My Evolis New Pebble runs on a serial port I bought a IOGEAR USB to Printer port to run on my HP6910p laptop computer...as to date I have not been able to link the printer up with the computer. I need help
    New Friend:
  • 54 Answers
Check for port setting in Evolis driver Port tab
Posted on Aug 29, 2009
I change the printer tape in the printer and it still has the change tape light on
You have 3 possible problems/solutions:
1) Did you make regular cleaning?
2) Sensor is not working properly(maybe a replacement of spare part is needed).
3) Maybe you just connected your usb cable to another port and it generated a copy, in that case, delete all printer Evolis drivers from control panel and enable it from beginning again.
Nov 01, 2013 | Evolis PEBBLE 4 Led Card Printer
I have an Evolis Pebble 4. For each card printed, a white thin streak appears. This streak cuts through the entire card.
Try cleaning your printer first using the Evolis A5011 Cleaning Kit. If the line is solid and goes across the length of the card, you might have a burned/damaged pixel. Check with Evolis or your Evolis Card Printer supplier for warranty information, your printhead might still be under warranty.
-- The Pros at www.DiscountIDStore.com
Aug 28, 2011 | Evolis Pebble Color Card Printer
Hello, We have a problem with our EVOLIS PEBBLE
reload the ribbon make sure you load correctly and set the correct type of ribbon on the driver make this and reply to me
Aug 24, 2011 | Evolis Pebble Color Card Printer
Evolis pebble doesn't printer after standby
Just do one thing . Check the selection ports tab. Change it Apply it and again change it to original value and apply . This should solve problem. Also check if printer becomes offline. .
May 18, 2011 | Evolis Pebble Color Card Printer
I'm using Evolis Pebble 4 to print card, i wish to let the printer flip the card itself and print at the back of the card. So i first set the duplex of the printer to vbPRDPVertical on VB6, and then i...
Dear Sir,
Evolis pebble4 printer is a single side card printer . It doesn't has mechanism to flip the card.
If you want to flip the card automatically you must go for Evolis Dualys or higher model.
Apr 04, 2011 | Evolis PEBBLE 4 Led Card Printer
Evolis pebble 3 is printing very dark and then has large yellow and magenta spots
Check for luminosity and contrat settings in properties/graphic/more options
If you have replaced print head enter its serial number properly.
Apr 27, 2010 | Evolis Pebble 3 ID Card Printer Package...
Evolis Pebble Cleaning Kit
try right clicking the printer and choose properties under the tols tab there is a "printer self clean" try clicking that with the card at the feeder
Feb 26, 2008 | Evolis Pebble Color Card Printer
USB port connection
I had the same problem. I bought a USB to Serial Adapter (IOGEAR). Works great. I believe I got mine from Wal-Mart last year for around $25.
Look here: http://www.iogear.com/main.php?loc=product&Item=GUC232A&PHPSESSID=119a3d80d289daeb12185ff1ee32e7ff
Dec 17, 2007 | Kenmore 19001
IOGear multi-function USB print server
The direction of the GMFPSU01C will never tell you that you need to create another printer driver. Because, once you install the MFP Utility of this print server, you will have an automatic Copy1 icon of your printer once you successfully, detected the print server and once you successfully connected to the Printer.
Since, the computer is not detected the printer on the network, here are the things that you may do:
1. Make sure that the printer driver is properly installed in the computer. and make sure that the printer is working when directly connected to the computer.
2. If you can't detect the printer, disable your FireWall or any anti-virus program that's running in your computer.
3. Uninstall/reinstall the MFP Utility. If the CD is not working correctly, use the driver from the Website. Here's the link: http://iogear.com/support/dm/driver/GMFPSU01#display
Nov 13, 2007 | IOGear GPSU21 Print Server
81 people viewed this question
k24674
Marvin
Marvin
