Question about Dymo LabelManager 300 Desktop Labelmaker Printer
Cannot load Dymo Software in to Vista
Tried loading Dymo software, but as soon as it asks me to plug in to USB port, which I do, the programme will go no further, although it appears in my list of programmes, it says the drivers have not been loaded.
  • Dymo Master
  • 19,396 Answers
Installing Dymo software can be a real nightmare if you fail installation at first time.
Call Dymo customer support, they will follow you step by step, ask you to download dymo uninstaller for your model, and tell you how to clean registry. They got used to this.
DYMO | Contact Us
Posted on Dec 15, 2008
Cant get the stupid thing to be redognised by vista usb drivers for the mp3 not installed or regnoised
Hi There,               Vista should reconize  it as a usb divice and look into the storage space. Just try to use vista in the control panel and goto add new hardware if ask for driver just but in the software mini cd it came with. I have no problem with mine. If it does not work then you might have a faulty product or you should ask a vista tech how to identify a a usb divice mp4 player to windows. I know the pmp 8308 Missil is compatible with Microsoft Window Vista. It should just be plug and play and identify as a usb device so you can drag and load your videos or mp3s or pictures or even text into your ebook on the device. I hope I helped a bit. Good Luck
May 04, 2009 | Audio Players & Recorders
DYMO LabelWriter 400 Turbo Installed but gives error message when sending prints
First of all, on Dymos you need to use original Dymo roll,.
Dymo rolls have a tag at the back, non original ones does not have it.
Before reinstalling driver you also need to run the dymo uninstaller utility that you find at Dymo website.
I will post the links for download.
Oct 03, 2008 | Dymo LabelWriter 400 Turbo Thermal Printer
Loaded 3D Embroidery software on computer but will not recognize the dongle plugged in to the usb port. Drivers for dongle did not automatically load, went online to find a HASP file (driver I think) and...
1st try another usb port
2nd uninstall the software and plug the device in only after you have reinstalled the software and you are asked to plug it in. If it doesn't ask then install the software first and try again.
You can also right click on my computer and select manage.
then on the left side of the window select device manager, unplug and plug back the usb dongle and see if any devices appear or disappear also note any yellow ! marks. you may have to press the scan for new hardware button or right click on the window to scan for hardware changes.
Jun 18, 2008 | Husqvarna Rose
Can not find or activate comport 1 on windows Vista
Com port referes to a serial port. It looks like a monitor port only smaller. Since yuo connect via USB, it may be that the locator software is set to use Serial port or Comm Prot. See if it can be changed to USB. Perhaps load the software before or after plugin in the unit, that may make a differernce.
Apr 07, 2009 | Microsoft Windows Vista Home Basic for PC
Problem loading Webcam driver
Normal 0 You need to go to the manufactures site and download the VISTA driver for the camera. Then follow the info below to install the program.
Normal 0
Try disconnecting the Camera from the USB port and reinstall the CD or Downloaded software program. When the program asks you to connect the camera to the USB port, do so and it should work.
Hope this helps. Bud
Oct 27, 2008 | Computers & Internet
Just loaded software on my Windows Vista Laptop for the Nikon L16 digital camera------everything loaded fine but cannot get it to transfer pics from camera---it is not "seeing" camera when I have...
Software for camera in a required in Windows computers
And as you have Vista it is like not compatable anyway.
Remove the software and simply plug the camera in
Windows will recoginise it as an extra drive in 'My Computer.
or
Windows camera/scanner wizard will display
Aug 20, 2008 | Cameras
Genius Model-VideoCAM Messenger Problem
Disconnect the Camera from the USB port and reinstall the CD or Downloaded software program. When the program asks you to connect the camera to the USB port, do so and it should work.
Mar 31, 2008 | Genius VD3000022 Webcam
LG USB Serial Port
Have you tried using the USB port in non-enhanced mode?
Go to the Device Manager under Hardware in My Computer properties, scroll down to USB, and disable the "Enhanced USB", your mouse and keyboard will stop functioning for a minute; but will regain function.
Try plugging it now, it should work.
Hope That Helps!
Feb 10, 2008 | Toshiba Satellite A135 Notebook
Windows Vista installation of drivers.
i jus plugged mah concord eyeQ duo 2000 digital camera into mah usb port and it downloaded the drivers for me without usin mah disc on mah vista...
Feb 08, 2008 | Concord Camera Eye-Q Duo 2000 Digital...
LG and Vista
Hi vista shouldnt be the problem do you have the software for your phone installed on your comp as i have come across loads of problems with people not having the right software for their phone let me know if this is the case.
The one problem i did have with the usb port is when i was trying to use one of the ports i kept getting errors and i tried everything to solve it but to no luck,
Then the next day i plugged the usb into another port and found that it worked and to this day that one prot wont accept my phone but the other will, i dont know why but using the other port worked.
Let me know how you get on ok
Nov 26, 2007 | LG KG800 Cellular Phone
126 people viewed this question
Top Dymo Office Equipment & Supplies Experts
Marvin
Marvin
Jose Pino
Steve Allison
Steve Allison
Are you a Dymo Office Equipment and Supply Expert? Answer questions, earn points and help others
