XEROX WC 7345
Hi To all
if you can help me
i have machine WC7345 and i have fax in this machine
any fax received i need to foreword all the fax to email
Pleas if u can send step bye step
  • 54 Answers
SOURCE: can't receive fax but can send
Call your cell phone from the fax machine and check the caller ID to make sure that it is the correct number for your fax machine. Next, call the fax machine from you cell phone, and make sure the fax machine rings. Problems like these are almost always a phone line issue, not the machine.
Don't forget to rate your solutions please.
Posted on Dec 04, 2007
SOURCE: Brother MFC 8860DN: Send Problems
Update the firmware and it does support SMTP-AUTH
Posted on Apr 15, 2008
SOURCE: Error is fax full cannot send or receive. Please help !! Hp J6480
I have not found the answer to this in the manual however, you may solve the problem in the following steps:
1. From the Setup menu, choose #6 Tools
2. Choose #6 Clear fax log
Problem solved! Hope you found this answer helpful.
sg
Posted on Feb 24, 2009
leroyal
  • 2120 Answers
SOURCE: Setup FAX...
Plug a phone cord into the LINE port of your machine. Ideally it should be a dedicated phone number, but you can share a line.
Sending a fax is just like making a phone call.
Load your original face down , dial the fax number, press send or start.
Receiving will be automatic.
Posted on Mar 15, 2009
Healeyman
  • 1198 Answers
SOURCE: My fax machine will send faxes but not receive them. I have made sure it is plugged in and connected but no faxes will come through. Please Help!
If you have an answering machine, have it answer at three rings. Have the fax answer at five rings. Let the answer machine go thru it's cycle, and see if the fax picks up.
Posted on Apr 27, 2009
Xerox 7345 error 004-361
what is the solution erro code 004 361 Machine docucolour 7345 ?
Dec 09, 2014 | Xerox WorkCentre 7228 7235 7245 7328 7335...
Erreur cod 009-330 xerox 7245
009-330 error code xerox work center 7345 problom & soluson
Jul 10, 2014 | Xerox WorkCentre 7228 7235 7245 7328 7335...
How do I know my fuser is good or not?
If the toner rubs off the page after it comes out of the printer the fuser is bad. Fuser wires get very hot, so if the page isn't slightly warm, thats a good indicator of a worn fuser wire
May 30, 2014 | Xerox WorkCentre 7228 7235 7245 7328 7335...
Fault error occurred no. 123-333
I install xerox new machine when turn on gives error code 123-333
Jun 20, 2013 | Xerox WorkCentre 7228 7235 7245 7328 7335...
How do i reset my drum for xerox workcentre 7345
You can't reset the drums counter on the machine. The drum has what they call a CRUM on it. It's the micro chip on the drum frame. You can buy new CRUM's or use one that still has some life on it. Press the two plastic retainers to remove the CRUM.
Nov 30, 2012 | Xerox WorkCentre 7228 7235 7245 7328 7335...
Losing print quality on blue on a new 7345
Most likely if you go into the tools screen and perform a Auto Gradation setup it will come back.
But being that it is a 7345 and new, it should be under warranty.
Call 1-800-821-2797 and give them your serial number. Let Xerox correct it as they should.
Jul 30, 2008 | Xerox Office Equipment & Supplies
I need to know where to install a postscript kit on a Xerox Workcentre 7345 multi-function printer/copier?
PostScript language support is available as an upgrade kit from Xerox - You need to buy it and I was advised it is around the £400 mark.
Jul 01, 2008 | Xerox Office Equipment & Supplies
Computers & Internet Logo
186 people viewed this question
David Payne
David Payne
