Question about Philips Refurbished POWER SUPPLY 50/60 HZ (75111271) Power Supply
High pitched squeal coming from power supply on my philips VCR
We had a Brown out/Black out recently and the video started making a high pitched squeal from the power supply. Very occasionally after switching it off it will work for 2-5 minutes and then start making the high pitched squeal again with no power to the vcr. On the whole though it just makes the noise and no power to the VCR. I have removed the power supply cleaned it and viewed it to see it anything obvious would stare back at me. but this was to no avail. I am living in Australia and would appreciate any help anyone out there could give as this is the only useful site I could find. It would be much appreciated. Thank You. PS. It is a Philips VR3261/75
    Problem Solver:
  • 5 Answers
Hi , i am a hardware engineer in the uk here to help if i can, the vga, doesnt normaly squeel , i have not heard of this problem , is the graphics card pci or does it go into the brown slot,if its pci the try change the card to a new one if its a brown slot where the card goes it may be the board slots blown as you say the vga only works for a few moments , see if that helps regards steve
Posted on Mar 19, 2007
My tv powers on displays the LG logo then makes a high pitched squeal sound from speakers and then flashes on screen (strobe light effect) does not display picture or sound.
LCD TV Repair Tutorial - LCD TV Parts Overview, Common ...
? 11:05
https://www.youtube.com/watch?v=tS4sIpdajVw
Aug 23, 2013 - Uploaded by ShopJimmy.com
Repair review of common LCD TV Problems and Repair Solutions ... input the tv is set to it begins making a high pitched whiningsound. .... I have a LG 47LN5750 that powers on, flashes a good picture for about 1/2 second, then goes dark. ... hi my samsung tvis not turning on is black. and I just replace the ...
#Treat At Home high pitched whine from plasma tv Tinnitus ...
www.aspenridgerentals.com/tinnituscure/?...high%20pitched%20whine%...
LG 50PK540 plasma TV Repair power supply EAY60968801 Part 1-2 ... Sanyo DP42849 with high pitched squeal after replacing power supply. ... In my second daily fix video, I solve a mystery that was making me having to turn off my speakers before I went to be ... The flash is accompanied by an high pitched sound.
TV not turning on; making high-pitched sounds - Tom's ...
Dec 16, 2015 | LG 55LE5400 TV
I have a Panasonic vcr that has recently has gone awry.and is making a very high pitched noise and will not power on
It sounds like either a mechanical failure shutting the machine down or the switch mode power supply just gave out. Repairing VCR's is not worth the charges these days BUT head to your local Goodwill store. There you'll find a stack of good VCR's for less than $10 each.
Jan 08, 2014 | Panasonic PV-V4523S VHS VCR
Dryer was making high pitched squealing noise and now won't run
Please supply the model number so we can help further.
May 20, 2012 | Hotpoint Dryers
Squealing sound on magnavox tv
if a high pitched whine or buzz it is likely coming from the power supply board.
May 15, 2012 | Philips Magnavox 42MF521D/37 Television
RCA VCR makes high pitched whining noise when it's on...
The power supply is starting to fail. There are a number of capacitors in the power supply that need to be replaced. A local repair shop should be able to fix this easily. Figure on $10 max for parts.
Dan
May 05, 2009 | RCA VR508 VCR
High Pitch squeal everytime t.v. is turned on. 20min warm-up.
sounds like the switchmode power supply is varrying in frequency ..needs to be checked by qualified tech,,,
Apr 16, 2009 | SNK Magnavox 19MF338B/27 19 in. LCD TV
Philips DVDR 3506/37 - when in stand by mode -
I had the same problem, it is a Diode on the Power Supply Board. The Location number is D1054, you should change C1051 also. It maybe leaky. I used a 10v 1000uf capacitor instead of the 6.3v 1000uf it had. Make sure to be careful when changing these components, making sure the polarity is right. Good Luck!
Jan 22, 2009 | Philips DVR-1
High pitch
I have never heard a tube make noise when there is a good picture. Anyway, the noise has to be a transformer ringing or oscilating. They make a high pitched squeal when they have a loose winding or their cover is loose. You probably won't be able to feel or see anything loose on these transformers The power supply switching transformer is the first to look at. Take a hot glue gun and just cover the thing...especially at the base of it. The next (and only other) one is the horizontal drive transformer.It is located close to the high voltage transformer( biggest thing on board and usually in back or corner of the PCB.This one wont squeal) The horizontal drive transformer is about the size of a large marble and is encased in a black plastic cover. Cover it with hot glue also.
If you take the back off you will probably be able to localize where the squeal is coming from. You will probably need a signal to hear the noise also. After you find where it is coming from UNPLUG the set before doing any hot gluing!!!!
If you 're not up to this procedure take it to a technician. Your tube is not going bad and the set is definitly worth repair. Simple fix!! Good Luck!!
barneyluc
Oct 03, 2008 | Sharp 32SC26B 32" TV
Computers & Internet Logo
462 people viewed this question
Top Philips Computers & Internet Experts
micky dee
Steve Allison
Steve Allison
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
