I reformatted my hard drive and istalled XP s1 and after SP2. Everything works except that I cannot install my Lexmark X6100 series printer. The printer works great with other computers. I downloaded the drivers from Lexmark for XP s2 and I still cannot install printer. I keep getting the message " Hardware cannot be installed etc. I noticed tha the print spooler in msconfig is stopped?
  • Angelglez Dec 17, 2008
    My Desktop PC is not recognizing anything installed on the USB ports. As I have stated, I reformatted my hard drive and installed Xp sp 1 and then downloaded all updates until I got to Sp2 and then installed it. Everything works except that I cannot install my USB printer(Lexmar x6100 series). I went into ms services and made sure my printer spooler was on auto. However, when I run msconfig, it shows it as stopped, even after rebooting. As I mentioned, I have an extra USB mouse and it too does not work regardless what USB port I use. All my hardware used to work on this computer prior to reformatting.
  • Angelglez Dec 18, 2008
    Thanks for the help. However, I ended up removing XP SP2 and SP1 allowed me to install the printer. I tried to reinstalled SP2 and I crashed severely. Since I had no data saved, I reformatted and I installed win 98 and all my peripherals and when I have 10 hours to spare, I'll install my XP upgrade and then go thru the endless upgrades updates until I get to SP2. Then we'll see....This is an old computer that it's only used for emailing and I refuse to buy a new one. (PIII 866 MHz /Asus motherboard).
  • 68 Answers
If this is actually a usb problem which it sounds like then it is much simpler to resolve. I would just download the latest motherboard drivers from the manufacturers website an reinstall these. USB drivers are generally installed when the motherboard drivers are installed, espicially if the USB card is in a pci slot
Posted on Dec 17, 2008
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
With the indulgence of the others...
If the Print Spooler could be started and yet problems in installing the printer, additionally pls try make sure that the Remote Procedure Call is set to automatic and running.
If with both started and running and yet an error will be displayed "Error 23: Data error (cyclic redundancy check)", sorry but you might be better off doing a clean/fresh install. At this early stage and errors are present, it is likely others will follow. You may also want to confirm the the XP CD installer has no scratches and that there will be no install error during the process.
Good luck and Thank you for using FixYa. Happy Holidays.
Posted on Dec 15, 2008
  • Louie  Role
    Louie Role Dec 17, 2008
    Hi again,
    Based on your subsequent postings, re-install/update the USB drivers not from Microsoft but from the download & support of the motherboard manufacturer.
    Cheers.
    Genius:
  • 2,035 Answers
If you are not able to install even after starting the spooler then ,
  1. Go to Start, All Programs, Lexmark, Uninstall Lexmark.
  2. Reboot the PC.
  3. Go to Start, Control Panels, Printers and Faxes.
  4. Go to File, Server Properties, Drivers.
  5. If there are any Lexmark printer drivers, select them and click Remove.
  6. Open Windows Explorer.
  7. Go to C:\Windows\System32\Spool\Drivers\w32x86 and delete all the Lexmark files from this folder.
Then try to install the driver....
Good luck...
  • Anand Kumar
    Anand Kumar Dec 18, 2008
    1. Right click on My Computer and select Properties.
    2. Click the Hardware tab, then click on Device Manager.
    3. Click on the plus sign (+) beside Universal Serial Bus Controllers.
    4. Right click the problem device (printer).
    5. Go to Properties, Driver, Update Driver.
    6. Choose the option to Install from list or Specific Location.
    7. Click Don't Search, I will chose the driver to install and then click Next.
    8. Click Have Disk.
    9. Click Browse.
    10. In the Look In screen, select the C: drive from the drop-down list.
    11. Double-click Windows, then double-click INF. The USBPRINT.INF file for the printer will be displayed.
    12. Select this file and click Open.
    13. Click OK in the remaining screens that appear.
    Sergeant:
    Champion:
  • 331 Answers
Did you try enabling the printer spooler. using services.msc
do to  mycompute->properties->hardware->devicemanager
and check  whether the printer is being detected or not. and post back the resut.
  • 6,487 Answers
Try to remove the printer software from your computer then disconnect the printer from the computer and then restart the computer... Try first to connect the printer and let the computer recognize your printer and install the driver for it don;t run the software for the printer....
  • Mark Gil
    Mark Gil Dec 18, 2008
    You're welcome feel free to contact us back for any updates about this concern so we also know what happen to your problem and what solve it...
    President:
  • 2,110 Answers
Try to start printer spooler in services by doing this
Goto Start>Run>type services.msc and there right click on the print spooler and start...
  • Sibananda Jena
    Sibananda Jena Dec 17, 2008
    try following steps..
    HKEY_LOCAL_MACHINE\SYSTEM\CurrentContr...
    2. When you do so, the USB storage device does not work when the user
    connects the device to the computer. To set the Start value, follow
    these steps:
    3. Click Start, and then click Run.
    4. In the Open box, type regedit, and then click OK.
    5. Locate, and then click the following registry key:
    6. In the right pane, double-click Start.
    7. In the Value data box, type 3, click Hexadecimal (if it is not already selected), and then click OK.
    8. Quit Registry Editor.
  • 13,433 Answers
Ok, press start -> run -> type in services.msc
now find print splooer from the list, right click properties, change the start up type to automatica and start the service.
This is just a start so get back to me with results.
When i start it up, only the "vaio" is occuring on my screen. i tried to reformat it using xp sp2, but it doesn't working. what should i do
In that case, put your Windows XP disk in the drive and boot up. During boot up press F2 and set the boot sequence to CD. Windows will install XPon your hard drive. Follow the promps and after the istallation is finished, download and install SP3.
Apr 01, 2010 | Sony VAIO NS Series VGN-NS130E/W Notebook
My Lexmark x6170 all-in-one Printer will not scan
I have the same printer, Windows Vista, and also only use the device drivers, but do not experience the problem you are having. The only problem I have with it is that scanning using MS Office 2007 times out before the image can completely transfer. So uninstalling your existing drivers and then reinstalling may do the trick.
If you still wish to install the All-In-One Center software, Lexmark will only provide the device drivers, as you have discovered. However, there are reports that the Lexmark X6100 series AIO (All-In-One) is identical to the Dell A960 AIO. And, fortunately, Dell is kind enough to provide the similar All-In-One Center software.
Click here for the 32-bit Windows XP version. (just in case)
Click here for the 32-bit Windows Vista version.
Give it a try and please report back as to whether or not it worked for you.
Jul 05, 2009 | Lexmark X6170 All-In-One InkJet Printer
I have vista and my x6100 lexmark printer not responding please help. i when on the lexmark website no help
It looks like the X6100 series of printers are supported on Vista starting with model # 6150 through 6190 Pro.
Based on the above information, I would say that the X6100 is not supported on Vista.
Jun 14, 2009 | Lexmark X6100 Flatbed Scanner
I have the disk it installs everything but it wont work it needs a driver please download the needed driver i'm using vista thank you Kim
You have to install the software drivers in compatible mode of Windows XP SP2.
Right Click on the setup file----->Select Properties------>Select Compatibility----->Select the "Run in the Compatiblility Mode of Windows XP SP2"------>Also select "Run As Administrator"---->Apply----> OK.
Now reinstall the Printer Software. It will work for sure.
Jun 07, 2009 | Lexmark Z600 InkJet Printer
Lexmark all in one printer don't install on vista. is there a patch
You may want to see if the Printer is actually compatible with Windows Vista first before you try anything else.
If your Printer is Listed Below, then unfortunately it will not run on your system unless you format the machine and downgrade to Windows XP. (Or obviously you can wait until the device is supported, but to be honest that could be months, years).
exmark
  • Lexmark Z11, Z12, Z22 & Z32, Z31, Z42, Z51, Z52 - work with pre-installed drivers
  • Lexmark Color Jet 3200, 5700 - work with pre-installed drivers
  • Lexmark X5400, X4200, X1200, Z645, Z840, Z730, X2400, X3400, P350, X7300, X8300, X9300
  • Lexmark X1100, Z500 & Z600 (combined), P4300, X3300, X2300, X7100, Z810, Z700, X5200, P6300, P910, P6200, X6100, X5100, X2200
  • Lexmark 1100, 1200, 2400, 3400, 4200, 5400 Series, Lexmark X7350, X8350, X9350, P350, Lexmark 640 Series, Lexmark 730 Series, Lexmark Z845[4]
Dec 04, 2008 | Laplink Software PCmover for PC
Lexmark X6170 fax bvrp
it's supposedly bundled with that printer..
here are some instructions..
How to Install BVRP FaxTools Software on the Lexmark X6130/X6150/X6160/X6170/X6190 Pro ID:ENUS8694 null.gif null.gif null.gif
The FaxTools software is on the Lexmark X6100 Series Installation CD. During installation of the printer driver, you will be asked whether you want to install it. If you choose to cancel this option during the installation process, you can install the software separately as follows:
  1. Insert the Lexmark X6100 Installation CD into the CD-ROM drive.
  2. When the Install Software screen appears, click Cancel.
  3. Right click on the Start button and select Explore.
  4. Click on the plus sign (+) beside My Computer .
  5. Click on the plus sign (+) beside the Lex X6100 CD.
  6. Double-click on the FAX folder.
  7. Double-click on the relevant language folder on the right-hand side.
  8. Double-click on the Setup executable. (Note: The correct setup icon is the one with two white arrows on a grey foreground.)
  9. Follow the on-screen instructions to complete the installation.
Feb 18, 2008 | Lexmark X6170 All-In-One InkJet Printer
Installing Lexmark 6100 series all-in-one to new hp computer
There are some compatiblity problems between Vista and your printer. Check this web page to download a driver that may provide limited printing capability for your printer...you'll need to use Windows Scanners and Cameras or Photo Gallery for scanning.
Jan 18, 2008 | HP Pavilion Media Center a1330n - AMD...
Lost CD for printer installation
my lexmark x6100 having problem to work with my window vista. i am very desappointed and very upset.and i can't uninstall it to reinstall again please help
Dec 10, 2007 | Lexmark X6150 All-In-One InkJet Printer
Hi Iwant to add a printer
Go to www.lexmark.com and click on Drivers & Downloads then Driver Finder. I did not see the X6100, but I saw the X6150 and X6170, hopefully that's what you have. You need to download the correct driver depending on what operating system you have. In other words, do you have Windows XP or Vista?
Here's a link on the Lexmark site that gives you step-by-step instructions on how to download and install a driver:
http://support.lexmark.com/cgi-perl/knowledgebase.cgi?ccs=229:1:0:383:0:0&framed=&docid=480&relevance=1
Good luck.
Nov 27, 2007 | Lexmark X6100 Flatbed Scanner
Computers & Internet Logo
27 people viewed this question
Alun Cox
David Payne
David Payne
