Question about GE JGRP17 Gas Single Oven
GE gas oven won't stay lit
Oven will start in Bake mode when cold and heat up, but unit shuts off sometime after it heats for a while. If the set temperature is low, say 200 F, it reaches this temp and sounds the ready beeps. If the set temp is high, say 400 F, it usually shuts off before reaching that temp. Today, it shut off at 285 F. Once it shuts off, it will not re-light until it cools completely down. If you light the broiler first, it burns OK, but if the oven shuts off, the broiler will not light. Checked both igniters and they are drawing proper amps. Checked 3 limit switches noted for this unit - the ones marked 157 and 158 are normally open and 159 normally closed in cold mode. When the oven shuts down, I checked the limit switches and all are in same mode as when it is cold. Checked continutiy across gas valve and it's good. No codes. Any more ideas??
5 Suggested Answers
jumptrout51
  • 3361 Answers
SOURCE: GE JKP27 F2 error
F2 Oven over temp - exceeded 590F with door in unlocked position or 990F with door locked If actual temp condition occurred, look for welded relay contacts or high resistance connection or any cause in the oven temperature sensor circuit
Posted on Oct 30, 2009
heatman101
  • 43501 Answers
SOURCE: Oven/ broiler will not heat and bottom element slow to reach temp
Check out this tip that I wrote about this problem...
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Posted on Apr 28, 2010
  • 523 Answers
SOURCE: GE Wall Oven won't hold temperature and sometimes shuts off
t stat
Posted on May 27, 2010
bestdarngood
  • 3037 Answers
SOURCE: GE Model JKP12G0P2BG Wall Oven Bake Element Not Working Properly
The temperature sensor is bad. The broil element will work even if the temp sensor is bad but the bake element will not. If you measure the resistance across the contacts on the sensor, it should be around 20 ohms, if it is much higher (1000+), then it is bad and should be replaced. It is just as easy to replace as the elements and looks like a small pencil sized rod in the inside top of the oven. Let me know how this works out for you.
Benjamin
Posted on Nov 04, 2010
Will not stay on will shut off
Whirlpool Gas Oven Will Not Stay Lit - Appliance Repair Forum
forum.appliancepartspros.com/oven.../482851-whirlpool-gas-oven-will-...
Jun 20, 2012 - 2 posts - ‎1 author
My Whirlpool gas oven will light but not stay lit. It has a glow plug igniter that heats up enough to allow the gas valve to open. Once the burner ... oven lights, but does not remain lit
Feb 19, 2013
Oven does not stay lit
Jun 19, 2012
Oven will ignite but will not stay lit
Aug 3, 2010
Gas Oven won't stay lit
Mar 25, 2008
More results from forum.appliancepartspros.com
Jan 04, 2016 | Ovens
I hav whirlpool accubake.oven wont stay lit.it ignites then flame goes right back out
Whirlpool oven won't light - Appliance Repair Forum
forum.appliancepartspros.com/oven.../225907-whirlpool-oven-wont-lig...
May 19, 2011 - 10 posts - ‎2 authors
I have a Whirlpool Accubake oven (SF362LXSS0) that doesn't seem to be consistently turning on, and the problem's getting worse. ... If I try to turn it on to bake, I hear several clicks, but not that "gas oven turning on" sound and no heat comes out (but a slight smell of gas is ... Whirlpool Gas Oven won't stay lit
1 post
Oct 25, 2012
whirlpool oven won't stay on
1 post
Aug 13, 2012
Jun 20, 2012
whirlpool accubake oven will not stay lit
1 post
Nov 9, 2009
Whirlpool Accubake Model # GW395LEGQ4 - Oven won't Start ...
Dec 12, 2015 | Stoves Ovens
My oven is not heating up properly, it either doesn't heat up or it takes a very long time to heat up. The range top works fine and the broiler works, but when i set it to bake it doesn't or takes long.
There are two possibilities for problems with the range. If it has a "timed bake" setting for the oven then it's possible that the last person who used it neglected to return the setting to the manual mode. In "timed bake" mode, the oven will heat to approx. 160 - 185 degrees, what is called a "keep warm" temp. It will maintain that heat setting regardless of what you set the oven temp control to, as long as you're not in the time frame that it's set to bake. This will make trying to bake anything a very difficult procedure.
The second possibility is that the oven glo coil igniter is cracked and will not heat to the proper temp to allow the electricity to flow through it to the oven gas safety valve to allow it to open and let the gas flow to the burner. These things are ceramic and for some reason crack in normal use. If it has a top broiler, that unit is obviously good. Unfortunately, the igniters are seldom interchangeable. You would need a tech to check the igniter with an ohmmeter.
Mar 23, 2011 | Amana Ovens
Oven will not heat on bake.
does the ignitor glow? if it does and the burner does not fire within 30-60 sec. replace it it is weak .if the ignitor does not come on at all youll need to check for voltage at the ignitor when the bake circut is on.
Sep 16, 2009 | GE JTP86 Electric Double Oven
Frigidaire gas oven not heating
replace the bake ignitor its getting weak
Jul 01, 2009 | Frigidaire FGB24T3A Gas Single Oven
My gas oven stays warm even though it is turned off
A standing pilot such as this will give off heat. So long as the gas bake burner is not lit also, you will be fine. If the bake burner IS lit you have a defective oven control.
Jun 26, 2009 | GE Ovens
GE JGRP17 Gas Single Oven Logo
99 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a GE Oven Expert? Answer questions, earn points and help others
