Question about Sony KP-53S65 53" Rear Projection Television
Sony KP 53S65 Rear Projection TV
I am having a "problem" with my Sony Rear Projection TV. While watching a program, the screen made a loud "pop" noise, the screen went completely blank and an odor of some sort of burning was smelled. The TV was immediately turned off and disconnected. What could be the problem? Would it be cost effective to repair (the television is about 6 years old)? If it can be repaired is it something I can do myself. I am no expert but I know my away around electronics. Any help would be grealy appreciated. Thanks, Boo
  • 1 more comment
  • Cgirl1 Jan 03, 2008
    I was watching tv and heard a huge pop and a burning smell. What could be the problem and cost to repair
  • Weasel100 Jan 15, 2008
    WHILE WATCHING...LOUD "POP" THEN A WHITE DOT GONE TO BLACK AND A BURNING SMELL...UNPLUGGED AND NOT TRIED AGAIN. SCRAP OR REPAIR?
  • Anonymous Jul 05, 2008
    same problem, Sony KP 53S65
    Problem Solver:
  • 8 Answers
You have a bad capacitor, its location number is c514, and it is located near the horizontal output transistor. i just finished 2 of these sets, the cap values are 390pf @ 2kv. best of luck to you.
Posted on Apr 17, 2008
I don't know if this will help you but I just experienced a similiar problem with a sony kp-53s35.
It turns out that a fluid leaked out of a rubber boot on one of the guns( I have no idea what the fluid is or why it is corrosive), down to a circuit board and started to desolve a jumper wire. when it had eaten away enough of the wire, the residue or solutionSony KP 53S65 Rear Projection TV - 1.gif was conductive enough to cause an arc to a ground bus bar that ran along the circuit board. The TV still worked but would crack and pop like firecrackers inside.
I was able to increase the distance to the ground source by bending the bar away. Then I scraped and scrubbed the board with contact cleaner to remove residue and replaced jumper wire.
Has worked fine since.
Posted on Feb 23, 2008
Did you get this TV repaired? What was the cost of the repair? My neighbor has the same tv with the exact same problem. Before calling a technician, I'm trying to find out if they should just scrap it and buy a new tv. Thanks for any help.
Posted on Aug 15, 2007
  • 103 Answers
The unit has a bad crt Itis a known problem Callsony to see if they will authorize a part coverage on the crt
Posted on Mar 22, 2007
How do i get the pip to work with a cable box on the sony kp-53s65
You would need another cable box to watch a different channel on the secondary picture. If you can hook up another cable box then that one will plug into the secondary input.
May 05, 2011 | Sony KP-53S65 53" Rear Projection...
Is it possible to replace the bulb in this tv or something like that? I was watching it the other day when a loud pop occurred and there was some burning smell accompanied by the picture and sound going...
Shop around for the Big Screen repair Tech. Shop.The problems u discribing,the tv have more than a dead projection bulb.Circuits boards have burn components,must be trouble shoot and replace first.Before even know the static of the projection bulb.
Jul 16, 2010 | Sony KP-53S65 53" Rear Projection...
When I turn on my sony (KP 53S65) the screen doesn't light up
The most common problem for this TV is a bad capacitor (C514)
Call a good TV Tech and have him check for that first. Should be a $125 job at the most
Jul 31, 2009 | Sony KP-53HS30 53" Rear Projection...
I need to replace the bulb in kp-53s65
This TV does not have a lamp only 3 CTR tubes which bulb are you looking for?
Jul 11, 2009 | Sony KP-53S65 53" Rear Projection...
I have a sony kp-53s25
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
good luck
please mark the post with a fixya!
Nov 21, 2007 | Sony KP-53S65 53" Rear Projection...
KP-53S65 blury at times
the screen control and the focus control on the flyback transformer need to be turned down a little
Nov 12, 2007 | Sony KP-53S65 53" Rear Projection...
Sony kp-53s65
i have a sound no picture
Aug 07, 2007 | Sony KP-53S65 53" Rear Projection...
Samsung HDTV 1080i blue congernce/loud pop
One of the Convergence IC's most likely shorted and that is the pop you heard. Is best to replace both and check micro fuses supplying + & - dc voltage to the chips. Also check the resistors in front of the IC's as they discolor or burn & change value.
Jul 04, 2007 | Sony KP-53S65 53" Rear Projection...
Need to know part number or value for C514 in horiz out put circuit for kp-53s65
C514 has three different values possible. Just use this value as it has worked fine for me in the past. 680pf /2kv Sony part# 1-162-116-00
Jan 20, 2007 | Sony KP-53S65 53" Rear Projection...
Sony KP-53S65 53" Rear Projection Television Logo
211 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
