Question about Ahead Software Nero 6.0 (60045) for PC
My photosmart C4200 printer grabs the paper in the right hand corner first and creates a paper jam.
  • waltmon Dec 28, 2008
    Bought the printer new last X-mas....jams every single time we attempt to print.
    Please respond to norvarchivist@aol.com if possible.
    Thanks so much,
    Walter
  • 679 Answers
Sounds like you need new rollers.
Here is a website that has instructions to replace the rollers.
This is for the 2300
http://www.laserpros.com/pdf/HP%202300%20Kit.pdf
this is for the 1320
http://www.laserpros.com/pdf/HP%201160-1320%20Kit.pdf
Posted on Dec 17, 2008
Hp photosmart printer keeps saying paper jam
Use a flashlight to examine as much as possible of the papaer path. There may be bits of paper or paper debris lodged in some obscure corner
Sep 29, 2012 | Cisco Photosmart C4780 Wireless AllInOne...
Paper feed will not grab paper, tells me to load paper or there is a paper jam.
if paper is jam open the printer and remove it
if the problem still remain then take printer to printer shop
Jan 02, 2011 | HP Photosmart 375 InkJet Printer
When I want to print something, if I go to file then print, it says offline, bot when I click on the C4200 series( copy 1) it will print BUT brints VERY small. Am I supposed to doing something...
  1. Click start --> Control panel --> Printer and faxes
  2. Right click on printer 'C4200 series' and select 'Set as default printer'.
  3. Right click again on the same printer icon and select 'Use printer Online'.
  4. Try Printing.
  5. You can delete the icon that says 'C4200 series(copy1)' if you are not using it.
Regards
Riztech
Oct 24, 2010 | HP Photosmart C4280 All-in-One InkJet...
Message shows "Paper jam" but there is no paper jam
try turning off the printer for about 10 sec. to clear its memory and turn it back on.. then print again
Oct 19, 2009 | HP Photosmart C4250 Multifunction Photo...
Hp photosmart C4200, paper was jammed, pulled it out of the front, I don't think there is a jam anymore, but the printer still says there is a jam
There may be a small piece of either paper or dust on the sensor. Using a can of compressed air blow out the full paper path. If you still have an issue after that you may need some servicing.
Sep 14, 2009 | Office Equipment & Supplies
Carriage Paper Jam in Photosmart hp c6180 all-in-one-printer
Here's what you do. Take a look at the photo below.
Open the cover of the printer, where the ink cartridges are located. Behind the ink cartridges is the carriage, which is a box that moves side-to-side on a pair of rails. It's the thing that sprays the ink onto the paper.
You have to reach in with your hand and slide this thing to the center. Then, look to the very sides, left and right, for any bits of paper. If you look at the second picture, you can see my finger pointing to a small bit of paper that tore of and got jammed into the side. See the little crumpled bit of paper? It's preventing the carriage from sliding all the way to the right. You could have little bits on the right or left side. I had to reach in with needle-nose pliers to grab the paper bits out, but maybe your fingers are small enough.
Once the little bits of paper were out, I was back in business. Good luck!
Mar 15, 2009 | HP Photosmart C6180 All-In-One InkJet...
Jammed paper in hp C4200 series
Open up the back of the printer. There should be a panel that comes off that gives you access to the paper feed mechanism.
Mar 01, 2009 | HP Photosmart C4280 Aio Printer
Scanning problem on photosmart c4280
For a quick fix that doesn't involve downloading or installing anything, open the printer icon in the dock ("HP Photosmart C4200 series") and click the Scanner button in the upper right hand corner, then click "New Scan."  It should scan with no problems!  At least it did for me. : )
Apr 06, 2008 | HP Photosmart C4280 Aio Printer
Ahead Software Nero 6.0 (60045) for PC Logo
83 people viewed this question
Top Ahead Software Computers & Internet Experts
Bharat Das
Bharat Das
Alun Cox
Are you an Ahead Software Computer and Internet Expert? Answer questions, earn points and help others
