Question about Sony Video Game Consoles & Games
Ps2 with audio and distorted horizontal lines video
All connectors, adapter replaced with new one
but still no video
2 Suggested Answers
  • 1003 Answers
SOURCE: PS2 Video
clean lens with canned air and wipe rubber wheel on top of drive motor off with rubbing alcohol applied to a microfiber towel reassemble and have fun
Posted on Jan 13, 2008
When i turn on my ps2(slim) i cant see or hear eny on the TV way is the happing plz help me
Check your A/V cable connections. They are the Yellow (Video), White (Left audio), and Red (Right audio)wires coming from the back of your PS2 to the connectors on your TV. Be sure they are plugged in and they have a tight connection. Also, be sure they are plugged into the appropriate jacks. They jacks are usually color-coded to match the connector type. Then check to make sure the plug that connects to the back of your console is in the correct port and is snug as well. A loose connection anywhere will prevent anything from coming up, the PS2 was infamous for that.
Aside from issues with A/V, be sure your TV is on and tuned to the correct source. If your PS2 plugs into an RF switch which plugs into the coaxial (cable) port on the back of your TV, the channel should match what the RF adapter is set to before turning on the console. If the PS2 is plugged into your TV through the A/V cables (The yellow, white, and red connectors we discussed earlier), make sure your TV is set to the proper source. The source channels could either be labeled "Video 1," "Video 2," or "Video 3," depending on your configuration. Also, the source could also be labeled "Game."
If none of the two solutions above work, then it appears your PS2 has bitten the dust. Best thing to do is give it a nice tombstone with a beautiful eulogy to make even the most battle-hardened tough guys cry like a baby
May 04, 2011 | Sony PlayStation 2 (PS2) Console
Tip
Tv problems lg and vizeo
Power Issues Troubleshooting
*NOTE* LG & Vizio TVs must be plugged in for 5 minutes before it will turn on*
1. Inspect ALL Ribbons and connectors. Any tears or bad connections between boards must be replaced FIRST
2. If you have any of these boards, it should be the first board to be replaced
A) T-Con Board - Video Problems (No Video with standby light on, audio but no video, grainy, distorted, or color problems in screen)
B) X or Y Buffer Board (Plasma TVs only) - Standby light is on but no power
C) Backlight Inverter / LED Driver - No Video with standby light on
3. Main Video Board
- Either video or audio does not work (if no T-Con in TV. If audio but no video it is T-Con)
4. Power Board - No power AND standby light does NOT turn on. If standby light is on try other boards above
5. Panel - No power, distorted picture, lines, slow motion, half screen, faded in / out. Panel problems are usually not worth replacing the panel.
on May 22, 2015 | LG Televison & Video
I can't get my PS2 to connect to my dual xdvd270
You can connect the PS2 Video out (composite video out) to any of the 2 monitors video connector and the audio at the audio connector, remember to select A/V ext (External Audio and video) both video and audio uses 3,5mm jacks, if it does not work you might need to try to draw out the jacks a little, the connectors are of poor quality so be carefull.
You also might want to check if the right system is selected PAL/NTSC, check the format from your PS2 and set the monitor to accept the same signal type, then it should work fine.
The only thing I am not sure how you do is to get the composite video out of the PS2 but study the manual or google and you will find it I guess, but my guess is that you allready have that part covered.
Jan 03, 2010 | Dual XDVD270 Car DVD Player
USB Keyboard and mouse wont work with PS2 KVM with adapter
Have you tried rebooting once it is connected? Not sure if it makes a difference, but I know you can not hook up PS2 peripherals without rebooting.
Nov 03, 2009 | Dell OptiPlex GX280 PC Desktop
How do i set up a ps2 to a tv that only has a yellow and white input
It's called a "composite" adapter cable for PS2. The yellow RCA connector is composite video. The white RCA connector is left-audio (usually there's white and red for stereo - left/right)
There should have been a cable that came with your console, but in case you bought it used, here's a picture of what it looks like.
Also, you can buy one aftermarket:
http://www.amazon.com/MONSTER-CABLE-Hookup-PlayStation-PLG200/dp/B0000524PE
Look around, I wouldn't pay more that $15 for it.
Oct 03, 2009 | Sony PlayStation 2 (PS2) Console
PS3 disc games look distorted, while other discs run fine.
oh i know this problem i have the same check the cable with the audio and video if i doesn't work send it to sony or just buy a new one
Oct 02, 2009 | Sony Playstation 3 (PS3) Console
How do i connect my PS2 with my PC
on the back of your computer box, you will (probably) find 2 ports that look like this. the PS2 mouse will be plugged into the green colored port. NOTE: PS2 mice (and keyboards) will only fit into the port ONE DIRECTION, so don't force it! make sure to line it up
once plugged in, you will need to reboot your computer, as PS2 can only be recognized while the computer is starting up.
one final note: some of the newest computers DO NOT have PS2 ports. if this is true of your computer, you will need to get a new mouse, or an adapter, like the one shown below:b6b70e7.jpg
Aug 27, 2009 | KEIO PS2 Optical Scroll Mouse
Screen displays colored horizontal lines
Before you begin remove the battery and the ac adapter.Beneath the control panel(ie where the power button resides) is your connector for your lcd pry from the right side carefully the panel,it will pop up remove the lcd cable from the motherboard connector and re-seat it.Replace the control panel replace the battery and the ac adapter power on this usually fixes the problem
Aug 24, 2009 | Dell Latitude D505 Notebook
Video & audio interruption
damaged power supply board or damed vga board could be capacitors or other issues need a service tech to look inside and see what gong on.
Apr 30, 2008 | RCA G2G Gear 5" TFT Game Kit
PS2 Video
Jan 10, 2008 | Sony PlayStation 2 (PS2) Console
Video Game Consoles & Games Logo
178 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
