Question about Sony Ericsson W890i Cellular Phone
Its serious its just shutdowns suddenly when some applications are runned simultaneously.why?did it contains RAM
  • 20 Answers
All phones got ram ;-) try to install the update : http://www.sonyericsson.com/cws/download/1/110/61/1228141302/Update_Service_Setup-2.8.12.9.exe
Posted on Dec 15, 2008
What ram for
RAM is a type of computer memory accessed randomly during hard drive processes.
A computer's RAM is considered "random" because any byte of memory can be accessed without processing previous bytes.
Purpose of RAM
RAM is used to load and run programs or applications on a computer's operating system. More RAM means more applications and programs can be run simultaneously.
SRAM
Static Random Access Memory, or SRAM, stores data on a computer in a static method, meaning the data stays the same with power being supplied to the memory chip. SRAM is the faster RAM when compared with DRAM.
DRAM
Dynamic Random Access Memory, or DRAM, is a type of memory used in personal home computers. This type of memory must have an electrical current to refresh. DRAM is used more commonly because it's less expensive to manufacturer and install in chips.
EDO RAM
Extended Data Output, or EDO, is a new type of DRAM chip that uses technology to add 10 to 15 percent more speed than normal. A computer that uses EDO technology must meet the chip requirements or the EDO will not be recognized.
FPM
Fast Page Mode, or FPM, is a RAM speed enhancement that uses rows of bits selected in columns and rows of the memory.
FPM is used in EDO RAM.
Nov 02, 2012 | Computers & Internet
IC Problem
check all power and data leads from motherboard to hard drive and all of your cd/dvd drives make sure connections are secure dust free and not faulty
computers need all power and data to travel through every working device and to finish its cycle
so any faulty lead will end in computer error or shutdown or fail to boot
make sure your computers RAM modules are securely seated with no dust in the sockets also the Cmos battery has charge and seated with no dust in the sockets
some motherboards cmos batteries are soldered in
might be getting hot check your CPU make sure it has a thermal paste and a dust free and secure seating
could be a memory dump you might be running to many programs at the one time placing to much strain on the CPU you might not have enough RAM random access memory
you might have to many programs trying to or accessing the internet at the same time
scroll to bottom toolbar (bottom of screen) right click select task manager
applications you will see whats running
if you see anything you dont need running select end now and you might uninstall that specific
program if you or computer does not require it to run and
some unnecessary programs that could be jamming up your computer
also under processes see what is ticking over in the background again if you see something you
dont need to be running select end now and users you will see who is using your computer
you might need to add more computer ram
if you're not sure if a module is right for your system use the
Crucial Memory Advisor tool for a list of guaranteed compatible modules.
when purchasing any ram you should always ask if they can guarantee compatibility first you will need to select the manufacturer from a drop down list then select your product line
from a drop down list then select the model then click find it will take you directly to compatible ram also you will have an option to scan your system
hope this helps
Aug 01, 2012 | Computers & Internet
There is a small little coloured ball that comes on my computer and then it freezes while I am playing a game
Thanks for contacting Fixya Support.
Anytime you see the "rainbow pinwheel" which does manifest itself from time to time in Mac OS X environments, this is an indication of either a software issue or even a hardware issue.
Considering you are playing a game, it would be safe to assess that this issue you are having is in relation to the game you are playing (being unresponsive), means that this is a software issue.
There are several variables in regards to fixing issues with the spinning pinwheel in relation to a software.
If your application is not responding, you can first of all Force Quit the application by selecting Apple Command, Option and the Esc keys, and either select the game application in the window, which should be displayed as "Not Responding" and Force Quit or select Finder and simply relaunch it.
If you are unable to get your Mac OS X system to respond at all, then try a PRAM Reset process as shown below:
--PRAM RESET --
• First, hold in your power button for approximately 10 seconds to do a hard shutdown, if you have not already turned your Mac off.
• Once your Mac is shutdown, you will need to perform what is called a PRAM reset (Parameter RAM)
This should help with the freezing issue:
• Locate the following keys on the keyboard: Command, Option, P, and R. You will need to hold these keys down simultaneously .
• Turn on the computer.
• Press and hold the Command-Option-P-R keys. You must press this key combination before the gray screen appears.
• Now, hold the keys down until the computer restarts and you hear the startup sound for the third time.
• Release the keys and allow the Macbook to start up.
--Check to see if you are able to launch and play your game now.
If neither of these steps work, then if you have your Mac OS X installation disc which came with your Macbook, then I would finally recommend you perform these steps below with the installation (Macbook Restore) disk:
-RUN DISK UTILITY WITH MAC OS X INSTALLATION or RESTORE DISK-
Insert your Mac OS X Startup disk (Note: make sure the disk contains the same Mac OS X platform that your Macbook is currently running)
•Reboot your Mac
•At the Apple Chime, press the C key and hold it until you see a White screen, gray Apple and eventually a Spinning gear.
• Release the C key only after you see the Spinning gear.
•Mac will boot from the startup disk to the Installer environment
• From the Installer Menu bar, click Utilities > Disk Utility and open up Disk Utility application.
• Click on on the hard drive at the top of the window in the left sidebar and
• Select "Repair Disk"
**Let Disk Utilities run this repair the disk until completion
• At the end of this process, reboot your Mac
Now attempt to run your game application and see how your system responds after the Disk Repair process.
If the Macbook still persists in freezing or the game application still causes the spinning pinwheel to appear, then you may need to increase your Macbook's RAM memory, as the game may require more memory resources than you current have installed with your Macbook, or it may not be compatible with the current version of Mac OS X you are running with your Macbook.
I hope these steps point you in the right direction.
Regards,
-Mactechtrainer
Aug 20, 2010 | Apple MacBook Mac Notebook
My phone suddenly shutdown and the page cannot
HARD RESET
1) Start->Settings->System tab->Master Clear->1234->ok
2)Press soft-reset for 15sec.
3)Remove the battery, Simultaneously hold volume(-) button and red hangup button, while still holding those keys, insert the battery and wait for the led to go out, release keys and device will hard reset
3rd option really worked for me
Jun 21, 2010 | i-mate Jama 101 Smartphone
It shutdown suddenly while working
If Ur Laptop Shutdown While Working. Then First Check Out Your Bettery Life. If It is ok Then Make Sure Your Laptop Didn't Heat more. If Still You Face Problem Then Contact Hp Care No : 1800 112267.
Jul 29, 2009 | HP Pavilion TX2000Z Notebook
Automatic shutdown, crashing applications & no startup repair
Yes, sounds like some of you applications may have become corrupted. It happens over time. Find the backup program if XP >start>accessories>system tools>backup on Vista just type "backup" in the start box. You will see and option to back up all of your docs., email, web favorites, etc. Back them up then use the Windows disc reload the operating system You will also, have to reload your applications. That will take care of it. Good luck and let me know if you have any questions. Don't forget to rate this solution with 4 stars before you log out.
Feb 10, 2009 | Acer Aspire 4315 Notebook
Power PC G5 Dual 2.5 sudden shutdown and no reboot
In G5 always the cover should be closed properly if not it will start the fan very fast like a blower and the red leds will be on showing that the heat is over so please check that the cover is closed and locked from behind so itworks smooth and the power supply is standard or normal
u should always use genune parts with mac..
thanks
Dec 19, 2008 | Apple Power Mac G5 Desktop
HP laptop suddenly shuts down
clean ur cpu fan, its ventilaion is not occouring properly
Dec 11, 2006 | X-10 NU SBW242B/SBW242C Slim DVD/CD-RW...
Sony Ericsson W890i Cellular Phone Logo
49 people viewed this question
Top Sony Ericsson Cell Phones Experts
Damen Wong
Damen Wong
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
