead of line jack.
Oct 30, 2007 | Brother IntelliFAX 2800 Laser Fax
Brother IntelliFAX 2800 Laser Fax Logo
208 people viewed this question
James Cagle
James Cagle
ctnozil
Victorman
Victorman
